Unable to open door
Hi: My machine has stopped in the middle of a wash cycle with clothes inside. The instructions don't mention a door release cord. Anybody know where it is or how to open the door? The machine is old, so I will replace it rather than repair it. I just need to get the wet washing out. Many thanks for any help.
  • is1763 May 27, 2009
    Zanussi WDT1085
    I am new to this forum and thought I had posted in a specific category for the model. Obviously not!
    Many thanks.
  • Mike Inman May 11, 2010
    what make and model
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Door stay locked after finished washing hotpoint w/machine ref 9526
See if you notice any water still inside the washing machine, if so run another spin cycle to try and remove it as it will not open if there is still water inside.
If you don't see any water inside, try unplugging it and letting it cool off, the lock should release after this
Jul 03, 2016 | Hotpoint Washing Machines
How do I get the door to open on a whirlpool front load washer? It stopped in the middle of a cycle
remove front panel below the door reach up the right side of the door inside pull on a tear shaped ear connected to the door switch assembly pull down on this it will manually release the door lock
May 12, 2012 | Whirlpool Washing Machines
I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
Mar 08, 2011 | LG WM-2277HW Front Load Washer
Have a machine full of wet clothes on my front load Maytag Neptune Model #MAH5500B. Unable to open door. No power to machine. All outlets and circuit breakers are o.k. Did blow a circuit. we corrected...
Here is a link to some pictures to open the washer. In picture 11, you will see a green plastic line in the middle of the picture. This is the emergency release for the door. If you pull this line the door will open.
Nov 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hi, i have an electrolux eco 7kg froat loader that my son tried to open mid cycle, now the door won't open when the end of the cycle happens and the door clicks (with an orange light) to indicate that the...
Hi, the clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch completely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside during a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Nov 13, 2010 | Electrolux Washing Machines
Unable to open door
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jul 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hi I have a Hotpoint Ultima WT741 1400 Spin washing machine and I am unable to release the door and belive it is broken. I have rewashed the clothes to check that the door lock was not still on and...
There may be an emergency door release tab inside the pump filter access door.....You probably have a faulty interlock which locks the door during operation and is not releasing...Not a big job for a tech.....Nomess
Apr 09, 2010 | Washing Machines
Door locked
THE CAPACITOR IS FAULTY that discharges so door can be opened safely it should be at the rear of mc inside attached to the side of mc make sure u get correct microfarfad replacement
Jan 13, 2010 | Splendide 2100 Vented Washer-Dryer
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
