Question about Sony SRS-D2100 Computer Speakers
Sony speakers do not switch on
I connected all cables to my laptop but no sound comes out of the speakers, it is switched on but does not seem working
  • 66 Answers
I think ur sound driver not properly installed plz reinstall again properly .
Posted on May 26, 2009
Viewsonic n3246w manual
I have had this problem before and all you have to do is click on the sound button on the task bar (bottom Left) and click 'mixer', make sure that the sound is coming to the TV and if it is still not working try moving the HDMI cable in a circle while it is still connected to the TV and the laptop/computer. Hopefully it should then make sound but if the problem still persists try restarting the laptop/computer and/or TV. The cable might be broken so if the steps above to not work try getting a new HDMI cable and make sure it is plugged in properly into the TV and the laptop/computer. Hope this helps.
- Nathan
Apr 18, 2014 | Computers & Internet
I have a sony explode1000 watt amp xm 2r1852 hooked up to 2 10" Sony explode 1100 watt speakers, my protection light comes on green and stays on but I don't have no sound .I've checked all the wiring and...
1000W system is enough power to blast your neighborhood. If the + and - connections are correct the speaker balance is connected properly. I assume you have checked the speakers and they have been working fine.
Thus, the problem is internal, within the amp. Make certain that you have selected the proper sound out to the speakers. With the speakers attached, keep switching around from one sound path to the other. Make certain, your source (input to the amp) is proper and the signal is communicating with the amp. If the amp has direct out ports to L/R Center and Surround that you can use wires to connect to the speakers, try that method.
Feb 17, 2018 | Car Audio & Video
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
HP Pavillion dv6110us Speakers not working
The sound power comes through a ribbon cable to the power button,along with the power supply switch wiring. This "power ribbon cable"( part # 431437-001) has frayed where it connects to the motherboard.
The new cable will cost you about $5 with free shipping on ebay and takes about 10 minutes to replace.
You can find step by step instruction on the repair by searching "dv6000 power ribbon removal".
Feb 06, 2010 | HP Compaq Pavilion dv6110us Notebook
Bose Companion 2 Speakers won't work with Sony Vio Laptop
You don't write which operating system you use, but generally you should be able to choose where the sound output goes in the Sound Properties in Control Panel.
If however Sony decided to put some special software that does the thinking for you, and directs the sound output via the HDMI when connected, then you have to dig deeper...
Oct 30, 2009 | Sony Audio Players & Recorders
No sound coming from Sony Receiver STR-DG510?
Sounds like you are pretty close with this one. If you select fm tuner do you get audio. If not you may have the speakers on the wrong a-b setting. Make sure the audio from your cable box is not muted or turned down.
Mar 15, 2009 | Sony STR-DG510 Receiver
I have a Sony STR-DE635. It has a switch on the front for speakers A, B, and A+B. Normal. When I am on speaker A only, it works fine. B does not work. A+B works, but only through the A speakers. Now,...
Check for bad solder connections on the speaker switch or where the speaker switch board connects to another board. Not an uncommon problem with some Sony receivers.
Feb 25, 2009 | Sony STR-DE845 Receiver
Sound comes only fron one rear speaker
Did you try switching Speakers A and Speakers B button on the AV receiver?
Jan 10, 2009 | Bose Acoustimass 10 III System
Sony MHC-RV888D Tape Recording to LAPTOP - How to connect?
you have to connect the S-VIDEO output of the device to your laptop via s-video - usb cable , if they do not have a cable like that than you might as well use an adapter from s-video to usb, if u have your hands on one.
the second method is to hook up a audio recorder from the speaker output, and use a volume controller witch steps down the speaker output so you can plug the cable directly to your laptop microfone output..
good luck!
Apr 11, 2017 | Sony MHC-RV888D Shelf System
Sony SRS-D2100 Computer Speakers Logo
75 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
