Sony Vaio VGN-FS315M
This laptop has been dropped and I'm trying to resurrect it if possible.
The laptop seems to start up ok with all front and top lights working. The battery light responds correctly to the presence of the battery and the heatsink fan will switch on when the heatsink gets hot which suggests to me that the motherboard is mostly working.
The screen, however, never switches on and no picture is visible using the vga plug and external monitor either. I've closely inspected the screen and can't find any leaking crystal. The backlight also doesn't switch on.
The HDD sounds a little sick when the laptop starts up but I'm hesitating to say this is the cause of the problem because I would have expected to see the laptop at least boot into BIOS with it removed.
Does anyone have any other suggestions for what could cause this? My guess is the GPU or RAM but I'm looking for guidance as to which.
  • spuzzdawg May 26, 2009
    Just to clarify, I didn't say that the laptop boots into BIOS with the HDD removed. I said that that is what I would expect the laptop to do if the fault was caused by a faulty HDD based on my experience with desktop computers.
  • 79 Answers
It Sounds like your motherboard that faulty, Cause if it boots into the Bios with the hdd removed, then its your motherboard, I have had the same problem a week ago with a HP notebook, I would suggest removing the HDD and connect it to a external enclosure, and them make a backup off all your data, before you try anything else.. good luck
Posted on May 26, 2009
Sound for sony vaio vgn-fs315m
sony is the only that can help you /i know i had one good unit but i will never buy one again
May 18, 2011 | Sony VAIO Notebook
Sony vaio vgn-cr510e overheating and sutting down time to time what seems to be problem
Either the cooling fan is not functioning properly or not functioning at all, or the heat sink's vents are blocked by dust & need to be cleared.
Another possibility could be that the thermal grease applied to the top surface of the CPU and/or the graphics chip has dried out & needs to be cleaned & new fresh thermal grease applied.
Jan 08, 2011 | Sony VAIO VGN-CR510E/L Laptop
Installed 2GB of RAM (2x1GB). Laptop only recognizing 1GB. How do I get Sony Vaio VGN FS 760 to recognize 100% of RAM?
Sony VAIO VGN-FS 760/W supports PC-3200 400MHz and PC2-4200 533MHz DDR2 RAM
Expandable up to 2GB. Please make sure that both RAM Chips are according to the above specification, compatible with yout system and both sticks are the same (make & bus speed). Try using one RAM at a time and swaping RAM slots to see if the amount of memory is shown correctly. Memory is not recognized only when it is not up to the specifiction. If the RAM sticks are ok, the system shoud recognize them.
Let me know if any further clarification/ assistance is required.
Good Luck!
Hope this helps!
CreativeTECH
Jan 08, 2011 | Sony VAIO VGN-FS760 Notebook
I have a sony Vaio VGN-CS110E. It was running and just stoped. with no power. When I tried to power on I got nothing except the light on the front for the AC. I removed the battery and the AC and held the...
I wonder if your 'Front Light' seems any dimmer than what it was?
It can be your aging power supply is not providing the full voltage your laptop needs?... Let's say your laptop needs 19.5 Volts (and it DOES), but your supply can only provide 16 or lower volts? You may see results like you are getting now...
New supplies are not that expensive (about $14 inc US shipping) and rather spending a lot for diagnostics and waiting a week or so, a new fresh supply MAY be all you need!
OK... I just found a NEW supply for $8.52 on eBay for your system and he's a US Shipper too. It's worth a try!
Anthony
Vaio VGN CS110E power supply eBay
Oct 18, 2017 | Sony VAIO VGN-CS110E/W NoteBook
Hello I formatted my Complete Laptop and looking for Sony Vaio VGN-FS315M drivers but none of them is available for Free? can anybody help where I can find them please thanks rao
This is the option to restore to factory defaults if you have used original sony install disc. http://genesis.sony-europe.com/instranet/ccil_sony/selfservice/search.jsp?DocId=35564&l=en_GB.
This is the option for drivers for your model that came with computers original Operating system. Just press accept and download zip file. Some other drivers are available and as well some updated ones and different Operating Systems. Good Luck.
http://support.vaio.sony.eu/computing/vaio/downloads/info/info.aspx?l=en_GB&url=Vaio/Original/FS3_Drivers.zip&m=VGN-FS315M&ip=Preinstalled_Drivers_HD.htm
Nov 02, 2010 | Sony Computers & Internet
Remove the drop down icon bar on sony vaio
Usually, with a dropdown toolbar, you can put the cursor all the way to the top of the screen and with the toolbar visible, right click on it to activate a control menu from which you can stop it from dropping down, unlock it and move it to either sidr, or even turn it off altogether.
If this doesn't work, try entering yout laptop model name in Google search followed by "disable dropdown toolbar" for blogs and forums for your laptop model that may have a specific command or trick for your machine.
Good Luck
Jul 27, 2010 | Sony VAIO VGN-CS260J/P Laptop
How to check mbx-160- vaio
I HAVE A SONY VAIO LAOTOP VGN-N31S DO NOT START UP. LED LIGHTS ARE ON. SCREEN IS DARK. CAN ANYONE HELP
Feb 20, 2010 | Sony Computers & Internet
Computers & Internet Logo
504 people viewed this question
David Payne
David Payne
