Question about Microsoft Xbox 360 Console
Controller port usb pins are bent
The pins in the usb controller port are bent and or broken.Someone forced the controller wire into the port. How can the 2 usbs be replaced?
  • Anonymous Nov 21, 2008
    someone forced the controller in wrong and the usb pins bent and
    the whole black rectangular piece that the controller slides onto broke in half and the power on my 360 won't come on at all
Is it in the warrinty / do they cover it
Posted on Feb 22, 2008
  • 21 Answers
Just call 1800-4my-xbox
Posted on Oct 27, 2007
Can you change the port where the embroidery card attaches on a Brother SE-350?
Hi Marla,
If your machine supports a USB connection to your computer, you may be in luck getting designs to and from your machine. In the meantime, the bent pins may cause issues, but if there a standard
USB cable A to B (printer cable) available you may try that. If I recall there will be some settings to check but that is another way to get designs in and out of the machine.
San Diego, CA
May 21, 2014 | Brother SE350 Mechanical Sewing Machine
Usb port's pins are bent
usb sockets are normally pretty standard but without the make and model I could not be 100% certain.
Jul 29, 2017 | Akai Professional Akai LPK25 Laptop...
Lenovo USB port bent pins
The USB port/socket needs to be replaced it cannot be repaired.
It is not an easy DIY job, you need to take it to an IBM laptop repair center or a laptop repair shop.
Aug 25, 2012 | IBM Lenovo ThinkPad T400 (2767P6U) PC...
WHY MY BIOSTAR G31-M7 TE mother board key board NOT WORKING ANY KEY BOARD?
Lets trace the problem here before we get to the solution. Check the keyboard on another computer to see whether the problem still exists. If the keyboard does not respond then the problem is with the keyboard. But if the keyboard works fine on another computer then the problem might be with the keyboard port of your computer. Now lets get down to the solution. If the keyboard doesnt work on both computers, firstly check the keyboard connecting pin. The pins inside it might have been bent, broken, pushed in or the pins have remained to the keyboard port on your computer. In the case of broken, bent or pushed in pins, REPLACE THE KEYBOARD WITH A NEW ONE. In the case that the pins have remained in the port of your computer, get a Computer Technician to remove the pin. If it can not be removed, then replace the keyboard with the usb one.
Dec 11, 2011 | Computers & Internet
How to fix usb mouse port?
How is it damaged? Physically, i.e,. bent pins, or something broken?
If so, then total replacement of the motherboard is the only solution,
other than using a different USB port.
Or, for a desktop computer, you can add-in a PCI adapter-card, to add more USB ports.
May 22, 2011 | Computers & Internet
Any time I plug anything into any of the usb ports on my Advent roma 4001 my laptop switches itself off. Please help!
If the laptop switches off as soon as you insert the usb cable, there is a problem with either the usb socket or the cable. It is a safety system which stops usb power being re-directed down the usb data lines.
If you have tried multiple cables with the same result then the problem is with the usb socket. try a different socket (a usb hub will help if you are short of spare sockets).
Using a mall light, and maby a magnifying glass, inspect the usb port for bent pins or contacts, some sockets have pins (older dell machines especially) which are not supported at all by plastic backing strip and can be bent easily by inserting the usb plug incorrectly or by children armed with a pen etc.
If you find bent pins (there should be 4 pins evenly spaced or 4 metal strips along a plastic backing peice) remove the battery and attempt to realign the strips with a small screwdriver. switch the laptop on and try a usb plug in the socket - make sure you insert the plug gently and squarely (and the right way round). If the laptop still fails, have another go or ask someone else (who is nimble fingered and technically minded) to try it.
Don't give up (unless you find the socket is broken ie. missing pins) I can guarantee 99% that this is the problem.
good luck
Jan 19, 2011 | Advent Computers & Internet
My broken usb socket
Purchase a PCMCIA USB Adapter. Will fit in the little card slot and add 2 or 4 more USB Ports.
Oct 20, 2009 | Dell Latitude D600 Notebook
Yellow flashing light on dimension 5051
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 20, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Wiring diagramfor w2925
here's a link to emachines' webpage with the user's guide in pdf format to download.
or download it directly here
You must have a PDF reader installed or you can use this snapshot form its Page 19 - PC Desktop Back
The cable from your monitor must connect to the Monitor port (middle and right on picture). Be CAREFULL not to force the connection. The cable only fits one way and you can damage the pins if you force it. If it won't plug in easily, then rotate the plug 180 degrees and try again.
If your connection seems inadequate, you may have bent one of the pins. If you suspect a bent pin, look into the end of the connector on the cable to see if one or more of the gold colored pins are bent. You can straighten the pins yourself with a needle-nosed pliers or a small blade screw driver use gently, otherwise try to get a replacement monitor cable.
Sep 13, 2008 | E-Machines eMachines Desktop PC
Microsoft Xbox 360 Console Logo
926 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
