Question about Iomega 33089 250 GB Hard Drive
Disk is "full or write protected"
I can't delete antyhhing from ym external hard drive, I'e looked in properties to see if something is preventing me doing this and I can't find anything!?!
How can I delete files from the portable drive? The reason I ask si I think 3 of the files have minor viruses....
  • 72 Answers
Download this small program and install:
http://www.scanwith.com/download_soft.php?d=1993&s=746
You can right click on the files and force delete them.
Posted on Jun 17, 2009
Looks as if the disk is full and after logging on it requests me to format the disk and won't let me access in order to delete unwanted files.
Could you please give more details
- Is it an external drive? / USB etc?
- what operating system is your computer?
Have you tried running the disk clean up wizard?
(On windows goto computer then right click the drive then goto properties then tools then click the button disk cleanup)
Dec 02, 2016 | Computers & Internet
Not allowing files to be deleted. "cannot delete
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.?
hope this helps
Aug 29, 2011 | SimpleTech Signature Mini 250GB External...
Not able to copy /delete data from samsung G2 portable hard disk.cannot format also
take a look at the properties..by right click on its icon on my computer ..and see if it is not set to read only ...or right protected...cause this may cause the data not to be able to be changed or formatted ..If on properties the read only is ticked ..just clear the case ..and let it empty ...after that try to format it again in Fat32
Jul 05, 2011 | Samsung G2 Portable External HX-MU032DC/...
It always shows the disk is write protected
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps don
Feb 28, 2011 | Kingston (SDCZ2-512-A10-KT)...
How to remove hard disk write protected ?
this process works on USB drives and on many hard drives
click start control panel administrive tools computer management disc management right click on your drive select properties then security select take full control
also
- Click permissions
hope this helps
don
Feb 21, 2011 | Hitachi Travelstar 5K500.B...
I have a problem with my toshiba external hard drive. the problem is that when i want to delete something from hard drive or want to move to my pc it give the error 0x80070570. can you please tell me any...
More often than not this is caused by a bad sector on the hard disk, and can be fixed following these steps:
First backup the data on that hard disk to another one.
Second, click Start then click Computer.
Third, right click on the external hard drive and select Properties.
Fourth, click on the Tools tab at the top of the window that pops up and run the Error Checking software (button usually says "check now" or something similar) and follow the instructions.
This will hopefully fix any issues you have with that drive and once completed should allow you to delete and move stuff again.
Thanks, if this solution helps please rate :)
Feb 14, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
I cant remove the write protection of my kingston
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Nov 15, 2009 | Kingston Technologies 512MB DataTraveler I...
I can't delete files from my 160 GB Simpletech hard drive and it is full, what should I do?
Do a "disk cleanup"
Click on [My Computer]
Right-click on the External drive (D?)
Select [Properties]
In the [General] tab, click on [Disk Cleanup]
It will "scan" your drive, but not remove anything... alow it to complete the scan.
Look at the recommended list that appears and accept its findings.
This should remove non-essential files and leave your data intact.
Burn some of your data, especially video content to DVD (make at least two copies) ... then remove the data from your external hard drive.
You may want to purchase another (larger) external drive. You can use two of them or move your data to the new one.
Sep 30, 2009 | SimpleTech Signature Mini 160GB External...
Write protected zip disk
you can always try to format and delete all the data, then recover it, recuva can help you recover it, its free from recuva.com. but that would be last resort
Jul 30, 2009 | Iomega (32961) External REV Drive
I keep tryin to safe or delete files but it keeps saying it's write-protected
Dear,
1. Make sure you have full rights to do so.
2. Check the properties of drive or folder if it is write protected then change the properties.
Regards,
Rakesh Kumar
Apr 01, 2009 | Verbatim External, USB 2.0, 750GB...
Iomega 33089 250 GB Hard Drive Logo
264 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
