Question about Solis Ultra One Touch Cappuccino & Espresso Coffee Center
Solis Ultra - "Service !!!" message reset
How do you perform a reset to stop this message from appearing ?
Normal machine function is not impaired, but the "Service !!!" message keeps appearing after every product selection and alternates with normal display selection.
The user manual suggests that this can be reset by a service technician (which I am), but how ?
erguel
SOURCE: Solis Pallazzo espresso machine - need maintence manual
Hi, check under: http://www.solis.ch/franzoesisch/kundendienst/kundendienst_f.htm
and choose your machine, under E (english) column, you'll get the pdf.
Posted on Feb 01, 2009
  • 1089 Answers
SOURCE: I have a solis 5000 coffee maker and would like to
Hi
Starbucks used to carry a descaling product for their machines. Yes don't use vinegar because it is only 5% before you dilute it. It also leaves a taste for about 2 weeks that will affect the taste of your coffee. You can use Citric acid. 1 tablespoon per 32 oz of water. Use at least 2 table spoons. Dissolve the descaling solution so there are no crystals left. Now.
Turn the machine off and then push and hold the 2 buttons at the same time. While holding them down, turn the machine on.
Release the buttons and turn the dial counter clockwise till it stops.
This will keep the machine from heating.
If you push the steam button the pump will activate.
Open the steam knob. Run 8 oz through the wand and rekease the button. Let it set for 10 minutes, then open the knob again. Repeat until the tank is empty. Rinse with a whole tank of fresh water and your done.
If you have the Digital there is a program in the menu for descaling. There is also a program for resetting the descal mode so it will tell you the next time it need to be done. Chose yes and push the enter button. Also change your water hardness to 4. Descale more often than not enough.
Posted on Jul 15, 2009
SOURCE: Solis Master pro coffee machine
I hope you found your answer in the meantime. If not, here's a page of manuals from Soli. The Master pro does not seem to be in english, but your problem might be covered in a similar manual. Here's the link:
http://www.solis.ch/kundendienst/kdienst_manuals_body.htm
Collette
Posted on Dec 24, 2009
  • 1089 Answers
SOURCE: service solis master pro
Hi
Contact Quality Coffee Systems in Burnaby, BC qcs@telus.net
Posted on Dec 29, 2009
  • 1796 Answers
SOURCE: Brewed a coffee on my
Hi!!
Make sure the steam knob is closed, if it is open, when the machine gets at brewing temperature, only hot water will be dispensed out of the steam wand. If steam knob is closed:
  • unplug unit's power cord form wall outlet,
  • open the service door and remove the drip tray and grounds container.
  • Use the brew group key that came with the unit to loosen the brew unit, then,
  • remove it and clean under warm running water.
  • Let it dry completely before returning it to the machine.
  • Place brew group on the proper position and use the key to tighten it in place,
  • replace grounds container and drip tray,
  • close service door and plug power cord back on.
Unit should be operative. A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 20, 2010
How can I determine what parts I need to repair my espresso machine and where do I get parts and service?
Solis Master 5000 Espresso Machine - YouTube
? 9:49
www.youtube.com/watch?v=MjBmlQXElag Sep 2, 2010 - Uploaded by Day Tooley
I have been enjoying the Solis Master 5000 for a year. It's time to ... I haven't been able to find an actual user manual online...for some reason.
Nov 03, 2015 | Solis Master 5000 Espresso Machine
Error 5b00
Hello, your error is about the ink absorber.
"Ink absorber full Japan:
[5B00]
Others:
[5B01]
P07 The ink absorber
becomes full.
Replace the ink absorber (ink absorber kit), and
reset the ink absorber counter."
This is the way to enter service mode:
"Start the printer in the service mode.
i. With the machine power turned off, while pressing the Stop/Reset button, press and hold
the ON button. (DO NOT release the buttons).
ii. When the Power LED lights in green, while holding the ON button, release the Stop/Reset
button. (DO NOT release the ON button.)
iii. While holding the ON button, press the Stop/Reset button 5 times, and then release both
the ON and Stop/Reset buttons. (Each time the Stop/Reset button is pressed, the Alarm
and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm
LED.)
iv. When the Power LED lights in green, the machine is ready for the service mode operation
and "0" is displayed on the 7-segment LCD.
2) Start the Service Tool on the connected computer.
i. When a button is clicked in the Service Tool dialog box, that function is performed. During
operation of the selected function, all the Service Tool buttons are dimmed and inactive.
ii When the operation is completed, "A function was finished." is displayed, and another
function can be selected.
iii If a non-supported function is selected, "Error!" is displayed. Click OK in the error message
dialog box to exit the error."
You can use the service tool to reset this error after you have enter service mode.
here is the service tool:
http://www.4shared.com/file/QptYmQTM/ServiceTool_V1074planet.html?
Nov 03, 2013 | Canon PIXMA MP180 All-In-One InkJet...
After cleaning my solis, the machine wont switch back on. i've checked power supply and made sure the service door is closed.
