Sounds trivial, but want to make sure I am connecting drain hose to the dehumidifier correctly. Don't have the manual, hence need some help. There is a membrane on the back side between the hooks, which I removed with a plier. I even opened the back panel to see where the hole to connect the drain pipe is. There is a sqaure strip of cardboard piece glued at the back, which I believe is to be removed. I believe the drain outlet is behind that.
If you go to this site you can download the owners manual. Follow the instructions and it should solve your problem.
http://136.166.4.200/contents/Dehumidifiers/DH30.htm
Sgt 48
I have connected the drain hose, but find the bucket is still filling and the unit shutting off until I empty the bucket. Is there something else I need to do so it will continually drain via the hose?
