Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Fault Hey there, I purchased a new top load cabrio about a year ago, and about 3 months later, I started to get a fault during the wash cycle. It will be running fine, then it will shut down, and flash ( F 51 ). It always does it when it gets down to 34 min on the timer. In the begining , it wasnt every load, but now it is everytime. I lost my manual, so if you could let me hear from you, I would appreciate it. Thank You, Brian
  • 4,889 Answers
There is a motor rotor position sensor(RPS) failure.
Refer page 10 of the manual below
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
If you still cant fix it come back here..and ask i will help you out..
And please dont forget to rate if its solved..
Posted on Oct 20, 2007
My new whirlpool cabrio washing machine makes a grinding sound washing cycles. started on first load
Call the people you bought it from and make them bring you a new one. They sold you a lemon. It's not their fault, but don't try fixing it yourself. it was broken when you got it, and they will more than likely try to blame you.
Dec 27, 2014 | Whirlpool 4.6 cu. ft. Cabrio Platinum Top...
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
F1 flashes on my maytag bravo washer
This is an inherent problem with this Whirlpool-made top load washer and at first it is believed to be a machine/motor control fault. But it was found later that it can be due issues associated with the pressure transducer/switch system. Air leaks and moisture in the pressure hose including lints or flashing in the air dome can lead to signal error being sent to the machine/motor control assembly and it is interpreted as a machine/motor control fault. You may also observe that the fault code F1 appears usually during water filling at the start of the wash cycle and/or at the start of the rinse cycles.
Check the pressure hose for air leaks and moisture including the air dome. Replace the machine/motor control assembly if no issue is found with the pressure hose and the air dome. Click on the link below for the troubleshooting and repair instruction details.
Troubleshooting Fault Code F1 on Whirlpool Cabrio, Kenmore Elite Oasis, and Maytag Bravos Top Load Washers
Jun 17, 2011 | Washing Machines
OUR WHIRLPOOL/CABRIO MODEL WTW6600SW2 IS FLASHING F1. WHAT IS PROBLEM?
Lool on this site for F1 fault. Apparently a very known problem, seems with control pcb. I called Whirpool today on a machine purchased in 4/07 with a 4 year extended warrenty from Lowes, and they didn't even question it. Said a repairman would be out to replace part and parts and labor are covered by Whirpool. Call them at their 1800 #, Mention it's the infamous F1 fault, have model and seriel # at rear of top load door ready for the technical help person, and they'll take care of it.
Dec 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Load Fault (LF) during wash cycle after moving washer, never happened before move... what is going on.???
This is not a load fault it is Long Fill fault.
This happens when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Please check the following things
water supply connected and turned on?
hose screens plugged?
water entering the tub? If so check pressure hose connection to machine/motor control.
Thank You
Sep 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6700TW1 that is making a banging noise
The Cabrio unfortunately has many problems. Your problem however is the four suspension rods. If you know someone who is handy it's not that bad to do yourself. Just need a little patience. There are two clips just between the top panel and the front panel. Use a screw driver and a flashlight to see the clips. Then using the screw driver, push in on the clips to lift the entire top panel. This can be difficult. Once open you should be able to see the four rods that support the tub. That's what you need. Hope this helps...
Jan 17, 2010 | Washing Machines
Same F1 Fault Code
The only action you can take is to raise your voice with other people who have faced a same issue with Whirlpool :-
http://www.petitiononline.com/cabrio08/petition.html
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F-1 Error on Whirlpool Cabrio Top load
Called 1-800-253-1301. Spoke to a woman named Valerie in customer service. She told me there was a quality issue associated with the F1 fault code and they would take care of the repair parts and labor at NO CHARGE!. My machine is 28 months old.
Apr 06, 2009 | Whirlpool WTW6400SW Cabrio Washer
Hoover 550 MA Top Loading Washing Machine
if if spins the belt is ok,may have timer fault or timer module ( next to timer) if fitted will be faulty
Mar 24, 2008 | Washing Machines
Smart Drive 703-strange noise during wash cycle
hi there these washing machines don't have any pelts or pulley's. Washer will need new seals and bearings witch is a big job, you wont be able to do it your self as you need special tools to put the bearings back in :)
Aug 22, 2007 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
95 people viewed this question
Dan Webster
Dan Webster
Sal De
