Question about Compaq Presario 700 470024-192 Notebook
Mismatch typing and when pressing function key its ok but its too problem so pls how can i fix my keyboard according to typing rules, when i press 'j' it becomes 1
  • Rajesh Maharjan
    Rajesh Maharjan May 26, 2009
    THANKS A LOT FOR YOUR SOLUTION, IT'S VERY SIMPLE, BUT UNKNOWN IT THE BIG PROBLEM ANY WAY THANKS A LOT.
    MY PROBLEM IS ABSOLUTELY SOLVED.
    THANKS AGAIN
  • 696 Answers
You need to turn off the Number Lock. Usually there is a picture of a one "1" with a light near it, it will be the same colour as both the Fn Key and the "1" on the J key. Press the Fn button and hold it down while pressing the Num Lk Key and the light will go out, then your letter will be back.
This is a feature built into your laptop allowing you to have a numeric pad on a small keyboard. Must have been turned on accidentally but is just as easy to turn off.
Chris
Posted on May 26, 2009
  • Chris
    Chris May 26, 2009
    Your welcome,
    Simple for us Geeks, sure. But ask me to bake a sufle and I'll give you a blank stare...
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    How to open unlock mouse pad
    Click the Windows "Start" button in the bottom-left corner of your desktop.
    Scroll up and click "Control Panel."
    Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
    Click the "Enter" button and then click the "Mouse" link.
    Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
    If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
    If you are under the touch pad tab, click the enable button.
    Click the "Apply" button and then click the "OK" button
    or
    Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
    Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
    Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
    Shortcut Key Method
    Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
    Use your arrow keys to locate the Control Panel and press "Enter."
    Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
    Then, press "Alt-F" together to access the tabs at the top of this box.
    Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
    Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
    hope this helps
    Sep 22, 2012 | Computers & Internet
    Function key for Rupee symbol in lenovo keyboard?
    Maybe you have to Press and Hold the FN function key at the lower left portion of the keyboard then hit key 4 to get the rupee. Or it might be Press and Hold the ALT or CTRL key then hit key 4 to get it.
    The key to know which key to Press and Hold is notice the color of the rupee symbol on key 4, then Press and Hold either the FN function key, Alt key or Ctrl that is the same color as the rupee.
    May 07, 2012 | Lenovo ThinkCentre Computers & Internet
    I pressed some keys on the computer and now when I use the computer keyboard when I type o I get the number 6 and when I time i Iget the number 5. what did I do I am using a different keyboard as I type...
    Hi Carol,
    It seems that the function key (Fn) on the bottom left of the keyboard is stuck or jam. Try hitting the key multiple times or raise it with your fingers. Then try to press I and O again. Below the is image of the key you need to press and clear the jam from. You can also pat the keyboard/ laptop from at the bottom in case the jam wont clear by pressing the key.
    Fig 1 : The function key
    Fig 2 : The the shown below have multiple icon, those are activated by pressing Fn (function key)
    Regards,
    Shrey
    Jun 04, 2011 | Acer NSK8458AN Keyboard
    I type j and it comes out 1. can't fix.
    Try this.
    Press the Start key + R.
    type osk in that box and hit enter
    On this keyboard, try toggling numlock scrolllock and capslock a few times. does it help?
    I think your numlock might be stuck on and your keyboard "num lock" key isnt working
    Jan 04, 2011 | Computers & Internet
    Locked keyboard buttons
    You need to find the special function key that, when used with the Fn key, locks the Fn function on. On my keyboard it's the F11 key.
    Press the Fn key and that key and your keyboard will return to normal.
    Apr 20, 2009 | HP DC170B Keyboard
    Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
    NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
    Mar 22, 2009 | HP 2133 Notebook PC
    When ever i press certain symbel keys its wierd
    You may have activated a shortcut key on your keyboard such as the Fn (function) key. It looks like this
    Fn and usually situated on the bottom left hand side of your keyboard near the left hand cntrl button.
    Some function keys when pressed once remain on. Once they are on they can cause different symbols to appear in place of the normal keyboard ones. If you press your Fn key again and then try typing on the keyboard once again it may help fix your problem.
    I hope this helps
    Cheers
    john
    Nov 16, 2008 | Compaq Keyboard
    Keyboard stuck in upper case
    press caps lock and F9 together see if that fixes it
    May 06, 2008 | Microsoft Windows XP Home Edition
    Compaq Presario 700 470024-192 Notebook Logo
    137 people viewed this question
    Top Compaq Computers & Internet Experts
    Abhinandan  Patil
    Abhinandan Patil
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
