Question about Software Shelf International Promodag Enterprise Server (m32647)
Unexpeted close promodag.
I have a big problem. I have installed Promodag 8.5 into W2k3 Sp2 server. When I run promodag I recive this error and the application close. Event Id:1000 Category:none Source:.Net Runtime Error Reporting Description: Faulting application repex.exe, version 8.5.0.0, stamp 493ffa35, faulting module olmapi32.dll, version 12.0.6423.1000, stamp 49b08045, debug? 0, fault address 0x0004c488. Data 0000: 41 00 70 00 70 00 6c 00 A.p.p.l. 0008: 69 00 63 00 61 00 74 00 i.c.a.t. 0010: 69 00 6f 00 6e 00 20 00 i.o.n. . 0018: 46 00 61 00 69 00 6c 00 F.a.i.l. 0020: 75 00 72 00 65 00 20 00 u.r.e. . 0028: 20 00 72 00 65 00 70 00 .r.e.p. 0030: 65 00 78 00 2e 00 65 00 e.x...e. 0038: 78 00 65 00 20 00 38 00 x.e. .8. 0040: 2e 00 35 00 2e 00 30 00 ..5...0. 0048: 2e 00 30 00 20 00 34 00 ..0. .4. 0050: 39 00 33 00 66 00 66 00 9.3.f.f. 0058: 61 00 33 00 35 00 20 00 a.3.5. . 0060: 69 00 6e 00 20 00 6f 00 i.n. .o. 0068: 6c 00 6d 00 61 00 70 00 l.m.a.p. 0070: 69 00 33 00 32 00 2e 00 i.3.2... 0078: 64 00 6c 00 6c 00 20 00 d.l.l. . 0080: 31 00 32 00 2e 00 30 00 1.2...0. 0088: 2e 00 36 00 34 00 32 00 ..6.4.2. 0090: 33 00 2e 00 31 00 30 00 3...1.0. 0098: 30 00 30 00 20 00 34 00 0.0. .4. 00a0: 39 00 62 00 30 00 38 00 9.b.0.8. 00a8: 30 00 34 00 35 00 20 00 0.4.5. . 00b0: 66 00 44 00 65 00 62 00 f.D.e.b. 00b8: 75 00 67 00 20 00 30 00 u.g. .0. 00c0: 20 00 61 00 74 00 20 00 .a.t. . 00c8: 6f 00 66 00 66 00 73 00 o.f.f.s. 00d0: 65 00 74 00 20 00 30 00 e.t. .0. 00d8: 30 00 30 00 34 00 63 00 0.0.4.c. 00e0: 34 00 38 00 38 00 0d 00 4.8.8... 00e8: 0a 00 ..
Olmapi32.dll is one of the MAPI components installed with Outlook 2007. I think that your current configuration file contains one of the following conditions: account impersonation in the Exchange Connection tab of Tools > Options, and/or a hidden mailbox to establish that connection to the Exchange system. That could work with Outlook 2003, but not with Outlook 2007 or 2010.
Can you follow these steps:
  1. Locate the Repex.pri file, that you should find in the %SYSTEM%\ProgramData\Promodag\Reports\8\ directory.
  2. Edit it using NotePad.
  3. Delete the following values (xxxx in red):
    • MAPIServer = xxxx
    • MAPIMailbox = xxxx
    • MAPIUseNTSpecific = x
    • MAPINTAccount = xxxx
    • MAPINTPassword = xxxx
    • MAPIUserName = xxxx
  4. Save the Repex.pri file.
  5. Start PROMODAG Reports.
  6. Go to Tools > Options and open the Exchange Connection tab.
  7. Enter your connection settings (user account and mailbox) and make sure that the following conditions are met:
    • The user account is a member of the local Administrators group.
    • The user account is a member of the Exchange View-Only Administrators group.
    • The user account is associated to a mailbox and you select that mailbox (Outlook 2007 MAPI client libraries do NOT support impersonation).
    • The mailbox is not hidden in the Global Address List (Outlook MAPI client libraries would make the application crash).
I believe this should be sufficient to solve the problem.
