Question about Candy CNW136 Front Load Washer/Dryer
Whirlpool AWO 3561 Door lock light starts flashing + wash stops
I shut door, select programme and the cycle starts but within 30secs the door lock light starts flashing and machine stops. Have tried pushing the door to check door closed properly, I have tried different programmes. The door won't open even though light flashing, I turned maching off and door releases after a few minutes.
Machine about 4 years old and out of warranty.
Can someone help, need a cheap solution.
Thanks
  • 343 Answers
SOURCE: my washing a whirlpool awo 10761 front loader,when
If you can still open the door when it's supposed to be locked it probably means that the interlock on the door catch is faulty.Easier to fix than if the door is locked shut!!...Not a big job but should be done by a qualified tech. See if you can find an independent, self employed tech...Generally cheaper and better than 'Brand Name' servicemen..Good luck..........Nomess
Posted on Apr 18, 2010
abhishek33
  • 1239 Answers
SOURCE: AU AWO 3561 whirlpool washer comes up with FP on
hi it is the problem o outlet valve, clean it...... thank u.......
Posted on Jun 03, 2009
SOURCE: Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Posted on Jan 04, 2010
  • 19 Answers
SOURCE: Washing Machine will not empty after cycle machine
Drain pump may not be working or the drain hose is clogged up
Posted on Jan 16, 2010
SOURCE: my whirlpool AWO/D 4305 washing start button keeps
the dish washing machine does not turn on at all! the strat button ligh just flashes and nothing happens!
help please
Posted on Jun 06, 2010
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Whirlpool awo 9663 wont start cycle
This can be due to failure of motor components or the control panel as there is no communication for the drive . Check the motor to panel wiring, check the panel for failed component
Jul 05, 2012 | Whirlpool Washing Machines
Whirlpool AWO 10781 door locked light flashing
Hello
Unplug the device from AC mains socket, and replug it after 10 minutes and check. If it does not help you, the machine has to be troubleshooted. Its internal memeory circuit [electronic] has the fault.
Feb 01, 2012 | Whirlpool Washing Machines
I have a whirlpool sixth sense washing machine. the door open light constantly flashing although the door is well shut. No programmes work
We had the same issue: the cycle would start then stop, with the door open light coming on. It turned out to be a faulty contact in the door. Took a technician 15 minutes to fix.
Aug 04, 2011 | Whirlpool AWM8143 Front Load Washer
My washing a whirlpool awo 10761 front loader,when i switch it on after 20 seconds the ''door locked'' light starts to flash and the programme goes no further
Apr 17, 2010 | Washing Machines
FP fault code on whirlpool washing machine
i have a whirlpool 6th sense awo 10761 and evrytime i start a cycle it stops and the door lock light flashes can any one help me
Nov 07, 2009 | Whirlpool Washing Machines
Front Loading Duet Washer will not start
You have to set your programme FIRST, then put the "on" switch. Try.
Mar 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Candy CNW136 Front Load Washer/Dryer Logo
1,159 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
