Question about Canon PIXMA iP90 Mobile Printer
Flashing 4 orange lights
When I turn on my IP90 it flashes 4 orange lights. What does this mean
    Problem Solver:
  • 11 Answers
The power light flashing orange four times consecutively means that one, or both, of the inktanks is/are installed incorrectly. Follow the steps below to resolve the issue.
  1. Check to make sure that the ink tanks are locked into position (you might remove and reinstall them just to make sure).
  2. Turn the printer off with the power button, unplug the data cable (most likely usb) and the power cable and let it sit for at least 10 minutes (this resets all of the sensors that may be causing the problem). Then plug in the power cable and data cable and turn the printer back on.
  3. If that doesn't fix it then it means that it is a hardware issue and that your printer is in need of repair, at least that's what canon will tell you but now days it's usually cheaper just to buy a new printer and you don't have to go to the trouble of finding a repair center and taking it there and waiting days to get it back.
I hope this helped
Posted on May 26, 2009
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Cannon Pixma ip90 printer mechanical failure code 5100. Printer works for about 2 inches then stops with failure code 5100
The error 5100 actually means nothing. You need to look at the printers green and orange lights. they will be flashing in a certain sequence. Count the way the lamps flash ie.Green are mechanical faults and orange are operator correctable faults. When you have the info repost and i will help you further.
Jul 27, 2011 | Canon Office Equipment & Supplies
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Mar 05, 2011 | Olympus Camedia C-50 Zoom Digital Camera
My canon ip90 printer cartridges is stuck to the right of the printer. And the light keep flashing orange 5 times. Can someone please help me fix it.
LED blinking in Orange color 5 times = Print head is not installed properly or the print head has reached to the end of life.
May 29, 2010 | Canon PIXMA iP90 Mobile Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Yellow light flashes 4 times
4 Flashes says the ink tank is not installed or not installed properly. When the ink is in correctly it may have a bad switch which is under the ink tank and means you need a new carriage assembly.
Aug 11, 2009 | Canon PIXMA iP90 Mobile Printer
I have a flashing orange light on the printer, no error messages, any iseas?
Tell me how many orange flashes between the green flashes, and I'll tell you the problem...
Aug 03, 2009 | Canon PIXMA iP90 Mobile Printer
Error code 4 flashing orange - code 5c00
Hi Chris,
Error code 5c00 (flash in orange /green 4 times) indicates that purge unit has broken so that the printhead is locked down when initializing process performed. Sorry I have to say that no first aid for this problem unless you bring it to nearest service centre for part replacement. Hope this information helpful for you.
Regards,
Source:
Canon Inkjet Forum
Dec 13, 2008 | Canon PIXMA iP90 Mobile Printer
Canon pixma ip90 green light flash then orange light flash 4 times then back to green
Hi there SWCopiers,
Four flashes indicates 'Ink tanks installed incorrectly' or 'Printer needs repair'.
Click here for iP90 ink tank install procedure.
Click here for reset procedure.
Click here for instruction on contacting Canon Support. They have been very helpful. If it turns out that one of your ink tanks is faulty, they have replaced them at no cost in the past.
Hope this helps.
Remember: Good things come to those who Rate!!
Mike
Aug 07, 2008 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
541 people viewed this question
old marine
old marine