Best regards,
Pierrick Lussan
PROMODAG
Posted on Nov 15, 2010
It's posible to install windows 2003 server on hp 2210b
Change SATA Native mode in BIOS & use W2K3 Ent Edn with Sp1
Sep 12, 2011 | HP Compaq ProLiant ML370 G3 Server
Hard drive not detected. When i trying to install Win 2003 Server Std edition. It does not detect the hard drive.
you will need to download the RAID drivers from the Dell website
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R74082&SystemID=PWE_PNT_P3C_2450&os=WNT5&osl=en&deviceid=1374&devlib=0&typecnt=5&vercnt=7&formatcnt=2&fileid=126163 and load them onto a floppy drive.
Then when installing the server press F6 to install other drivers this will load the PEC drivers and W2k3 will then see your drives
Do not try to load the drivers from a USB as W2k3 is "preset" to only accept drivers from a floppy drive unlike WIndows server 2008
Hope this helps
Jul 22, 2010 | Dell PowerEdge 2650 Server
The program encountered an unexpeted erro flield
re install the windows xp home edition and see if it works
Oct 21, 2009 | Microsoft Windows Xp Home Edition Sp2...
I keep getting error code 0x80080005 when trying to download service pack pack 2 on vista and error code 80080005 when trying to run windows update. can you help?
you can download it from softpedia or dozens of places if you google it download it els where and install it that way i see alot of users have this issue i would also make sure your time date and time zone are correct if you still cant install it from the end user installer . *****http://www.softpedia.com/progDownload/Windows-Vista-Service-Pack-2-Download-112640.html here is the link i would try *****right click your my computer go to properties and find out if you have 64bit windows if so you need to download the x64 version if not x86 is for you food luck
Sep 20, 2009 | Computers & Internet
I need a Dell PE6300 Server Assistant CD
Good news, Dell has lifetime phone support for their servers.
Write down the Express Service Code and Service Tag number that is on the server chassis and call Dell.
This is the last number I used for server support: (800) 945-3355
If it doesn't work you should be able to find a valid number at support.dell.com
I hope this helps.
May 27, 2009 | Dell PowerEdge 6300 Server
Proliant 5500, installed configuration and OS w2k3 all operationa
What controller do you have? Have you tried running smart start that came with the system?
May 14, 2009 | Compaq ProLiant 5500 Server
Sync my contacts and calendar from outlook to iphone
You are on the right track.
You need to install the SBS 2003 SP2 package.
It contains Windows Server 2003 SP2 and Exchange 2003 SP2 along with other important updates. (It is a big download.)
Install all of the updates staring with Windows Server SP2.
Once you complete the install of Exchange SP2 your iPhone should sync.
FYI: If you use Remote Web Workplace you will need to forward TCP port 4125 on your firewall to your SBS server after this update or RWW won't work properly.
I hope this helps.
Oct 14, 2008 | Apple iPhone Smartphone
Power light flash
check the firmware you are upgrading to is supported for the hardware model yoiu are using.
Jul 25, 2008 | Dell PowerEdge 2450 Server
Server doesnt boot
First create a floppy disk with your RAID driver for W2K3 Server. Next boot the server with the W2K3 Server CD, and hit F6 when prompted, and S to add the specific driver for your RAID and using the floppy to get the driver installed.
Next boot to the recovery console of W2K3 Server. If it finds your hard disk, it will even ask for your Administrator's Password to continue. If this works, then you are probably home free.
Get to the command line of the W2K3 Server Repair console and perform some directory searches to see if the data is there and intact. You can also perform a CHKDSK from that console.
Once you have made sure your data is there and intact, type these two commands: FIXMBR and FIXBOOT
This should solve the problem and when you EXIT out of the console, it should reboot. Remove the CD and it "should" re-boot from the hard disk.
If you still have problems, let me know with how far you got with the steps above. I have another solution but need to know your RAID controller's model (ServeRAID 5i, 6i, etc).
-Chip
Apr 02, 2008 | IBM xSeries 346 Server
Computers & Internet Logo
384 people viewed this question
Top Software Shelf International Computers & Internet Experts
David Payne
David Payne
Are you a Software Shelf International Computer and Internet Expert? Answer questions, earn points and help others
