Question about HP Compaq Presario F750US
Laptop screen shows balck & white grids only- no images nx 6110
I have a nx 6110 laptop. The screen of the laptop has suddenly stopped display. It only shows black & white grids. There is no problem in the boot though.
Can someone suggest a remedy.
  • vishal_sriva May 26, 2009
    The problem is from start of the laptop- when I say booting- I guess it is booting from the sound it makes when the system is up and running.
  • Quirino Cardozo
    Quirino Cardozo May 11, 2010
    Vishal, what do you mean when you say no problem in boot? Does it boot the POST section and then start giving problems? Please describe in a little more detail to assist in solving your problem.
    Scholar:
  • 62 Answers
I have had this same problem with a HP DV2000 and the problem is not the contrast light. What it is, is that the laptop thinks that the screen is been shut down that is why the light does not come on. The best way to solve this is to remove your keyboard first.
You can remove the keyboard by removing exactly 7 screws from your laptop back, there are 5 screws located under your battery and other two that are in the location of your RAM'S.
Just open them up and then you will notice that the key board pops out abit then just simply take it up and then just below the keyboard, on the same line where HP brand logo is on your machine there are two small clip types of pind, that you can remove and put back.
There is a clip that is hidden abit under the metal plate, so just try and remove that clip from its place using a needle or any long and thin object.
That will make the laptop not have the problem. But once you remove that the laptop constantly will think that the screen is open even if you close it. then after like a week or two you can put it back and all shall be fine if not then just remove it and keep it out.
You can then set your power options to shut down the screen light every 2 minutes or something like that so as to avoid the backlight being switched on all the time.
Hope this solves your problem.
Posted on May 26, 2009
When i power on the laptop nx 6110 it brings a white screen on the LCD.
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
1-laptop-white-screen.jpg Here's an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning. In my case it was a Toshiba Satellite M45 laptop but this problem may occur with any other brand.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
3-video-cable.jpg I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
These laptop service manuals and disassembly instructions may be useful.
4-reconnect-video-cable.jpg I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard.
5-disconnect-lcd-screen.jpg The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video.
6-test-with-another-lcd-screen.jpg For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen.
7-white-lcd.jpg After I assembled everything back together and connected the original LCD, it's still white.
CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced.
May 09, 2011 | Compaq NX6110 TFT XGA Notebook
Hp nx 6110 was working fine but suddenly it went off and now it does not boot
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Feb 08, 2011 | HP Compaq nx6110 PC Laptop
Laptop Monitor shows balck and white stripes
From what i can barely see it your photo it looks like your video chip  (which is part of the motherboard's chipset) has died. It will be expensive to replace the motherboard.
To recover all your data is easy - just remove the hard disk from the laptop, put it in a case like one of these
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010010092%201053807124%201054107131&name=SATA
then connect the case to another pc.
Mar 26, 2010 | Toshiba Satellite A105-S4084 Notebook
Screen suddenly goes white with toshiba l505d
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. Another suggestion is run your Toshiba l505d driver DVD for installing Display drivers. When finish restart your laptop and watch whats going. If no success then format the Operating system & reinstall again.
Thanks & waiting for your feedback.
Feb 09, 2010 | Computers & Internet
I need to unlock my compaq nx 6110 hp. (laptop) black and white screen before it boots up says password loacked
need to reset bios password. download a bios password eraser, or see if there is a reset under one of the panels on bottom of pc. usually not but i have seen them. you can pull the onboard battery for a day but usually cant get to it. best bet is check who makes your bios and get a bootable cracker
Dec 01, 2009 | HP Compaq nx6110 PC Laptop
Display on but back light not on HP nx 6110
This could be an issue with the inverter problem. Are you using a universal adapter? If so, this could be the possible reason why the inverter died. It is not supplying the correct input for the inverter, thus the damage.
Please consider to bring this to an authorized HP service center. If its still under warranty, the better.
Aug 12, 2009 | HP Compaq nx6110 PC Laptop
Compaq NX6110 BLANK SCREEN!!
Does the screen come on when computer posts and then go blank?
If so then try strting it in safe mode (F8)
Have seen this happen on a friends machine though it worked now and again until laptop was moved slighty. I dismanteled it and it turned out the motherbaord had liquid damage and was corroded :(
Sound like the onboard graphics is faulty...sorry not good news :(
Dec 26, 2007 | HP Compaq nx6110 PC Laptop
My compaq laptop freezes after 30 minutes
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. Have you expierenced that problem also? There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
Nov 27, 2007 | HP Compaq nx6110 PC Laptop
HP NX 6110 Laptop problem
IT'S A CHIPSET PROBLEM - faulty connection resolved (or better-patched) with pressure on it: see here and good luck ! http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447626+1260029524885+28353475&threadId=1096080
Nov 19, 2007 | Computers & Internet
HP Compaq Presario F750US Logo
135 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
