Question about Kenmore 22422 Top Load Washer
Washing Machine Leaked but seems ok now.
My neighbours asked to borrow my washing machine as their's had broken down, but as mine was filling up, it started leaking at the front. I tried using it once after and it leaked slightly, but it now seems to be working fine. Could it be that they just overfilled it, or could something else be causing an intermittent problem? It's five years old and I probably use it twice a week.
  • lynncwilliam May 26, 2009
    Sorry, for some reason it automatically put the washer as a top loader. It's not, it's a Front loading Whirlpool AWG338-3.
  • 15,935 Answers
Likely it was overfilled - and caused an unbalanced load that may have shifted the tub - allowing the gasket to leak.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
My front load washing machine agitate but won't spin
If your machine is rather old or used quite frequently, you should check out the motor brushes. Go to youtube for details on washing machines brushes.
Mar 06, 2015 | Washing Machines
My kenmore elite quiet pak9 washer is flooding on the inside with water. I used a bucket to empty the washer but the next morning, it started filling up again. what do i do?
I just had mine fixed. It was a small hole in a water line inside the machine. Mine only leaked heavily when under pressure.
Feb 17, 2015 | Kenmore Washing Machines
My Servis M3001 washing machine will not fast spin , it will spin and the belt seems to be ok , the machine is filling and draining ok , can you help at allThank you
Some times on front loaders if it is out of balance it will not go into fast spin. Try to remove some of the cloths and see if this helps.
Best of luck
'RR
May 15, 2014 | Washing Machines
Hi there I have a haier hwmp50f washing machine.
check theres nothing stuck in the pump,, its quite a common thing
Sep 10, 2013 | Washing Machines
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
No power in whirlpool washing machine
hi mine did somthing similar not sure what the part is called but it looks like a silver battery thing about 4 inches long about 2 inches around with a few wires comming out of it mine blew this and the house fuse couldent miss mine as it was black changed this and it was ok hope this helps ivan
Sep 25, 2012 | Whirlpool Washing Machines
Water when filling has slowed down cold water is very slow hot is ok
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 26, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Hotpoint WT761 washing machine - Error code F-10 The machine is filling with water, then signalling F-10, then pumping the water out. So the fill solenoid and the pump are working OK. If I set the machine...
Thats strange, F10 means no cold fill.
Ok back to basics, you can check the pressure switch by taking off the tube and gently blowing into it and I mean gently, you should hear a click if its ok - make sure the other end is'nt blocked, blow it out with a cycle pump near the drum end
Sep 19, 2009 | Washing Machines
Kenmore 22422 Top Load Washer Logo
69 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
