Question about Humax 19 in. LCD TV
Stuck in standby
Humax lgb-19dzt stuck in tandby. does anybody know how to cure this fault?
3 Suggested Answers
hmerchant110
  • 7191 Answers
SOURCE: User Instruction Manual for a Humax LGB-22DRT TV
Hi, You can download the required manual from:
http://www.humaxdigital.com/global/support/downloadcenter_manual.asp
You will find it listed under "Digital TV". Click on the English link next to the model number to download the manual.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Posted on Aug 26, 2009
  • 473 Answers
SOURCE: I have a humax lgb
Hi... I see you have problem with you Humax tv conserning your screen.. it possible your tv tuner logic board fail to response to the video board, and need to be check for over heat component..
Posted on Oct 18, 2010
I have a human LGB 19DZT When I turn it on it doesn't turn and the stand by light is not on
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. ..
Aug 21, 2016 | Televison & Video
I only have one scart outlet on my tv my ariel is in the wall and mthen into my tv but its just picking up tv programmes on my humax recorder and not through my tv
The aerial should first go to the Humax, then from the Humax to the TV. Make sure power-saving is turned off on the Humax, otherwise it will not pass the aerial signal to the TV when the Humax is in standby.
If ypou want to use Humax power-saving, the aerial must be split so that one feed goes to the Humax and another to the TV.
May 19, 2016 | Humax Televison & Video
Its stuck on standbye
If it is a few years old, the most likely cause is failing PSU (Power Supply Unit) capacitors. These are replaceable by a competent electronics repairer.
For a more accurate answer, the model number would help.
Mar 15, 2014 | Humax Televison & Video
Does anyone know the code for a Sky+ remote control to work a Humax LGB-19DZT television.
381,386. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 20, 2013 | Televison & Video
I have a humax lgb 19dzt for just over a year now and when i turned it on this this evening, it presented me with a bright white screen and no sound. Have turned it off and on again and still no luck. Any...
have you tried the remote's menu to see if it's on anything else other than TV Broadcast?? the other thing I can only think of is the Tuner/modulator might have suffered electronic damage as a possible result of power surge... I've always suggested that surge protectors should be used on sensitive electronics...
Oct 18, 2010 | Humax Televison & Video
Stuck on amber light will not turn on
An amber light normally means that there is no signal getting to the screen, if it was stuck in standby then the LED would be red.
Please check your connections to cure the fault
May 31, 2010 | Harsper HP-4200B 42 in. Plasma Television
Aug 26, 2009 | Humax 22 in. LCD TV
Humax lcd-19dzt
Hi.
Try this,
It involves finding your make & model number from Sky.
Press INTERACTIVE BUTTON., then SKY CUSTOMER SERVICES,
then TECHNICAL ASSISTANCE, FOR ALL SKY REMOTES.
Now follow the on screen instructions.
http://dysonmanuals.inc.io/
Chris.
Dec 09, 2007 | Televison & Video
Humax  19 in. LCD TV Logo
307 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
