Question about Electrolux Washing Machines
E21 is flashing on the screen what does this mean?
The screen is flashing E21 and i have lost the manual what does it mean and is there a manual i can download for this washing machine? Thanks Ursula
  • 3 Answers
E21 indicates that water is not draining from the machine fast enough. This can be caused by a kink in the drain hose, a problem with the pump or a problem with the pressure sensor.
On my washer, there's a copy of the service manual inside the machine - remove two screws in the back and take off the top. The manual includes the error codes and the steps to take.
Posted on Nov 18, 2009
    Problem Solver:
  • 10 Answers
I had the code E21 error (not draining) on my 2012 Electrolux EWFLS70JTS0, which I'm guessing is similar to a Frigidaire Front Load Washer. After reading about the potential causes being related to drain or pump obstructions, I decided to try forcing compressed air into the drain hose at the rear of the washer to see if I could push out whatever got into the system. So I moved the washing machine out from the wall, and pulled the drain hose out from its wall inlet. No disassembly required. Then I placed the trigger air nozzle from my compressor into the drain hose that's connected to the back of the machine, and held it in place with my hand so that most of the air pressure would go up the hose and into the machine.
Once I pulled the trigger to start the air flow it only took a few seconds to see bubbles appearing in the washer's tub. At that point it seemed any obstruction was now pushed out (where it went, I'm not sure. Somewhere in the standing water in tub I suspect).
I suppose it would be just as effective to use a garden hose with water (if you don't have an air compressor), but a little more messy. Anyway, as soon as I put it in "quick wash" mode (which starts with a drain cycle), it drained fine. 100% problem solved! No more error code. And no repair bill!. I just hope that whatever was restricting the drain flow does not find its way back into the system again. It's been a couple of days and so far, so good.
Posted on Sep 29, 2013
E21 error is showing on my electrolux EWF14811 washing machine. What does this mean and how do I clear it?
E21 means a problem with the water draining.
Could be defective: drain pump, pressure switch, wiring, current leak between heating element and ground and finally main board.
Also could be drain filter or drain tube (kinked or clogged) and leaks from water circuit on pressure switch.
Dado
Sep 13, 2014 | Electrolux Washing Machines
What does error code mean e21
Manual says E21 is 'Off Line'. Not much to go on there but I am guessing that is probably referring to something that is plugged into the serial ports on the side - perhaps it is looking for an external kitchen printer of something along those lines.
Jul 09, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
Why is my logik washing machine showing e21
Find the error code reference in your owners manual or check on the companies web site to determine the meaning of the error code and then try to fix .
Jun 29, 2014 | Frigidaire ATF6000ES Front Load Washer
What does electrolux stove induction error code E21 mean?
Did u ever find out.mine is doing the same.ive searched everywhere and can't find an answer
Jun 23, 2014 | LG range & stove induction cooktops...
E21 code on Bosch Dischwasher...what does it mean
E21 Circulating pump blockage
This would be caused by a blockage or a poor water flow from the main motor of the dishwasher. This can be caused by a capacitor failure or for other reasons.
Dec 08, 2013 | Kenmore HE2 Plus Front Load Washer
I lost the manual, what does "LF" mean when it is
From my manual, it means:
Washer is taking too long to fill.
Check the following:
Are the hot and cold faucets turned on?
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press POWER/CANCEL to clear display
Dec 05, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Treadmill not working. Troubleshooting: Receiving E21 message. What does E21 indicate?
The E21 error code indicates that the console is not receiving a signal from the sensor that controls the speed on the treadmill. This means there could be a problem with the speed sensor. You may need to have a technician check the voltages on the power board and controller.
Nov 27, 2010 | HEALTHRIDER Exercise & Fitness
Green light flashing on blackberry pearl
This just means that the phone has coverage. under options and then screen/keyboard, you cna turn it off by where it says LED coverage indicator.
Apr 10, 2009 | RIM BlackBerry Pearl 8100
Error #e21
Having had it for half a year - how come no warranty? If you acquired it through regular means and still have purchase documentation then back to the retailer it goes. The problems you mention are definite - firm ware errors and seller/manufacturer responsibility. Suggest you also contact Support on Kodak website to discuss the problem - you do no have to discuss source if that is an embarrassment.
Aug 10, 2007 | Kodak EasyShare DX7630 Digital Camera
Washing Machines Logo
1,546 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
