Question about MSI MS-6734-10 (-6734-010) Motherboard
No sound output
My sound card is active but no sound when a working speaker is connected
  • Dixit Sardana
    Dixit Sardana May 11, 2010
    Have you got the correct drivers installed? Go to control panel and then select Sounds and Audio Devices from the list and check if your sound card is listed as the default playback device over there?
  • 66 Answers
I think ur sound driver is not properly installed . Plz first uninstall the driver and again reinstall driver .
Note :- Whenever u uninstall and install some programme after doing that operation plz restart the machine . After restarting the machine the software will be properly uninstall or install .
Posted on May 26, 2009
2 Suggested Answers
SOURCE: my sound i active but no sound
may be you don't have the correct codecs that support the audio that you are playing. try to get the cole2k codecs at www.downloads.com and install it, it's free
Have a new computer that now has windows 8.1, no sound is coming from speaker, S120 speaker system. Can I download something to resolve this?
Check the following;
  1. Speakers plugged into the correct jack
  2. Speakers receiving power
  3. Speakers Turned On
  4. Sound not turned all the way down in Mixer
  5. Sound Not Muted
Jan 04, 2015 | Computers & Internet
Connected my acer AL 1717 monitor to my computer but unable to activate the sound from monitor speakers?
You have to plug the monitor speakers in. The sound output from your sound card is green, and you connect a small cable between that port and the input on your monitor.
Feb 18, 2011 | Acer AL1717 17" LCD Monitor
I bought a x-530 5.1 and i cant seem to get all the speakers to work
First you have to connect them correctly to your sound card (green=Front, Black=back, orange= central+woofer)
Then set your sound card from it's drivers to 5.1 output.
All 5.1 sound cards should have a 5.1 sound test for each speaker, if not try a mp3 in windows media player.
Remember you have to set 5.1 output in each program to have sound in each speaker.
Feb 14, 2011 | Logitech X-530 Computer Speakers
Trying to connect BA735 speakers to a MacBook? No sound? Are they compatible?
Those speakers were originally supplied with Gateway computer system that had sound cards with digital outputs. While some versions had analog and digital sound inputs, most often the speakers had digital input only. The on-board sound in the eMachines is analog output only, so the speakers are most likely not compatible with your computer. If you want to use those speakers, you will need to locate a PCI sound card with digital output.
It's a matter of the output from the computer's sound card (built-in) being incompatible with the speaker input. The card is sending out analog sound wile the speakers are expecting digital input. Downloading a driver won't help because that doesn't fix the root problem. You need to get speakers designed for analog input, or a sound card with digital output. As it stands now, your computer just can't use those speakers.
Since your using a MacBook there is no option for this Pci Digital Sound Card.
Feb 03, 2011 | Boston Acoustics BA735 Computer Speakers
What connectors do i need to get my pc on to my tv with sound
If your TV has RGB port IN, you need VGA cable to connect VGA from pc to tv. If your pc has sound card with stereo output. Use an active speaker connected to audio output of pc.
Regards,
Jan 26, 2011 | Computers & Internet
I need to install the sounds of my pc but i dont know how to do it .thanks..
Hi, Disconnect all power to your PC. Open up the cover your PC (CPU) and find spare connection on *********** ( beside your VGA / video card). If you see a spare, you can install your card there. If you found cover with screw, remove it accordingly. Place your sound card on female adapter securely.Check if there is output audio wires from your cd rom and connect to your sound card. Close the PC cover. Power on your PC. If you have external active speaker, connect it out to sound card audio output. Now you supposed to can play your PC with sound card.
Dec 05, 2010 | ASUS Computers & Internet
My loud speaker is not working only the earphone can work
Have a look at this article, on some sound cards you can select if one audio output device is active or both. Could explain your problem.
Jun 17, 2010 | HP P5302U#ABA Sound Card
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
Igot REALY old speakers that used to worke perfectly well
The speakers themselves are probably not your problem. Some speakers use the USB connection while others use the Audio output jack of your sound card. The problem is likely with your sound card (assuming you use the Audio output jack). If you rebuilt your computer, chances are you're missing the device driver for your sound card (these are small programs that let your hardware talk to your operating system). You'll need to download the correct device driver for your exact sound card. You probably don't know the sound card make/model. You can download Belarc Advisor (www.belarc.com) which will scan your PC for all hardware and software. Once you have that report, you should be able to go to the sound card manfucturer's website and download the latest device driver. You can always find out if it's the speakers by connecting them to another computer. Good luck.
Aug 13, 2009 | Polk Audio AMR50 Computer Speakers
My speakers are connected but there is no sound output.
it may be either your sound card, or the input of your speakers, you can chage your sound card in the pc (if that doesen't work then it's from the speakers) i don't recommend opening the speakers yourself, and trying a repair unless you have a minimum knowhow of electronics, try an electronics service place.
Jul 07, 2009 | Dell HK395 Computer Speakers
MSI MS-6734-10 (-6734-010) Motherboard Logo
164 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
