Question about Toshiba Tecra A3 Notebook
While booting in Dos it appears- alert: system protection failure! Password=.
Alert: system protection failure
When I start my Laptop I, the screen comes with a message, "ALERT: System protection failure! Password =
You may try to insert the original operating system disc and fixing the boot process. Some computers do not offer an operating disc, thus you may have to use the Restore function. When booting, hit the F8 key and start up in the safe mode. Search for the Restore function and go from there. The problem is you did not state what version of Windows your using and it is difficult to navigate without that information.
Dec 18, 2013 | Toshiba Computers & Internet
Toshiba tecra a8 "ALERT: System protection failure! Password = "
Type the correct password and it will un protect the device.
Nov 02, 2013 | Toshiba Tecra A8-EZ8311 Notebook
  1. HELP ME toshiba laptop satellite A120 system protection failure password =,
PASSWORD I DON'T NO (SUBROTO.BOSU@GMAIL.COM)
Aug 20, 2010 | Toshiba Tecra A8-EZ8311 Notebook
Locked Laptop
This is from a factory repair and maintenance manual for Acer Aspire Laptops. It may work for you.
Forgotten Hard Disk Password
When the user keys in the wrong password three times, an error message appears. The user must now reset
the password.
1. Make a note of the error code that is displayed with the error message.
2. Run unlock6.exe from the DOS prompt in the following format:
unlock6 XXXXX 00
(XXXXX = HDD password error code, 00 = CRC base - default is 00)
3. Select Upper case ACSII Code from the screen that appears. The HDD master password is displayed.
Make a note of this password.
4. Reset your system. When the Enter Primary Master HDD User Password prompt appears, enter the
password you made a note of in step 3.
Resetting a BIOS Password
The user can reset a BIOS password using the clnpwd.exe utiility.
1. Copy clnpwd.exe to a DOS boot up disk (or flash drive).
2. Boot your system in DOS mode.
3. Execute clnpwd.exe from the boot up disk (or flash drive).
4. Press 1 or 2 to reset the required password as shown on screen.
5. A confirmation message appears when the process is successful.
May 24, 2010 | Acer Aspire 5315-2713 Notebook
Forget windowxp password
you can search for a password boot disk which will disable the administrator password.
There are dozens of these types of programs but one program I recommend is windows password reset 6.0
http://www.resetwindowspassword.com
Download the iso file and burn it to a disk to create the boot disk, that simple.
Configure your pc or laptop to boot in the cd drive,
Insert the CD and it would boot then just disable the password and restart.
Took about 5 minutes for the whole process.
Jun 08, 2009 | Dell Dimension 2400 PC Desktop
On boot up it displays and asks for a password on Laptop
1. At the BIOS password prompt ("PASSWORD = "), press and release the following keys, one after another:
Ctrl, Tab, Ctrl, Enter
The computer's response should be:
PC Serial No.= XXXXXXXXX
Challenge Code= XXXXX XXXXX XXXXX XXXXX XXXXX
Response Code=
2. Get response code from your local toshiba support center
Then follow the instructions the support guy will give you to unlock the laptop
Jan 15, 2009 | Toshiba Satellite R25-S3503 Tablet PC
Toshiba Tecra A8 EZ8512 Bios problem
Good day to you.
I have a toshiba Laptop with Bios Password problem. I cannot start my system anymore, cos the laptop is requesting for Bios password which I dont know or have.
Oct 25, 2008 | Toshiba Tecra A8-EZ8311 Notebook
Toshiba Tecra A3 Notebook Logo
700 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
