Question about D-Link AirPlus Xtreme G DI-624 Wireless Router
I can't connect to the internet or router, only wan and 1-4 local network lights up
It just stopped working one day. I have the network set up with wep password. the power, status, and wlan lights are not on.
    Scholar:
  • 58 Answers
Check the power cable,try to connect it to a different power socket.
Change the powercable and check whether the power light is up
if still the same problem then it should be the hardware issue.
Contact the manufacturer or service provider if it is under warrenty
{If it is connected through USB and getting power from the computer itself then uninstall and reinstall the USB software}
Posted on May 27, 2009
How to configure router & switch
You shouldn't have to configure anything except the PC's should have IP and gateway set to auto.
Here is how it works:
A router connects two separate networks and manage the traffic between them.
In most home network applications the router connects your local group of computers and devices known as the LAN with the Internet, commonly called the WAN or Wide Area Network.
The router usually assigns unique Local IP addresses to all of the devices connected to it via a service known as DHCP. The addresses assigned by your router are private addresses http://en.wikipedia.org/wiki/Private_net... and are not routable across the Internet.
Dynamic Host Configuration Protocol (DHCP) is an auto configuration protocol used on IP networks. Computers that are connected to IP networks must be configured before they can communicate with other computers on the network. DHCP allows a computer to be configured automatically, eliminating the need for intervention by a network administrator. It also provides a central database for keeping track of computers that have been connected to the network. This prevents two computers from accidentally being configured with the same IP address. http://en.wikipedia.org/wiki/Dynamic_Hos...
Your cable or DSL modem will get a Public WAN IP address from your ISP's DHCP service. These public IP addresses are leased in blocks by your ISP and are Internet routeble. The modem is connected to the WAN port on your router. The router will manage the traffic between the devices on the LAN and the Internet.
If your 5 port switch is connected to one of the router's LAN ports and router's DHCP is on then it will configure the clients attached to It automatically.
Feb 04, 2013 | Computers & Internet
How do i hook up my router?
There are several ways to do this, depending on how your network is configured.
Generally, if you have only one router - you connect the network jack of your cable modem or DSL modem to the WAN ("wide area network" or "internet") jack of the router with a CAT 5 network cable or jumper. Each computer's network jack would be connected to one of the router's (4) LAN ("local area network" or "home network") jacks labeled 1, 2, 3, & 4.
In the picture above, the left most jack (WAN) of the router connects to the cable or DSL modem. The "LAN" jacks labeled "1, 2, 3 & 4" connect to each computer's network jack in your home.
The above would change if you are simply adding this router to extend an existing network. You'd likely be using this router as a switch, and leaving the routing duties to the main router. Over simplified, all the CAT 5 network cables would be connected to the 4 LAN jacks. There would be no connection to the router's WAN jack because the output of the first router provides only private IP addresses used in YOUR location. The internet IP address from your ISP is used only at the first router so that your entire home has the single IP address. The WAN jack is for internet addresses only - and the LAN jacks are for local / private addresses in your home only.
Have a look at the LinkSys web site for help configuring your particular model router, or reply with the model and version here.
I hope this helps & good luck. Please rate my reply - thanks!
Jan 28, 2011 | Linksys Wireless-G Broadband Router
What is theam.if we apply theam the wole appreance will change or only on desktop
How Can One Cable Modem Work With Two Wireless Routers? By Terry Stockdale Leave a Comment In How to Fry a Wireless Router or Two, I wrote about my brother's experience frying a pair of wireless modems in a lightning storm. Last week, I talked about what had happened, why it happened, and what he could do to prevent the problem in the future (this was the third set of routers, plus he lost a computer motherboard in that storm).
This week, we'll look at his network layout, and why he could not get the network to set up properly.
To summarize the situation, he has an office an a shop, with computers on his network in both locations. Some connect via wired connections (Ethernet), while others use wireless connections. His Internet cable comes into the office first.
In the past, he first used Linksys wireless routers. Then DLinks. This time, he chose Belkin wireless routers.
The incoming cable (standard cable-company RG6 coaxial cable) connects to the cable modem.
Then, the cable modem connects to the WAN (wide area network "Internet") connection on the router.
The local wired ports on the router provide connections for two wired computers. Notebooks connect via wireless connections. Finally, one wired connection on the router is used to connect an Ethernet cable that runs 250 feed to the office from the shop.
That cable was the lightning problem, as it runs outside in a conduit just a little bit underground. Effectively, he's got a 250 foot antenna looking for the electromagnetic pulse from a lightning strike. Most of us don't worry about that because our equipment is so well grounded in the house, plus the Ethernet cables we use are much shorter lines. Even if we have underground cable company lines running from their switch boxes to our houses, those lines are usually only exposed about 40 to 50 feet before they enter the dwellings.
Back to the situation. When he hooked up his replacement routers, the router at the shop immediately worked. Not so, on the router in the office. The Ethernet light and the Activity light just poounded away, blinking and blinking rapidly. But, nothing connecting to the router could get to the Internet.
If they connected a computer directly to the Ethernet cable in the office, without running it into the router first, it worked just fine. But, with the router in place, it didn't work.
The problem was the way he connected the two routers. The problem is that there is no Out Of The Box connection that will work reliably. At least one thing, usually two, has/have to be tweaked one way or another.
As one might guess, the easiest way to connect would be to connect one router's WAN connector to the cable modem, using Ethernet cable, and then use Ethernet cable to connect one of the Local Area Network (LAN) connectors on that router ot the WAN router on the other computer.
