do a system retore before the last update, should solve the issue
SOURCE: snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
SOURCE: Office 07 won't work on Vista
been there, have you tried getting it out from safe mode, if that dosen't work there is a utility called unlocker, here
http://ccollomb.free.fr/unlocker/
Iuse it when things like that happen, it will unlock it. But try safe mode first
