Question about Kenmore 44042 Front Load Washer
No spin cycle.
Pump is working, but machine will not do final spin cycle.  Will wash the clothes tumbling.  Help
  • 24 Answers
I'll preface this by saying that I know this is going to sound stupid...
I had the same problem with my Kenmore front load. It would slowly toss the clothes clockwise then counter-clockwise when it was supposed to be spinning.
This started about 2 years ago and after a couple of months, the washer was about worthless as the isolated non-spin became the rule...
So, I did what anyone who wasn't going to stick money in a 5 year old washer would do, I tore it apart to see if I could find anything... cleaned up some parts and put it back together... nothing.
So, I figured there had to be a problem with either the motor or the speed control... something wasn't clicking. Since the motor seemed to work at other speeds, I concentrated on the speed control.
I took off the bottom access panel and looked in there... looking at the front of the washer, the metal box that houses it is located on the right, about 2 ft from the front of the machine.
Well, I took a piece of wood and tapped the box a couple times...
I then tried a spin cycle, and it didn't seem to do anything... so I tried pushing the metal box around a bit more, figuring that it could be a lose connection or something... and tried the spin cycle again...
This time it spun.
I ran about 3 loads of landry and it worked twice and didn't once, so I tried moving it a bit more (yes, with the machine off) with the piece of wood...
It's been about 20 months since I did this, and I will have the no-spin problem maybe once every two or three months. I haven't had to take the access panel off since early 2007, as it seems to be a very sporadic problem that I will reset the machine directly on spin and it will be fine.
Like I said, I know it sounds stupid... there has to be a bad connection or ground in there somewhere that moving the speed control around a bit would help... but it's kept the wash clean and has kept the wife from getting her new anodized washer that she eyeballs on each trip to Lowes... and hasn't cost me a dime.
Hope this helps.
Posted on Jun 20, 2008
    Problem Solver:
  • 4 Answers
My washer is doing the same thing. Washes fine, water drains fine but it will not do a high speed spin. I have had both front and back covers off to watch what is going on and the motor is not running at all during the spin cycle. Period. No belts slipping. I replaced the drain pump since I found some coins in it. That did not solve the problem. I replaced the control board since that had been suggested. No help. Ka ching. Ouch. I will replace the door switch and if that doesn't work I will bring in the experts to isolate the problem since it is electrical and will need diagnostics run. It is just over 2 years old and having all sorts of problems. I will not buy another Kenmore (made by Frigidaire) washer.
Posted on Nov 21, 2007
  • 4,889 Answers
Do you hear if motor is running (an humming noise) ?if you can then It sounds like a badly worn belt that slid on the tub (the washer succeed to spin- depending on clothes weight in tub) . Open the rear panel, check for belt status and if it really worn,replace it with a genuine belt from the manufacturer.
Be aware you should disconnected power cable from the machine before starting work on it.
Come back if you need more help...
Posted on Oct 20, 2007
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
I am having issues with my washing machine. At it's final spin it seems to be off balance and makes loud noises
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Aug 05, 2010 | Frigidaire Washing Machines
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Frigidaire Tumble Action washer won't complete the final spin. leaves clothes soaking wet.
Had the same problem and fixed with ease. The problem is with the door lock. There is a secondary locking mechanism that kicks in for the final spin due to the high speed. When the secondary lock goes bad the washer will not do the final spin. The replacement part is under $40 @ .
Dec 08, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front load pumps out water, DOESN'T SPIN, but DOES "tumble"
The pressure switch or pressure switch tube could be blocked tricking the machine that it still has water in it therefore not advancing into 'spin mode'.
Or the electronic card could be faulty and require replacing.
Jun 17, 2009 | Frigidaire GLTR1670A Front Load Washer
Ca230 w. machine not spinning leaving clothe wet, no water in drm
It is possible that the belt at the back of the machine is slipping. try running the spin cycle without any load in the machine. I assume this is a front loading machine and you are in UK. the Belt is available on line for about 15 pounds.
If it is running the washing cycles normally, it can't be the motor.
Dec 06, 2017 | GE S8000E
No spin cycle.
better chance that its the door latch assy, id change that befoer the timer
Jan 21, 2009 | Frigidaire FWTR445R
Kenmore 44042 Front Load Washer Logo
164 people viewed this question
Sal De
 Brian Main
Brian Main
