Question about Panasonic Lands Phones
Phone ringing after hang up a few second
After finish a call and hang up the phone , the ring will be ring after a few second
  • 77 Answers
You may have unopened voice messages waiting to be answered. If you have never set up voice message service you may need to contact your phone service provider & have them disable the service they sometimes give you as a default. Contact them anyway they will know what to do.
Posted on May 26, 2009
How to increase the no. of rings on my LG tracfone
  • Press *#61# on the phone's keypad and press "Send."
  • Write down the phone number that is displayed, because it may be different than your cellphone number. This screen should also display the number of seconds your phone is set to ring before going to voicemail. Press "Cancel" to return to the main screen.
  • Press *61 followed by +1 and the 10-digit number from the previous step. Do not press "Send" yet.
  • Press 11 followed by the number of seconds you want the phone to ring, such as 20 for a 20-second ring time.
  • Press # to finish the sequence and press "Send." Your settings should now be changed. You can dial *#61# and press "Send" to check the settings.
Jun 17, 2016 | LG Cell Phones
My phone won't ring
If you are using Android phone you need to make sure that the ring-tone volume is not muted. Just goto setting and sound and then increase all the volume, sometime even if the phone is not in silent mode it won't ring due to Android sound settings . You can also use the volume rocker key to increase the ring tone volume. Just in case also change the ring-tone as well in case if the ring tone file is corrupt. Now try ringing your phone from another phone and see if that works. If it still doesn't work, just turn off your phone and take the battery out for 10 seconds and put it back. Try ringing it again. If nothing works, there might be problem with your built in speakers. And you need to contact the manufacturer.
It would be better if you could tell your phone make, model and mobile operating system name and version, to help you further.
Cheers!
Dec 27, 2013 | T-Mobile Concord
My phone won't stop ringing when someone calls. it has a steady ring and it rings after you hang up. the caller id won't pickup who is calling. how do i fix it?
Try to reset the telephone base by unplugging the unit's electrical power. Wait for 15 seconds and plug it back in again. Allow up to one minute for the handset and the telephone base to synchronize.
Apr 01, 2011 | Vtech CS5121 Cordless Phone
My H700 Motorola Bluetooth does not go to pairing mode by steadily lit in purple, even after turning off the phone it is currently paired with and after I close and reopen the H700 Motorola Bluetooth ...
First off, you want to have the H700 fully charged up and it's probably good to have the phone fully charged up too. Now turn off the H700 (the ring around the talk button should not be flashing blue every few seconds) then push the talk button for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the phone to finish the process
May 11, 2010 | Cell Phones
Hello.. We have the parter-18D phone system. one of the phone rings when there is an incoming call, but it shouldn't, since this is not the main phone Ext 10. How can I program this phone to ring only...
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
May 06, 2010 | Lucent PARTNER18 Corded Phone
Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Dec 12, 2009 | Uniden Cordless Phone
How do I change the number of rings on my Panasonic KT-TGA110EX (S) cordless?
Press MENU button. Scroll down until you see Initial Setting. Press SELECT. You will see Set Answering. Press SELECT. There, you will see Ring Count. Press SELECT. Press the number of rings you want using your keypad, then press SAVE. Just press OFF when you are finished, just like you are hanging up the phone. That should solve your problem!! :)
Aug 20, 2009 | Panasonic Lands Phones
Whenever I receive long sms, my phone goes off and say"insert sim" and says sim rejected.The phone hanged, I can restart by switching off the phone.Again within few minutes the same sms come in and phone...
I too have the same problem.
It is easy to solve :)
Its all bcoz of ur phone memory.
If u store more msgs,pic msgs,ring tones It will switch off automatically...
Jus clean up ur mobile by free up memory
Dec 30, 2008 | Nokia 1100
ANSWERING A CALL AND NON FUNCTIONING ANSWERING SYSTEM
no make or model listed
on many phones there is an ability that when the phone is picked up it is automatically connected to the caller and pressing the answer button is the same as hanging up
as for you second point , if a caller rings but hangs up before the message beep or after the beep but hangs up , there will be no message recorded
Nov 15, 2017 | General Electric 29115AE1 1.9 GHz 1-Line...
Samsung Prostar 816
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
it sounds like the memory battery on the main board is no longer working which means that it'll happen again.
Aug 30, 2008 | Samsung Prostar 816 Phone
Lands Phones Logo
126 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