Hi
On Master 5000's there is either a fuse or reset button on the back side of the boiler. The fuse is under a clamp on the side. The reset button is between the 2 black wires (white terminals) on the back of the boiler (front of the boiler is towards the front of the machine). If you machine is 2004 or older then you might have a fuse (they made the switch in 2004).
May 17, 2011 | Solis Master 5000 Espresso Machine
LCD monitor is blank, purple lines flash on/off
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_g_series/powershot_s500#ServiceAndSupport
Issue: How do I reset the camera to its default settings?
Solution: Procedure for resetting the camera to default PowerShot S400, S410, and S500
Resetting the Settings to Default You can reset all of the menu and button operation settings to default except for [Date/Time], [Language], and [Video System].
1. Turn on the camera.
The mode dial can be turned to any setting.
2. Press and hold the <MENU> button for longer than 5 seconds.
menu_button.gif The message  Reset settings to default? appears on the LCD monitor.
default_menu_a70.gif 3. Select [OK] using the left_button.gifand right_button.gifbuttons, then press the <SET> button.
  • The screen below appears while resetting. The normal screen resumes when resetting is complete.
  • To cancel resetting, select [Cancel] instead of [OK].
  • The custom white balance is not cancelled even if settings are reset to default settings.
  • Settings cannot be reset when the camera is connected to a computer, to an optional direct print function compatible printer (CP series) or to a direct print function compatible BJ printer (optional).
Solution: If troubleshooting fails, the PowerShot S500 requires service.
If all troubleshooting steps have failed, then the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Links to the service options that are available for your product are listed below:
Request a Repair Online You can conveniently pre-arrange repair service with a Canon Factory Service Center through Canon's website. Find a Service Location Search to locate a repair service center and obtain further instructions. If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
  • Obtain Support by Email
  • For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 pm. EST, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Friday (excluding holidays) at 1-866-251-3752
  • Technical Support is available for Customers in Canada at 1-800-OK-CANON
We look forward to helping you rectify the issue you are experiencing and are always available to provide any assistance you may need.
Aug 05, 2010 | Canon PowerShot S500 IXUS 500 Digital...
Perform service jeep grand cherokee 2005 this message is appearing in the message center
Actually the newer cherokees are a little more complicated, it's not a reminder for an oil change. It is for an emssions service that should be performed according to the dealer. Here is the rest procedure
Turn ignition to on position, but do not start.
Depress brake pedal fully twice.
depress excellerator very slowly twice
Turn ignition off & that will reset the perform service indicator.
I am mechanic & we are getting frustrated because the dealers do not want to release this info to anyone, they want your money! Can you believe if you did not get them to perform the service they charge you a 1 hour shop rate??
Feb 10, 2010 | 2005 Jeep Grand Cherokee
My glucometer one touch ultra was not turning on, please help
Hi
The most common cause of this is battery failure. First thing you need to do is replace the battery. Its a 3.0V Lithium Battery (#2032 or equivalent).
If the meter does not work after this it will require service repair.
Hope this helps. Please do rate my answer. Thanks.
Sep 02, 2009 | Solis Ultra One Touch Cappuccino &...
EVIC - PERFORM SERVICE MESSAGE
To reset the perform service message , is as follows , turn ignition switch to the ON position , depress and release MENU push button until SERVICE INTV . = is displayed , press and release STEP button to step through available options. the last selected distance option displayed becomes the service interval at which the PERFORM SERVICE message will be displayed . if a new distance interval is selected , RESET SERVICE DISTANCE ? with a yes or no option. when yes is selected the accumulated distance since the last previous PERFORM SERVICE message will be set to zero because the service interval has been changed . when NO is selected , the distance until the next PERFORM SERVICE message is reduced by the accumulated distance since the last previous message . EVIC exits programming mode and returns to its normal operation mode when the C/T button is depressed or when the end of the programmable feature menu list is reached , whichever comes first .
Thanks for asking .
Dec 30, 2008 | 2002 Jeep Grand Cherokee
Grinder not working on my solis master 5000
Order the replacement boiler, (be sure to empty all of the hot water from the boiler first using the hot water function on the right side of your Solis) take your time and open the machine up, the top comes off. There are 3 mounting screws that hold the boiler in place, remove them, be sure to take hold of the boiler before removing the last mounting screw. Remove and replace the wires and 2 water hoses (w/clips). The orange wires the connect to a unique plastic harness are clipped into the harness. Look closely and you'll see a little window in the plastic harness at the end of each orange wire. Use a tooth pick or a pointed device and push the metal clips thru these windows, this unlocks the wires for removal from the boiler.
http://www.shop.partsguru.com/product.sc?categoryId=-1&productId=937
Good luck and Best wishes
Lane
Dec 19, 2008 | Solis Master 5000 Espresso Machine
Solis rapid Steam stuck in descaling cycle
try to run a new descaling to see if it works normal again.
/Mirran
Sep 22, 2008 | Solis Palazzo Espresso Machine
Solis Ultra One Touch Cappuccino & Espresso Coffee Center Logo
378 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
