Pantum M7102DW error code 11 typically indicates a problem with the laser scanner in the printer. The laser scanner is responsible for reading the image or text to be printed and transferring it to the printer drum.
Error code 11 can be caused by a variety of issues, such as a malfunctioning laser scanner, a problem with the printer's internal components, or a problem with the printer driver. To troubleshoot this error, you can try the following steps:
Turn off the printer and unplug it from the power outlet. Wait a few minutes, then plug it back in and turn it on.
Check the printer driver to ensure it is up to date and compatible with the printer.
Check the printer for any visible damage or debris that may be causing the error.
If the problem persists, it is recommended to contact the manufacturer or an authorized service center for further assistance.
The cartridge installation error is displayed on the Canon PC-D320 printer when the cartridges are not installed properly. Glance through the steps below to resolve the issue.
1) Power up the printer and remove the ink cartridge from the printer.
2) Shut off the printer and disconnect the power cord from the power source.
3) Reconnect the power cord to the printer and power source after a few seconds.
4) Load the ink cartridges into the printer again and wait until the initialization completes.
5 )If the error code appears again, repeat the above steps.
6) If you have installed the cartridges properly but are unable to print, the printer will display an error code.
7) Open the front cover on the printer and wait until the print head moves to the left.
8) shut off the printer and disconnect it from the power source.
9) Remove the ink cartridge by pressing the clips on the sides.
10) Remove the felt pads in the platen waste ink absorber under the ink cartridge holder.
11) Rinse the pads and dry them using paper towels. Reinstall the pads. Check if the issue is resolved.
12) If the printer displays error E4, replace the ink cartridges.
13) Reset the print system if the issue persists.
For more printer related assistance get in touch with our experts by just giving a call @ 1-866-293-9220.
I am trying to print via wi-fi direct, and it gives me: SPL ERROR -Please use the proper driver POSITION 0x0 SYSTEM h6fwasim/x1_image LINE 398 VERSION SPL 5.73.04 06-10-2014 ERROR CODE 11-1113
If an error caused the printing to end abnormally or a malfunction occurred in the printer, then an error message code (***-***) is displayed.
If an error code not described in the following tables is displayed, or the problem persists even after you have tried the following solutions, contact the Customer Support Center.
Tip
If an error code is displayed, all print data of the printer as well as print data stored in the built-in memory of the machine is discarded.
Error Code: 127-212 Error Category: Print; Other Problems Cause: Detected an internal print check error by the FreeFlow Print Services Controller. Remedy: Remove and reinsert the command/video cable between the FreeFlow Print Services Controller and the printer. Power off and on both the printer and the FreeFlow Print Services Controller. If the problem persists, call the Customer Support Center.
*** extracted from my Fuji Xerox Color 560 Printer - Printing Systems User Guide
The error code indicates a communications problem between the display and the electronics. Reseat the connectors on the display and the connection to the electronics. If that does not solve the problem, replace parts in this order until the problem is solved: display and display cable, electroncis module, logic board.
Hi, I tried looking up your error code 131B and could not find it anywhere, but from Epson troubleshooting page for this printer there should be an error message on the display panel. Check out this link for the messages: http://files.support.epson.com/htmldocs/pro38_/pro38_ug/trble_1.htm#S-00700-00100-00100-00200
I would replace that print cartridge, even if you just bought one just to make sure you dont have a bad cartridge, but do a cleaning of the nozzles first. Let me know how it went.
