Question about Samsung Televison & Video
Remote Frequency Problem
I have two Samsung plasma TV's, the problem I have started when I purchased the second one which is a PS50A550. In order to change channels on my satelite TV decoder in a room away from the decoder itself I use a remote signal strengthening device. The problem is that the signal from my Samsung remote is also being amplified and when operated the TV in the other room is operated as well as the one I intended to operate. The problem is clearly as a result of both the TV's using the same frequency for the remote. The older of my two TV's is about 3 years old,sorry do not have the model code with me. Is it possible to change the frequency on one of the TV's ?
  • 236 Answers
SOURCE: can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Posted on Sep 09, 2007
SOURCE: code for universal remote
0463
Posted on Jan 02, 2008
swampduck651
  • 5 Answers
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
Posted on Feb 05, 2008
SOURCE: IR frequency determination
The remote could be using RF, which is why your Niles equipment cannot handle it. There is no way to duplicate the RF or convert it to an IR signal.
If the remote is using IR, make sure the batteries are full and the light is low when you are learning the codes with tne Niles equpment. There is no way if it's IR that the freq is > 100.
Posted on Apr 23, 2008
  • 133 Answers
SOURCE: - SKY REMOTE CODES
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Hitachi TV is either 0000 or 0145. If these numbers do not work, then I would buy a newer universal remote. They can purchased at Walmart for less than 10 dollars.
Posted on Jul 13, 2008
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Tip
SAMSUNG PLASMA POWER SUPPLY CLICKING.
If you have a Samsung Plasma PS50A550 which will keep clicking and not come on, the fault is in the power supply .Check Power supply if its a BN44_00222a. This PCB cost almost $ 300.00 can be fixed for around $ 30.
The fault is in the 5.3v supply to the T.Con PCB. On the Power supply check voltages.VS will not come on unless the T.Con pcb is active.
Check on printed circuit side of PCB on secondary side there are 3 IC close to one another. 2 IC'S are 8 pin and one is 16 pin. Replace both 8 pin reg IC (25h3ll ) these are available from RS components. Part number is STS25NH3LL. The 16 Pin IC is a L6725A but this is not faulty.
lets keep these good TV working for another 4 years.
on May 30, 2014 | Samsung PS50A550 50" Full HD Plasma TV
Just bought tv today. Remote will work for a second then stop. Checked and there is a white light when I use a camera. What's going on?
Sounds like the crystal failure to the remote control's circuit board. There is a crystal that oscillates at a constant frequency, and this frequency is divided by some certain frequencies lower that it, when we press each button on the remote control, and an infrared LED at the front of the remote control will emit infrared rays according to this divided frequency, which in turn will absorb the infrared sensor inside the TV. In fact, if the basic oscillator crystal do not generate the adequate frequency, all the output frequency will differ from what it meant for; and TV set will either process it or not.
Just replace this crystal first. If it do not help you, buy an other remote control.
Gopakumar Gopalan Google
The component I've stated above will look somewhat like this.
May 05, 2014 | Samsung Remote Control AA59-00600A...
Will a Samsung AA59-00482A remote work with my Samsung PN50C450B1D plasma TV?
all samsung remotes work for each other only diffrence some keys on remote may not there but for menu and vol channel all function works once its a tv remote
Apr 28, 2014 | Samsung Televison & Video
TV shuts off with volume control
Improper signal frequency goes to the TV from the remote control. Check your remote control for fault. Gopakumar Gopalan Google
Mar 23, 2014 | Samsung PN58B550 58 in. Plasma HDTV
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
Lost remote can i still tune the channals
Hi, you can tune the channels of the Plasma TV without Remote Control. However, I suggest that you to purchase a new Remote Control of the same model number of the Plasma TV with any near by Plasma TV dealer.
Apr 07, 2011 | Samsung PS42B430 42 in. Plasma TV
Hi we have a samsung 50" plasma tv it started
Look for Bad Capaciotrs on the power supply board ,they will be vented or puffed up on top
1000uf 16v 2200uf 10v 3300uf 10v ect...
Feb 03, 2011 | Samsung HP-R5072 50 in. Plasma HDTV
Universal Remote codes for Norcent Plasma HDTV 42
Try other manufacturers' codes. I used 10178 (a code for MGA TV) and it worked on my Norcent. The other codes for MGA are 10150 and 10030.
Jan 05, 2008 | Televison & Video
Televison & Video Logo
309 people viewed this question
Jerry Greenberg
Jerry Greenberg
