Question about Sony Cyber-shot DSC-W55 Digital Camera
Scratch disk For the very first time, I get an error message that my scratch disk is full! I dont know what that is! Can you help me? Deb
  • 4,889 Answers
Dont worry its not a problem with your camera..Its just photoshop's way of telling not enough RAM..Read this
http://www.ephotozine.com/article/Photoshop-Scratch-disk-full---what-this-error-message-means-1
Posted on Oct 20, 2007
What does error code 2881 mean?
Error 281 is a disk recognition error, bad disk, scratch on disk or disk contains moisture (dry it)
Try
1.- get out and reload the disk
2.- Clean the disk for Dust / scratch
3.- clean pick up lens (with a soft clooth or a piece cotton
4.- Replace the disk and check if the error message continue.
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Hitachi DZ-MV230A DVD Camcorder
I have a Sega Dreamcast console that I someone gave to me. I was happy because I heard it was a great system in its time. It runs great and most of the games play okay but this one game I put in I am...
There is a video of using a banana to remove scratches from a disk at http://www.metacafe.com/watch/859694/banana_cd_scratch_remover/
also at: http://www.wikihow.com/Fix-a-Scratched-CD wikihow tells you about commercial scratch removers.
sometimes they work sometimes they don't but hey! why not try?
The last resort is to buy another copy
Dec 03, 2010 | Sega Dreamcast Console
I get a can't read disc message with my wii fit
even small scratches can cause disk read errors. Try cleaning it again with a little white spirit using a soft cotton cloth then dry it off with a soft cotton cloth. If it still does not read, a lot of 'game' shops repair scratched disks for about £3.00.
I hope this helps
Jan 17, 2009 | Nintendo Wii Console
New XBox 360 putting scratch in games
the problem is the disc drive.
you have to open it up and put some stick foam " like a sticky strip of foam, insulator : on top of the drive .
the problem is that the disc touches the laser assembly while turning cheating a ring on the disc.
i can fix your games as well as the disc drive if you feel like is to complicated.
Jan 02, 2009 | Microsoft Xbox 360 Console
Scracth disk is full
The Photoshop scratch disk is your hard drive. Photoshop uses your hard drive as temporary "swap" space, or virtual memory, when your system does not have enough RAM to perform an operation. If you only have one hard drive or partition in your computer, then the scratch disk will be the drive where your operating system is installed (the C drive on a Windows system).
You can change the scratch disk location and add multiple scratch disks from Photoshop Preferences. Many power users like to create a dedicated hard drive partition for the Photoshop scratch disk. Although Photoshop will function with a single scratch disk on the system partition, you can improve performance by setting the scratch disk to be the fastest drive in your system. Other useful guidelines for setting scratch disks are to avoid using the same drive where your operating system is installed, avoid using a drive where the files you edit are stored, and don't use network or removable drives for a scratch disk.
If Photoshop is shut down improperly or crashes in the middle of an editing session, this can leave fairly large temporary files behind on your scratch disk. Photoshop's temp files are typically named ~PST####.tmp on Windows and Temp#### on Macintosh, where #### is a series of numbers. These are safe to delete.
If you're getting an error message that the scratch disk is full, it means you need to clear some space on whatever drive is defined as the scratch disk in Photoshop Preferences, or add additional drives for Photoshop to use as scratch space.
Dec 29, 2008 | Adobe Photoshop 7.0 for PC
Scratch & windows error
You must change the location of Photoshop's primary scratch disk to a different HD or other HD partition. You can do this using the Windows Explorer
Oct 28, 2008 | Adobe Photoshop 7.0 for PC
Photoshop's Primary Scratch & Windows primary paging file on the same volume
this is not a hardware error actually photoshop writes temporary files, for which it uses hard drive, its alway a better to have scratch disk other then the drive where its installed, you can change this, by going to edit, preferences, then check plug ins-scratch disk, check your first scratch disk other than c, say the drive which has the maximum space, then select any drive
how do you like the solution please rate it i will appreciate your comments
Missing operating system
missing operating system message usually means that your HDD is pooched, or corrupted
check your bios settings to check that it can still "see your HDD"
if you can hear your hard drive going "click, click, click" when attempting to boot, that is usually a bad sign
to perform setup use orignal recovery setup disk or OS disks of your choice (BOOT from CD) to install OS from scratch.
Sep 30, 2008 | Microsoft Windows XP Professional With...
Game Cube will not read disks. Please help!
you can clean the disks using tap water and then drying with soft cloth have you tried a lense cleaner to clean the laser on the cube get a good brand one not a cheap one also you can buy a disk cleaner that gently takes the scratches out of cds and gets them as new but you will have to shop around to get one but these work on anything cd dvd games the lot so deff worth having one as lots of people throw out dvds cd and games due to the scratches stopping them working but remember the data on a disk isnt on the plastic it is on the layey the other side of plastic the plastic is their to protect the data getting damaged so removing the scratches does not damage the disk if you have scratches this will affect the disk because the laser cant read through the scratch so polishing these scratches out will make the disk as new not many people know you can do this so consider yourself having privalaged info hope this is some help to you but you might have to ask arround for a disk repair so good luck you could even charge people to repair their disks and games this works for anything on a cd style disk.........................................................
Nov 17, 2007 | Nintendo GameCube Console
Sony Cyber-shot  DSC-W55 Digital Camera Logo
54 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
