Question about Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW
To find out symbols on my freezer s and a triangle
I have a polar king freezer with symbols S a triangle and I don't have a clue what they mean and I bought it wthout a manual. Cany anyone help?
  • Robert Moller
    Robert Moller May 11, 2010
    How about a model number ?
Frigidaire triangle symbol
Good Morning Jon, this is Z. Thank you for allowing me to assist you!
I see that your post is listed under Frigidaire freezers. Please help me understand if the question you are asking is related to the "UP" and "DOWN" arrows that are designed to change the temperature setting? If you are speaking about another triangle symbol, I will need your model number please. The serial tag, which lists your model number, is normally located inside the cabinet, on the left side wall. With this information I can better address the issue at hand. Thank you!
Jul 25, 2014 | Frigidaire Freezers
What do the symbols on my Electrolux freezer mean?
That is the model number. The E means European. The w at the end means that it is white in color.
Jul 19, 2014 | Electrolux Freezers
I have the red triangle symbol lit up what does this mean?
This means the sensor has determined that the temperature is rising. This can happen if the door was left open or an unusual amount of warm food was put into it. If this is not the case you may have a cooling problem. If you can put a thermometer in there and check the temperature, working properly the freezer should be around 0 F. If you have trouble please send the model number from the tag on the freezer. That will help with trouble shooting.
Thanks
May 01, 2010 | Whirlpool 10 cu. ft. / 283 liter Chest...
We have just got a second hand ice diamond freezer and not sure what the 2 drip and 1 drip symbols mean can you help me thankyou,
hello sir/mam
the symbol 1 drip indicates the normal settings,and the 2 drip symbol indicates higher settings.
Oct 04, 2009 | Freezers
What does front breathing mean?
"Front Breathing" usually means the refrigerator has a fan forced cooling system (condenser fan) that gets it cool air (and usually exhausts the warm air) via a front vent. The vent is usually located on the bottom or top.
Aug 10, 2009 | Silver King 1242.90 Front Breathing...
Freezers Logo
1,016 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
