Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Will not print annymore
Our printer just prints blank pages, we put in nnew cartridges and cleaned the heads lots of times but it still prints blank pages, somebody says we need to empty a resevoir ? how do we do this or is there another reason it prints blank pages ? thanks for any help.
    Problem Solver:
  • 8 Answers
Hi Thomas,
Some possible causes can be:
1. Not removing the plastic covering on the new cartridge before replacing the old one. This is an obvious thing, but I've come across instances where this was plain forgotten, so check this and see.
2. Check the Printer settings in Windows Printers Panel and try changing the print quality to Normal or Best and see if that makes a difference.
3. Re-install the drivers for the printer, they can get corrupted sometimes and don't work the way they should.
Let us know if any of the above worked for you and don't forget to rate my answer.
Best regards,
Quirino Cardozo
Posted on May 26, 2009
    Problem Solver:
  • 6 Answers
Thomas You need to get yourself a pint bottle or even two pints of ink solvent and a syringe and spray it into the print heads where you removed the ink cartridges and let it set about two hours. don't be conservative with the solvent. Please read the manual for your printer and after you run the printer through several cycles you will see the differences put the old cartridges in the trash and install new cartridges. this can be prevented if you run the printer through its self test and run clean print head cycles.
NOTE: put paper towels in the bottom of the printer so as to not make to big a mess
  • 24 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
asd-21
Posted on Sep 03, 2009
Printer will not print pages. Blank paper comes shooting out
clean heads and align clean cartridges,next time use original dell cartridges no refills or over filled ones
Apr 24, 2015 | Dell Photo 926 All-in-One Printer
There are no signs of error but the paper comes out blank
Hi Zanda
if you haven't used your printer for that long, your printhead is more than likely dried up and clogged. Try running the "Head cleaning" utility 2-3 then print a "Nozzle check" (find both of these functions on "Maintenance" page under "Printer properties".
If the nozzle check shows any print, you're on the right track. Run few more head cleans or try printing several pages (with LOT of colour) on high (best photo) quality. Combination of printing & nozzle checks works best. Be prepared to waste lot of ink doing this!
If you get no print at all, it's probably time to get a new printer. There are other things you can try eg. buy set of cleaning cartridges, try to clean the printhead by placing some folded tissue soaked with Windex under the printhead or forcing some Windex through the printhead pickup (using a syringe & rubber tubing fitted over the pickup needle - where the cartridge usually sits) etc.
Another way yet is to remove the printhead from printer and soak it in cleaning solution (if if you're handy and prepared to pull your printer apart).
good luck!
Lumir
www.inkbank.com.au
REFILLABLE CARTRIDGES
Mar 02, 2014 | Epson Stylus RX425 Multifunction...
All the pages I print are blank. There is sufficient ink the print preview shows the image but the actual print out is blank
Sounds like your print heads are clogged. This is quite common. Go into your printer's menu and find the maintenance menu and follow the steps to clean your print heads. Run the process everal times until the prints are 100%. Then run a printhead alignment. Regardless of whether your not your ink is full, if cleaning the heads several times does not solve the issue, put new ink cartridges in because you may have bad cartridges. If that doesn't work, you've got bigger issues, contact the manufacturer.
Apr 26, 2011 | Office Equipment & Supplies
No ink on printed pages
Try to pull out the ink cartridges. Then after 1 minute put the cartridges on. Then it will initiate head cleaning. Just perform the head cleaning to clean clogged nozzles. Then try to print a test page.
May 10, 2010 | Brother MFC 490cw Color Inkjet...
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
Printer prints blank pages. computer screen shows ink in cartridges
screen shows ink but many of the times if the cartridges are dried up it will print blank pages.clean the cartridge head clogging manually and then try.otherwise replace the cartridges.
Dec 07, 2008 | Lexmark Inkjet Z517 Photo Printer
Printer will not print ,paper comes out blank
Put new in cartridges in printer.
Page prints out blank.
Have cleaned the print heads 3 times.
Need help!
Nov 16, 2008 | Epson Stylus C66 Inkjet Printer
Hp 3820 printer cannot print
there are a few steps to take.... try a few head print head cleanings ... then attempt to print a test page ...next clean the catridge contacts as this fixes lots of problems ... just follow the instructions on the hp support site .... a big problem with underused inkjet type printers is the print heads dry out over time... you can rejuvinate a dry print head by removing it and setting it on a moistend papertowel overnight ... use distilled or spring water... you could also simply replace the colour cartridge
Mar 29, 2008 | Office Equipment & Supplies
Prints blank pages only
Try brand new genuine cartridges, if that does not work, it is your printer's print heads. Canon has these built into the printer as opposed to having them built into each new cartridge. Sometimes cleaning the heads a few times does not do much at all. On some occassions I have cleaned the print heads over 20 times and have succeeded eventually in getting it to print. Good luck.
Sep 06, 2007 | Canon BubbleJet i560 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
156 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
