Question about HP PSC 2175 All-In-One InkJet Printer
Printer won't print yellow
My Hp PSC 2175 printer will print, but it is now printing my photos in weird color schemes. I did the self-test- and under the section that is supposed to be "Cyan" is aqua blue. Under "Magenta" it's bright pink. Under "Yellow", there is nothing. Under "Violet" it is Navy Blue. Under "Green" it is royal blue. And under "Red" it's bright pink. The color cartridge is relatively new.
  • 52 Answers
Either theyellow is finished or the nozzles are blocked. Try cleaningthe nozzles of the cartridge.
Posted on May 26, 2009
Hp psc 2175 printer prints, but doesn't print anything on envelopes. help!
printer show remove and check color cartridge and we already did it
Apr 25, 2010 | HP PSC 2175 All-In-One InkJet Printer
My 2175 All-In-One printer will not print a document from my computer. The LED readout says "1 Copy / 100%". The push-button "copy" icon is lit up. It will print a "Self-Test Report" OK. I have...
Check to make sure that when you give the print command that the HP 2175 is the printer the document is aimed for...not XPS or some other printer on your system.
good luck
Feb 22, 2010 | HP PSC 2175 All-In-One InkJet Printer
Hp psc 2175 printer prints black fine and also yellow and blue color, but nothing prints in red. I have used both a refilled and a new (remanufactured) cartridge with same results. How can I get the red...
The hole he is referring to is probably the nozzle. Most of the HP all-in one's have this feature under the maintenance tab. Open control panel->Double click printers->Right-click on the HP PSC-> Click properties. Then click on the maintenance tab and click on the nozzle check option and insert a paper into the document feeder. The printer will check the nozzles and print different colors and patterns on the printer. Check to see if the printer is printing red and then post back on this thread with your results.
Sai.
Jan 21, 2010 | HP PSC 2175 All-In-One InkJet Printer
No red
the color red is a mix of two color. so run the cleaning tool on the printer
Dec 12, 2009 | HP PSC 2175 All-In-One InkJet Printer
Page Counter?
If the printer was reset recently then you will not et the entire or exact page count till day, but you can still run a Print self test report and check for the information:
To Run:
  1. On the front panel of the product, press Menu (or Setup) .
  2. Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK .
  3. Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK .
It will print a self test page and you will find the page count in thie page
Good Luck
Sep 24, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP psc 2175 skips when "copy"
replace the black print cartridge. I guess that the text is B&W. Pictures are printed in color - from the color ink cartridge.
Mar 20, 2008 | HP PSC 2175 All-In-One InkJet Printer
Color problem
clean the unit and if not functioning the unit .!
Mar 08, 2008 | HP PSC 2175 All-In-One InkJet Printer
Printing problem - all red
try doing alligning the catridges , or else that u r catridges are leaking while printing.
Nov 02, 2007 | HP PSC 2175 All-In-One InkJet Printer
Slow Printing
Hi, The slow printing issue can occure even if the cartridges are out or low in ink try to check the print function by the stand alone unit by printing a self test page Here are the steps to print a self test page: On the front panel of the product, press Menu (or Setup) . Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK . Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK . If the self test page takes less time to print and if all the color blocks and black block print fine the ink level are fine. if the time for self test is also more try to clean the cartridge contacts and replace the cartridges if needed this will fix the issue. If the printer works fine as stand alone self test and copy try to performe the steps in the below webpage: ========== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00093466&lc=en&cc=us&dlc=en&product=2512010&rule=10185&lang=en ========== If the issue is still un fixed try to set the print directly settings in the printer properties Click on start >> control panel >> printer and faxes >> there look for the HP printer icon with the check mark and right click on it and select properties and then click on advance tab and under it select the print directly to printer and click on apply and ok to save the settings. Once done try to print and check with the issue. Hope this will fix the issue. Regards, Barret.
Sep 03, 2007 | HP PSC 2175 All-In-One InkJet Printer
Printer issue
I can only suggest that you should use genuine HP ink carts. Try all new carts and realign again. Hopefully it is under warranty. HP is good at exchanging.
Aug 02, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
235 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
