Question about Singer Tiny Serger TS380
Singer sewing machine model 6012 c
I am going crazy ....  I was sewing a straingt seam and the machine just stopped picking up the top thread , now it won't pick up the bottom thread from the bobbin.  I have changed the needle, refilled the bobbin, rethreaded the machine top and bottom still won't pick up the thread and form a stitch.
HELP PLEASE  !!!!!!!
  • rrabbit Nov 18, 2007
    i have a singer cg-550. i did not know how to sew at all when i got it so a friend set it up and i watched her sew. i used it for a year with no problems, learning as i went. a week ago i was sewing thick, fluffy material and i was "forcing" the fabric through, just a little, and the needle broke. i replaced the needle, quit sewing the fabric, and tried to sew on an old cotton tshirt. the thread from the bobbin was not connecting with the material or the upper thread. and. . . the needle broke again. i made sure i was using the right needle and replaced it, again. i then ran the machine by hand and assessed the problem. the needle was now striking something below the needle plate and the bobbin case. after removing the cover plate and the bobbin case i saw that the needle was striking the circular round-edged "thing" that i think brings the bobbin thread around. it hits only every third pass, or maybe second pass. however, when i turn the wheel (?) on the side away from me, rather than towards me, it does not hit- it just barely grazes the circular round-edged "thing". i think it is the timing something-or-other and i would love to know how to fix it.
  • Mary Ann Conlin May 11, 2010
    I too have a Singer Serger cg 550 and can not pick up the bottom thread. Allmakes, please forward the information to correct the timing. Thank you very much. My e-mail address is carib3242@aol.com.
SOURCE: Bobbin won't p/u thread Singer 478
i have no idea how to thread this machine ?
Posted on Aug 16, 2008
Mongo32
  • 111 Answers
SOURCE: Machine will not pick up the bobbin thread.
if your machine's needle threads from front to back, make sure that the flat part of the needle shank points to the rear of the machine. If it threads from left to right, the flat side should face right, etc.
Posted on Jun 11, 2009
Mongo32
  • 111 Answers
SOURCE: singer sewing machine, needle will not pick up bobbin thread?
needle in backwards?
Posted on Aug 23, 2009
miket756
  • 2702 Answers
SOURCE: NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Posted on Oct 24, 2009
Testimonial: "Thanks! I was hoping to avoid paying for a fix, but it looks like I have to **** it up. So much for being thrifty and restyling my clothes."
  • 1788 Answers
SOURCE: I have an old singer sewing machine 401A. The top
You can download a manual for $10 at www.sewingmanuals.com and it should help you. A couple of suggestions though, is your needle inserted correctly? Flat side facing the rear of the machine, fresh needle? Threaded correctly on top and bobbin area? Is your thread good not too old and the same type in bobbin and top? Did you leave a long enough tail in the bobbin thread? 3-4 inches which you hold with your left hand. Is the thread in the bobbin unwinding the right way? Are you turning the handwheel towards you, not away from you at least two revolutions or until you see the thread loop? Try these suggestions, and I am sure one will work unless your timing is off and it needs professional service.
Posted on Sep 20, 2010
I just received a new Singer CG-590. Have threaded the machine and bobbin. Each time I try to pick up the bobbin thread, the top thread wraps around the bobbin case. It will not pick up the bobbin...
try turning the bobbin the opposite way, and if that doesn't help then take the machine back and get another one, maybe even a different model
Dec 26, 2013 | Singer Sewing Machines
I had to remove the bobbin to add more thread...I put the bobbin back in the hole, now i don't know what the do to get the bobbin thread hooked...its a singer 6012 C
try the threading diagrams at www.sewusa.com your model is not listed but the basics should be very similar. Link is
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_4538_threading_diagram.htm
It is so useful to have a manual for a machine, and there are several websites including singer where you can buy manuals for various models; well worth the $10 or so to obtain one.
there is also lots of general sewing machine info at www.sewing.about.com or u-tube videos could help too.
Mar 06, 2011 | Singer Sewing Machines
Tension is too tight on my sewing machine,,need to know the settings to go with which seam. singer 724 graduate
Hi. As a rule of thumb, once the tension is balanced on your machine, it shouldn't need adjusting. It's not something you adjust for each different type of seam or fabric (again, rule of thumb!). (Certain kinds of sewing, like free motion embroidery or when you use rayon thread, require particular tension adjustments, but for ordinary sewing, you shouldn't have to mess with the tension that often.
If the top tension is too tight, your top thread will be loose and basically just sitting on top of the fabric. You need to loosen it up so that the bobbin thread can pull the top thread down into the fabric.
Let me know if this helps, ok? I'm going to post a tip on adjusting tension so please check that out.
Happy Sewing!
Robbie
Mar 10, 2010 | Singer Sewing Machines
Jun 08, 2009 | Singer 2639
Unable to sew straight stictch with singer futura ce 100
When I had this experience I cleaned the thread path under the plastic cover. There was a piece of thread caught between the disks.
Aug 09, 2008 | Singer CE-200 Quantum Futura Computerized...
hi
i want to know how i put thread in the sewing machine
thank you
Dec 15, 2007 | Sewing Machines
Sewing Machines Logo
139 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
