Question about HP Office Equipment & Supplies
Printer not printing
When i send documents to print, the printer just blinks for a moment but doesnt print anything.
  • 52 Answers
There's seem to be a communication problem between the computer and printer.
First try changing your usb cable with a new one.
Posted on May 26, 2009
Zebra 105SL The printer was printing labels just fine on Friday. Monday morning it won't print anything. I send a document to it for printing and it just sits there doing nothing. Everything is connected...
Go to "Printers and Faxes" or "Devices and Printers" and try printing a test page by right clicking on the icon and choosing printer properties. This will better define if the problem is something wrong with the printer or connection OR if it is a software issue.
Oct 11, 2010 | Zebra 105SL Thermal Label Printer
How to print 11 X 17 documents using a Kyocere CS 2550 printer
Use this method:
[File]
[Print]
Select the printer from the list and click on [Properties]
Change the "Original siae" to "11x17"
Change the Output size from "Same..." to "8.5x11" or "8.5x14"
[OK]
[OK]
Sep 29, 2009 | Kyocera CS-2550 Black and White Copier
My printer is not printing any document and when i check whats printing it says its deleting another document
click on start
goto control panel
select printer and faxes
double click on printer icon
and delete all the que printing jobs
Jun 18, 2009 | Dell 926 All-In-One InkJet Printer
Wont Print
try to go under control Panel - Administrative Tools - Services, then scroll down to Print Spooler and stop the service, then restart it. Try to print now.
good luck
Mar 31, 2009 | HP Officejet J5780 All-In-One Printer
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
It Just Wont Print
Have you tried installing the HP Print Diagnostic Utility?
This utility fixes some of the basic issues with the printer /computer.
Download/Install and follow the onscreen instructions to run the utility and restart the computer when prompted.
I hope this tool resolves your issue.
gud luck.
Oct 26, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printing pictures
Download the Print Diagnostic Utility from this HP site (click on "click here to download the Print Diagnostic Utility" on this HP document, then install it and follow the directions on the page.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01072463&dlc=en&product=3194498
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Aug 23, 2008 | HP Photosmart C6280 Printer
42 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
