FixYa.com
Tags:
Hotpoint RGB745 Gas Kitchen Range
Bake part of kenmore not working seems to take to... (by 3 users)
posted by kenskaw on Oct 20, 2007
I have a kenmore gas oven the bake part of the oven seems to take a long time to preheat . I'm not sure how long the oven is suppose to take to reach 350 but it seems that it is taking forever. I just installed a new regulator and the broil seems to work fine, when I turn on the broil the temperature starts 100 and goes slow to 150 which takes about 6mins. and then I get a gas smell so I turn it off because i'm not sure of how long it's suppose to take to preheat and to reach 350
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by feetcme, posted on May 19, 2008
My JennAir double oven takes forever to preheat itself. I'm wondering if the electrician connected it properly.
Comment by Bomp, posted on Nov 16, 2007
I just moved into a home with a Kenmore oven (using propane.) The first time I tried to bake anything, it took forever for the oven to preheat and it never did fully warm up -- however, the house filled with propane smell. I called the propane company and they replaced the ignition. After they left, I tried it...and discovered that it now took a shorter time to go from preheat to bake and the oven does now achieve temperature, however, during the preheat phase the propane smell is so bad I have to open the window. Once it achieves temperature, the smell dissipates. I called the propane company again and they said that there is nothing wrong with the oven and that particular model "just does that." However, everyone else says I should never smell propane -- and especially not that strong for that long a time.
Please help!
Best Solution
posted on Oct 20, 2007
FixYa! (100)
fridgetech
Rank:Guru Guru
Rating: 88%, 719 votes
Chances are the oven ignitor will need to be replaced.  Look and see if it glows.  If it does then it is weak and not opening the gas valve to lite.  Let me know what you find.
Comment by fridgetech, posted on Oct 20, 2007
Should be able to remove the bottom drawer and unplug the ignitor from below.  Or you can cut the wires on the old ignitor and splice the new one in using ceramic
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Kitchen Ranges problems?
HOtpoint Electric stove/oven
we just bought a used (BUT IN... Answer This...
UNEVEN HEAT IN OVEN
how do i adjust temp in oven?? Answer This...
hotpoint oven
My hotpoint oven turns on, but... Answer This...
Oven Ignites, But Will Not...
I have no problem with the... Answer This...
Need a 24 inch freestanding
Need a 24 inch freestanding gas... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
