Question about Dishwashers
Haier HDW300ss - Powder/tablet not dispensing.
  • marson69 May 26, 2009
    Hi Ginko,
    Thankyou for your response. The draw does open. I will check the spray arms and impeller pumper and water temperature and see how that, on your advice. I will do this in the morning as it is late where I live.
    I let you know how i go.
    Kind regards
    Maria
  • marson69 May 29, 2009
    Hi Ginko,
    Sorry for my delay. I have checked everything bar the impeller pump, as I can't get to it. My husband will check this for me in the morning. I will let you know how we get on.
    Regards
    Maria
  • 19,396 Answers
The soap dispenser drawer is supposed to open during the cycle. Try first to understand if the drawer is opening or not during cycle.
If the drawer is not opening, then check if the opening mechanism is stuck, if it is blocked by dirt and soap, if it is broken, or if something, for examble a basket too close to dispenser drawer is preventing the drawer from opening.
Some dishwasher works only with powder, in that case indications are given on the owners manual.
If the drawer opens and the table, or powder is still staying stuck in the drawer, then that means that the spray does not have enough power to solve the tablet.
In that case check spray arms and impeller pump.Also check water temperature.
If the problem is also happening with powder, then it is probably a drawer not opening on cycle.
HDW36TS
Posted on May 26, 2009
  • Ginko
    Ginko May 26, 2009
    Check also the water supply at the back, if the machine is getting insufficient water from supply, that will cause low pressure on recirculating.
  • Ginko
    Ginko May 29, 2009
    Hi Maria.
    I also suggest contacting Haier to ensure that you are using the right powder, or to see if they can have some more idea.
    Several Haier models do not work with tablet, and ony use powder.
    The drawer door must open at the beginning of the cycle, and it is operated by a solenoid that must open the door at first part of the cycle, just after enough water had entered in the machine.
    What a technician does is testing the drawer solenoid first, by energizing it, and then , if it works, reading power at control door terminal with machine cycling. This last test is not an easy one, and must be done by an experienced technician, as you have to read power with machine cycling, and this will be highly unsafe if done by a home DIYer.
    I hope this helps.
I have a Haier HDW300SS dishwasher. The top half is cleaning the dishes normally but the bottom dishes aren't being cleaned at all. I've cleaned out the sump and checked the bottom spray arm i
Dear Sir:
See the diagrams attached and proceed according with the common sense.You can use the instruction manual in section troubleshooting.if you do no have go for free download: www. fitness. manualsonline.com or www. retrevo.com
May 07, 2012 | Stoves 27 in. DW60 Built-in Dishwasher
Tip
Dishwasher does not dispense cleaning tablet
on May 26, 2009 | Stoves 27 in. DW60 Built-in Dishwasher
White film left on the dishes after going through the dishwasher. Why?
Too much rinse agent. If you are using powder or gel, set pointer knob on rinse agent dispenser to a lower setting. If you were using the tablets, they have rinse agent built into them, and the additional rinse agent from the dispenser equals a double dose, so the film shows up. Stop using tablets until liquid rinse agent dispenser is empty.
Apr 14, 2011 | GE Dishwashers
I have a Haier HDW300SS dishwasher. My problem is that it is not dissolving the detergent powder. It doesn't even get wet! Is the bottom spray arm at fault? Have tried putting less dishes on the lower...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 03, 2011 | Stoves 27 in. DW60 Built-in Dishwasher
Dishwasher dispenser will not open. I've been using the detergent tablets and am wondering if I should be using a liquid or powder instead?
Try starting a cycle without using detergent at all. If the dispenser opens, you just need to use powder detergent because the tablets are too big for the dispenser. If it still doesn't work, replace the dispenser. Go to the link to see how to take the door apart and replace the dispenser.
http://www.appliancerepairlesson.com/2011/01/29/dishwasher-soap-cup-dispenser-replacement-dishwasher-repair/
Good luck
www.ApplianceRepairLesson.com
Mar 05, 2011 | Whirlpool DU840CWD Dishwasher
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
Simpson brand dishwasher won't disperse detergent tablet
Feb 18, 2009 | Dishwashers
Detergent dispenser - Fisher Paykel dishwasher DD603
manufacture does not reccomend using tabs, small amounts of powder, will work jsut fine
Dec 25, 2008 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishwasher powder/tablet not being used
Yes
The problem is not enough water presure is hitting the soap dispenser. Probably the top rack of dishes is not getting clean either! look for my post about fixing with CLR and use that see what happens then
Thanks
Kashif.A
Mar 06, 2008 | Dishwashers
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
