Question about Dryers
Heating problem/dryer heating element goes on when started for 10 seconds aprox than a click & it goes off ,everything else works but that which worked fine this morning just stoped now.
  • troy268 Dec 11, 2007
    Dryer worked fine in morning then last night heard a bang. It was loaded up pretty good, it spins and runs indefinately but no heat is coming out. The vent outlets are clear.
Replace igniter coils
Posted on Mar 20, 2008
  • 94 Answers
Make sure your exhaust vent is completely cleared.
Posted on Oct 21, 2007
HE5 dryer has no heat - everything else appears to work, tube spins , controls can be set, start. But no heat. Purchased new in early 2008, may be used 2 times / week.
Several reasons this could be. There is a separate fuse for the heating element inside the unit...find it and check it. Second...The element works on a 220v system whereas the spinning and lights work on regular 110. Check the 30 amp breaker in the house. Third, the element is bad and needs to be replaced. There are only 3 or 4 major parts to a dryer. There are easy to repair if you take the time to get the repair manual and study it.
Jan 22, 2011 | Kenmore HE5 Electric Dryer
My beko tumble dryer drcs68w does not heat up, i have taken the back off and checked all the connections between the heater and the control panel,if i do a reset by holding the cancell button for aprox ten...
its a trip switch, if its tripping then there is a fault with the element, it is either clogged up or shorting out when it heats up. i would think it needs replacing. becareful with dryers as there have been a lot of beco products over the years.
May 30, 2017 | Dryers
I have a frigidaire clothes dryer, model number FSEC747GES1. it turns on but does not get hot, just cold air. wondering if it is the heating element and if so what part number it is, aprox. the cost and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Dryers
Dryer working but no heat
if its a gas dryer check the spark ignitor
it should click as you first start in within 20 seconds upon starting it with the heat mode switched on
Mar 11, 2010 | Dryers
Electric dryer won't heat
The problem is most likely one of the thermal limit switches/thermostats which is bad -- there could be several of them. Or, it is less likely that it is the heating element or a loose/corroded/broken connection to the heating circuit.
I would call for service -- it would be less expensive than a new dryer.
Apr 21, 2009 | Dryers
Dryer gets to hot
Start with the vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
If the vent is ok, turn the timer to any on position without starting it. Wait 10-20 seconds and then check if there's heat inside the dryer.
If yes, the element has a short and therefore always stays on. Replace it.
If no, run the dryer for a few minutes and listen for the clicking of the relay which cycles the element.
If there is no clicking sound, check the hi limit thermostat & thermal cutoff for continuity and replace if necessary.
If those seem ok, it could be the motor (centrifugal switch inside) or the timer (shorted contact).
If not
Feb 21, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore dryer takes to long to dry
You may have to get inside the exhaust assembly ...somtimes there are lint buildups that occur and cause long drying times. Also make sure you don't have a DUAL heating element model. I had one and only one of the elements worked when I repaired the second one it worked great. Most likely is the exhaust block however. Hope this helps.
Jan 18, 2009 | Kenmore 659 Electric Dryer
Dryer tripping electricity saftey switch
You probably have a shorted heating element.
May 15, 2007 | Miele T1322C Electric Dryer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
74 people viewed this question
Top Dryers Experts
Marvin
Marvin
