MY DVD DRIVE IS NOT RESPONDING TO DVD DISCS IT SHOWS IT AS A CD-ROM IN THE DEVICE MANAGER I HAVE TRIED REINSTALLING THE DEVICE AND I CANNOT ALSO FIND THE DRIVER FOR MY DRIVE HELP ME FIND IT MY DRIVE I
MY DVD RW DRIVE HAS STOPPED RESPONDING TO DVD DISKS I HAVE TRIED REMOVING THE DRIVE AND THEN REINSTALLING IT
    President:
  • 156 Answers
FIRSTLY MAKE SURE SINCE HOW LONG YOU ARE HAVING THIS PROBLEM AND TRY SYSTEM RESTORE IF YOU HAVEN'T TRIED IT AND IF YOU HAVE THEN FOLLOW THESE STEPS...
1) Click on Start -> Run -> Regedit-> Registry Editor Will Come Up.
2) Then Follow These Registry Settings By Clicking The Small Triangle Mark In Front Of It..
3) HKEY_LOCAL_MACHINE
SYSTEM
Current Control Set
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
OR SOMETHING WHICH IS SIMILAR TO IT BUT IT SURELY HAS THE E965 IN IT. IT WOULD BE NEARLY 5TH or 6TH Registry Key....
In Short Guide Yourself To This
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Once You've Reached In The Registry Key Then On The RIGHT HAND SIDE BOX Right Click upper filter and lower filter and then delete it...
Restart Your System
See Everything Would Be At Place...
Reply To The Post If You Need Any Further Help....
Posted on May 26, 2009
    Problem Solver:
  • 10 Answers
Cant understand properly; is dvd drive dislpaying in my computer ??? if not there is loose connection problem or if dvd writer is showing in coms setup (while starting pc u may press DEL key and go to CMOS setup> in main menu if you find dvd writer and it is not showing in my computer ) means your operating system is currupted. u may need to reisntall it. if problem is with reading disk u need to clean drive with disc cleaner CD.
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
My dvd/rw drive reads all discs, but not able to
It depends on what you have in your disc player that tells it what it is if nothing then it shows CD player if you put in a DVD then it will show DVD drive, go to start click on my computer then right click on properties then go to hardware then device manager then click on your CD/DVD ROM drive and right click on it and click update drivers if that does not work then you may have the Wrong DVDs I have had that happen where I had DVD- and it was supposed to be DVD+ also the right protect could be on what your trying to record and you would have to use your program to un-protect it to record. hope this helps. Thanks for using fix-ya
Jan 19, 2010 | Computers & Internet
CD - ROM
If you haven't tried reinstalling the drive, this may help:
- Open the Control Panel - Open the System folder - Click on Hardware - Click on Device Manager
Locate the DVD-CD-ROM entry and expand it. Highlight your optical drive and press 'Delete'
If it argues with you, answer 'Yes' to the question of deleting the drive(s)
Reboot your computer and watch for a message box reading that a 'New Device' was found and software for it is being installed.
If it still doesn't want to cooperate, then the drive is probably 'toast' and will need to be replaced.
Sep 15, 2008 | LG CRN 8245B (CRN-8245B) Internal 24x...
CD ROM drive not seen in "device manager"
i think you are going to have to boot into bios and where it shows the boot configuration look to see if there is a cdrom there if not change it so the computer will have the cd rom in there along with the harddrive and the a drive then save it and exit and reboot then the cd rom should be back into the device manager and also under my computer
Aug 17, 2008 | Samsung TS-H492 (TSH492AWRBH)...
Cd-dvd rom error code 10. failed to start
I had similar problems with my HP computer and i found either uninstall it through device manager the reinstalling it through new hardware wizaed in control panel. Or if that doesnt work try opening your laptop up and unplugging/removing the drive itself and restarting the laptop then turn it off again and put the drive back in the computer should then register it as a new device and reinstall it. that second option worked for my drive so it should hopefully work for yours
God Bless
Braydon
Mar 28, 2008 | Toshiba Satellite P205-S6287 Notebook PC
DVD works but not regular CD ROM
try frimware update for it from site ok pioneer.com ok
Feb 07, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
Aspire 4520 DVD combo problem
try uninstalling the drive in device manager then reinstalling it allso check for bad connections
Oct 14, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
