Question about Kenmore 84072 Electric Dryer
Dryer stops & gets F04 code. ?? what is this code, can't find it in my book. Thanks LW
Kenmoore 417.84072300 dryer stops & gets F04 code. ?? what is this code, can't find it in my book. Thanks LW
  • 1 more comment
  • Anonymous Mar 15, 2014
    f04 dryer error code
    electrolux f04 dryer error code
  • 89 Answers
The F04 code refers to improper venting of the dryer.
either your vent is too long, or blocked by lint or a crimp.
dryer vents should be no longer than 10' in flexible venting or 15' in rigid venting.
alot you will find that at the EXIT port outside your house is clogged with lint. remove the lint and you should be ok.
Posted on May 26, 2009
F04 fault on a hotpoint aqualtis tumble dryer. Also 4 lights flashing. HELP!
This should be in your manual?
F04 Rear thermostat fault Advice: We recommend you call our customer service centre to book an engineer on: 0344 822 4224
Aug 19, 2015 | Hotpoint Washing Machines
What do Error codes F04 and E03 mean?
The dryer is in need of service if a code beginning with an "F" appears in the display.
Alternating between F# and E#, the dryer control has detected a problem that requires service.
Call for service.
May 04, 2014 | Maytag Maxima EcoConserve Series MED6000XW
Hotpoint Ultima Super Silent WF865. I'm getting error code F04 there's water in the machine and it's stopped.
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
Dec 14, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hi our washing machine keeps displaying error code f12 and will not go on does anyone no what this means carolyn
F01 - Short circuit motor triac - Book a washing machine repair. F02 - Motor jammed tacho detached - Book a washing machine repair. F03 - Wash thermistor open/short circuit - Book a washing machine repair. F04 - Pressure switch jammed on empty - Book a washing machine repair. F05 - Pressure switch jammed on full - Book a washing machine repair. F06 - Program selector error - Book a washing machine repair. F07 - Heater relay stuck - Book a washing machine repair.  F08 - Heater relay cannot be activated - Book a washing machine repair.  F09 - Incompatible eeprom - Book a washing machine repair.  F10 - Pressure switch not sensing correctly - Book a washing machine repair.  F11 - Pump cannot be activated - Book a washing machine repair.  F12 - Communication error - Book a washing machine repair.  F13 - Dryer fan or dryer thermisotor faulty - Book a washing machine repair.  F14 - Dryer element faulty - Book a washing machine repair. F15 - Dryer element relay faulty - Book a washing machine repair.  H20 - Not fillings. Check tap, hose and inlet valves LOCKED - Check interlock - Book a washing machine repair.  Here is a list of fault codes. I hope this helps !
Nov 21, 2009 | Hotpoint Aquarius WD640 Front Load...
I'm after some error codes please guys, It's flashing 2(Reduces Creases) & 4(Time Saver) I've been told that these 'do' mean something, but can I find out what it is....no Any help would be really...
List of the Error Codes I found on another site. I'm getting f04 light 2 (the "wash" light). Looks like you've got the opposite problem with your pressure switch stuck on full (f05).
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
Sep 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Kenmoore Dryer will not start
ok im with you,,send me the model #..and check your door switch..i want to veiw schematic on this,,,we have a defective part..
Jan 17, 2009 | Kenmore 63942 Dryer
Hotpoint wt965 f04 error
F04 indicates that the pressure switch is jammed on empty,
check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an enginner
This really is your only option.
Plz rate my solution
Thanks.
Dec 18, 2008 | Hotpoint Ultima WD72 Front Load...
Kenmore 84072 Electric Dryer Logo
1,195 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