There is a problem with this setup, but it's easily solved. First, if you're using identical wireless routers, as he was, the wireless routers are both trying to use the same IP Address range and subnet mask for their local area networks.
That works fine for the first router, which is connected to cable modem. On the cable modem side, it gets an IP address on the Internet Service Provider's network - often an actual Internet address and not just a private network address. On the local area network, it assigns the IP address range specified in its setup menu. This often varies by manufacturer. In the case of Linksys, this is 192.168.1.x. In the case of the Belkin routers he bought, it was 192.168.2.x.
The problem occurs at the second router. On it's WAN side, it sees a 192.168.2.x network - but it's default setting tells it to give 192.168.2.x addresses on it's local area network side, too. In other words - it's confused. It doesn't know where to find the Internet because both networks are assigned the same addresses.
The solution was to disconnect the second router's WAN/Internet cable, connect to it via a wired computer, and tell the second router to use a different IP address range. We chose 192.168.3.x.
We hooked up the Ethernet cable to the Internet/WAN side of the router again. The router started working fine, normal light blinks for activity, no more confusion. The computers could get to the Internet just fine.
Problem solved.
That solved the Internet connection problem. However, no computers in the office would be able to share files or printers with the shop, nor would computers in the shop be able to share with the office. That was both acceptable and intended, in this case.
It could be done; however, that would require a different configuration on the routers and connections.
Jan 05, 2011 | Computers & Internet
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    Wanting to make my laptop wireless connection
    Hello.
    Connect the MODEM (device you received from your Internet Serivce Provider that gets the Internet signal) to the router via the WAN port. WAN stands for Wide Area Network and this gets you out to the Modem and then to the Internet.
    Ports 1 and higher are for computers and network printers that you can directly connect to your LAN - Local Area Network.
    To secure your connection, you will need to configure your router and you will need to connect your laptop to the router (either wireless or via one of the numbered ports on the back of the router), open a web browser and enter the IP address of the router.
    Since you did not put the model of the router, I cannot give you specifics on how to secure the connection. You can go to the D-Link web site, find your router, download the manual and it will walk you thru the settings.
    Basically, you will be entering a WEP key (a set of letters and numbers that you know) to allow only wireless computers that have this key.
    Apr 30, 2010 | D-Link DI 514 Wireless Router (DI-514)
    Trying to hook up router. What is the wan for and the 4 inputs
    The WAN port is the physical interface that provides input and output to and from the device that provides Wide Area Networking capability .. i.e. the modem that connects to your Internet Service Provider. The usual choices are a DSL modem, a cable modem or a Wired router or a wired switch.
    The 4 other inputs are wired inputs and outputs for wired Local Area Network connections.
    The WAN port normally connects to the Internet. It is not necessary to connect anything to the WAN port to have a network. But without one of the usual devices, you will not have access to the Internet.
    The LAN ports connect to the network interface port on the individual computers that are part of the local network. One port connects to one computer.
    A large system will have routers connected through the LAN ports to the WAN ports on sub routers and so forth.
    Nov 25, 2009 | Dynex DX-E402 Router
    Trendnet 633-GR won't connect to the internet
    Well I think that the internet is down from your ISP side
    Did you try to call the internet service provider ? Your ISP must be DSL .
    with the message " ue Mar 09 13:06:51 2004 PPP network down [INFO] Tue Mar 09 13:06:51 2004 WAN interface is down [INFO] "
    It seems that the internet is down on the modem.
    Click Here for more info about networking
    Oct 07, 2009 | Trendware Computers & Internet
    My D-Link Xtreme G DI-624 worked quite well for 5 days -- then failed to connect with Internet while I was using it 2 nights ago. "Network Connection Disabled" was the message. Can you tell me which cables...
    From modem's ethernet, connect the wire to the router's Internet/WAN port. From your PC, connect the wire to port 1 of the router. If it says network connection is disabled, right click on Local Area Connection and click on Enable.
    Jun 04, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
    D Link model 2310
    When you connected your PC directly to the modem, were you able to get the internet working automatically or did you have to run a dialup-like connection?
    If it worked automatically, try this:
    1. Connect a PC to a numbered port of the Dlink router (don't connect the modem to the router nor the PC)
    2. Open Internet Explorer and enter http://192.168.0.1 on the address bar. This should then ask you to login. (restart the router and the PC if nothing happened then try again)
    3. Enter admin for the username and blank for the password
    4. Once you're on the Dlink Setup page, click on Network Settings on the left panel.
    5. Change the Router IP address to 192.168.2.1 then hit Save Settings
    6. Now, connect a cable from the Speedstream modem to the WAN port of the Dlink router then check if your internet is working from the wired PC.
    If its still not working, turn off the modem and the router and then power the modem first (wait for the lights to be stable) then plug the router.
    Hope this works for you. Goodluck!
    Nov 07, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
    WAN
    The wan port is what you hook your modem to. Wan stands for Wide Area Network, which in your case is the internet. Your house with your 2 pc's and networking equipment would be considered a Lan, local area network.
    The 4 ports on the router are switch ports, when you hook the modem up to the switch instead of the wan port the modem will only allow traffic from one physical, (MAC) address to pass through, this is why only one of your pc's can access the internet. The wan port on the router has its own MAC address, so the modem will associate with the wan port and trust all traffic that comes from that port.
    Finally, after you have connected the modem to the wan port, pull the power cord on the modem then plug it back in to reset it, this will force the modem to orient with the wan port.
    Jun 01, 2008 | Computers & Internet
    D-Link AirPlus Xtreme G DI-624 Wireless Router Logo
    135 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
