Iomega 2 tb ego dead
This is an external HDD, right ? In such case it's good to realise, such devices are a combination of an external USB enclosure and an internal SATA Harddisk. Maybe the harddisk is still OK, but the PCB (print with all tiny electronic components soldered at it) is defective. In such case you can overcome your problem by simply buying a new USB enclosure (even non-name will do) and put your harddisk in it.
To check if the harddisk is damaged, you should remove this by opening the Iomega casing and connect this disc inside a PC to it's motherboard. If the harddisc is working again, you're lucky. If not, than even the harddisk is damaged. If this is, and the data at your disc is important, you can try to source a identical harddisk (brand, type and productiondate) and transplant it's PCB. But, I can asure you, this last option is a tricky step.
