Question about HP LaserJet 1010 Printer
One page jammed after switching off when 1 page printed. Orange light on
Switched off hp laserjet 1010 printer as only wanted one page printed. Seems to have second page partly stuck in machine with orange light flashing. Press green light & get 2 steady yellow & 1 steady orange light for less than 10 secs. No message appears on computer screen. What do I do? Have tried switching off and on but no change.
  • 66 Answers
Hi ,
First off all u switched off the printer and on switch off mode press the green button and on pressing the button switch on the printer hold that button for 5 seconds and then release the button whenever u realese the button the printer start migrating . After migrating if the printer have same problem then u reinstall the printer driver and again reinstall the driver, after reinstalling the driver the printer will working fine .
Posted on May 26, 2009
All the lights are on in hp laserjet 1010 printer i cannot print any page how to solve this problem
Try a hard reset of printer and/or reinstall the software, Check cartridges for ink and operation.
Sep 04, 2016 | HP LaserJet 1010 Printer
HP LaserJet 4L quit working It's connected to my PC and it's on. All 4 lights are on; 2 green and 2 orange. When I try to print, the paper goes through but nothing is printed on the paper.
Empty cartridge maybe?
Otherwise it's simple: selt-test page(by printer button) printed ok - it's outer problem. Self-page is blank - it's inner problem. And so on... use Golden Section method
Jan 10, 2014 | HP LaserJet 4L Printer
PC communicates with my HP laserjet 1020 but paper does not seem to pull through and wont print and orange fault light flashes then stays on
nothibg to warry about it just check tonner if its ok then do the servicing and also see for the paper jam chek may be ther e inside paper was jamed yeterday
Jun 07, 2012 | HP LaserJet 1020 Printer
LOCATION OF PRINTER SENSOR
Jams
Clearing jams
CAUTION Do not use sharp objects, such as tweezers or needle nose pliers, to remove jams.
Damage caused by sharp objects will not be covered by the warranty.
CAUTION Always pull jammed media in the direction it would travel through the paper path.
Do not pull jammed media against the direction of travel through the paper path to avoid damage
to the printer.
To prevent damage to the printer when clearing jams, including jams in the output bin, always open the
print-cartridge door and remove the print cartridge. Keep the door open and the cartridge out until the
jam has been cleared. Opening the print-cartridge door and removing the print cartridge relieves tension
on the printer rollers, which prevents damage to the printer and makes the removal of jammed pages
easier.
Occasionally, media becomes jammed during a print job. You are notified of a media jam by an error
from the software and the printer control panel lights. See Control-panel lights (HP LaserJet 1010 series
printers) on page 102 or Control-panel lights (HP LaserJet 1020 printer) on page 106.
The following are some of the causes of media jams:
The input trays are loaded improperly or are too full. See Loading media on page 25.
NOTE When you add new media, always remove all of the media from the input tray and
straighten the stack of new media. This helps prevent multiple sheets of media from feeding
through the printer at one time, reducing media jams.
The media does not meet HP specifications. See Media specifications on page 21.
Typical media jam locations
Print cartridge area: See Removing a jammed page on page 43.
Input tray area: If the page is still sticking out of the input tray, gently try to remove it from the input
tray without tearing the page. If you feel resistance, see Removing a jammed page on page 43.
Output path: If the page is sticking out of the output bin, see Removing a jammed page
NOTE There might be loose toner in the printer after a media jam. This toner clears up after
a few sheets are printed.
Use the procedures in this section to remove a jam.
CAUTION Media jams might result in loose toner on the page. If you get any toner on your
clothes, wash them in cold water. Hot water will permanently set the toner into the fabric.
Partshere Troubleshooting
CAUTION To prevent damage to the printer when clearing jams, including jams in the output
bin, always open the print cartridge door and remove the print cartridge.
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print
cartridge with a sheet of paper.
NOTE The following illustrations show the HP LaserJet 1020 printer. The same procedure is
used to remove a jam in the HP LaserJet 1010 series printers.
Open the print cartridge door, and remove the print cartridge.
Grasp the middle edge of the side of the media that is most visible, and carefully pull it free from
the printer.
jams. Damage caused by sharp objects will not be covered by the warranty.
Do not forcefully pull jammed media against the direction of travel through the paper path to
avoid damage to the printer.
When you have removed the jammed media, replace the print cartridge, and close the print cartridge
door.
After clearing a media jam, you might need to turn the printer off then on again.
NOTE When you add new media, remove all of the media from the input tray and straighten
Sep 25, 2011 | HP LaserJet 1020 Printer
Printer not used for 5 months. Now connected to a new PC but I get all light switched on. How can I be shure it's in good working order?
You probably want to print a test page.
To print a test page with this printer:
Hold down the Go button (green button) for 5 seconds. You'll see an orange light flash, let go of the green button and a Self Test/Configuration page will print.
Read more: http://wiki.answers.com/Q/How_to_Print_configuration_page_for_hp_laserjet_2015dn#ixzz1HJWm1vUf
If the test page comes out ok, the printer is in working order. You just need to get a driver at http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1845561&lang=en&cc=us&prodTypeId=18972&prodSeriesId=1845551&taskId=135
Mar 22, 2011 | HP LaserJet P2015 Printer
I have an HP laserjet 1010. i got the paper jam
If you are getting correct test page without errors, simply unplug your printer's USB Connection from PC. uninstall Printer drivers and software. restart PC.. Re-Install New Copy of Drivers and Software.. THEN PLUG THE PRINTER USB CABLE TO PC.. try printing after proper driver is installed..
May 30, 2010 | HP LaserJet 1010 Printer
It does not print
my printer hp 1010 was printing fine and suddenly stop print pages.it take in page and through it out as blank page.
Jul 02, 2009 | HP LaserJet 1010 Printer
My have hp lase printer 1010 driver
im kosova drvers hp laserjet 1010 pleas
Feb 17, 2009 | HP LaserJet 1010 Printer
Laserjet 1010
Hp 1010 printer driver downlod free
Aug 20, 2008 | HP LaserJet 1010 Printer
Laserjet 1010
where do I download a free driver ofHP LaserJet 1010 Printer
Dec 23, 2007 | HP LaserJet 1010 Printer
HP LaserJet 1010 Printer Logo
430 people viewed this question
Seeker5211
Seeker5211
