Microprocessor instruction set
Hi could you explain to me the role of the microprocessor instruction set.
  • 1 more comment
  • Jazz13 May 26, 2009
    What do you mean by and all their variations? Do you mean like the Arithmetic and logic instructions etc.
    So what you are saying is that the role of the microprocessor instruction set is to carry out a list of instructions that the processor can execute.
    Thank you
  • 32,281 Answers
An instruction set is a list of all the instructions, and all their variations, that a processor (or in the case of a virtual machine, an interpreter) can execute.
Instructions include:
  • Arithmetic such as add and subtract
  • Logic instructions such as and, or, and not
  • Data instructions such as move, input, output, load, and store
  • Control flow instructions such as goto, if ... goto, call, and return.
An instruction set, or instruction set architecture (ISA), is the part of the computer architecture related to programming, including the native data types, instructions, registers, addressing modes, memory architecture, interrupt and exception handling, and external I/O. An ISA includes a specification of the set of opcodes (machine language), the native commands implemented by a particular CPU design.
Posted on May 26, 2009
  • Chris Hingee
    Chris Hingee May 26, 2009
    YES
  • Chris Hingee
    Microprocessor usually refer to 8bit processors such as Intel 8085 and Zilog Z80.
    For a more detailed information on microprocessor instruction set use Google to search on Microprocessor instruction set
How to reset avr5805
n very rare instances, the AVR-5805 internal microprocessor might lock up, or otherwise cause mis-operation. This might be caused due to an AC line surge or line spike noise, or by static electric discharge on or nearby the unit, or to connected components. If the condition cannot be corrected by powering off the unit, including disconnection of the AC cord for a period of ten minutes and subsequent re-connection, then the unit may have to be re-initialized. Doing so will restore the microprocessor to its original out-of-the-box state, with all custom memories and settings erased, and the original factory default settings restored. Only use this procedure if you are sure that the microprocessor requires re-initialization.
1 Switch off the unit using the Main unit's power operation
switch.
2 Hold the following STANDARD button and HOME THX
CINEMA button, and turn the Main unit's power operation
switch on.
3 Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
and the microprocessor will be initialized.
NOTES:
If step 3 does not work, start over from step 1.
If the microprocessor has been reset, all the settings are reset
to the default values (the values set upon shipment from the
factory).
May 13, 2015 | Audio Players & Recorders
Work on daynow it don't
The modern motherboard performs many functions and connects to a wide variety of devices, but the hardware's most basic role is to connect the system's microprocessor to the rest of the computer. The central processing unit, otherwise known as the CPU, is typically housed in a socket on the motherboard. From there, the motherboard receives electrical power from the system's power supply and distributes it to the CPU.
Oct 24, 2010 | Computers & Internet
Display Panel Microprocessor No.
is a programed microprocessor (microcontroler) , only the jvc has correct version.
Jan 17, 2010 | JVC THD-50 System
Define microprocessor
microprocessor, integrated circuit containing the arithmetic, logic, and control circuitry required to interpret and execute instructions from a computer program computer program, a series of instructions that a computer can interpret and execute; programs are also called software to distinguish them from hardware, the physical equipment used in data processing .
..... Click the link for more information.
. When combined with other integrated circuits integrated circuit (IC), electronic circuit built on a semiconductor substrate, usually one of single-crystal silicon. The circuit, often called a chip, is packaged in a hermetically sealed case or a nonhermetic plastic capsule, with leads extending from it for
that provide storage for data and programs, often on a single semiconductor semiconductor, solid material whose electrical conductivity at room temperature is between that of a conductor and that of an insulator (see conduction ; insulation ).
base to form a chip, the microprocessor becomes the heart of a small computer computer, device capable of performing a series of arithmetic or logical operations. A computer is distinguished from a calculating machine, such as an electronic calculator , by being able to store a computer program (so that it can repeat its operations and make
, or microcomputer. Microprocessors are classified by the semiconductor technology of their design (TTL, transistor-transistor logic; CMOS, complementary-metal-oxide semiconductor; or ECL, emitter-coupled logic), by the width of the data format (4-bit, 8-bit, 16-bit, 32-bit, or 64-bit) they process; and by their instruction set (CISC, complex-instruction-set computer, or RISC, reduced-instruction-set computer; see RISC processor RISC processor [Reduced Instruction Set Computer], computer arithmetic-logic unit that uses a minimal instruction set, emphasizing the instructions used most often and optimizing them for the fastest possible execution.
). TTL technology is most commonly used, while CMOS is favored for portable computers and other battery-powered devices because of its low power consumption. ECL is used where the need for its greater speed offsets the fact that it consumes the most power. Four-bit devices, while inexpensive, are good only for simple control applications; in general, the wider the data format, the faster and more expensive the device. CISC processors, which have 70 to several hundred instructions, are easier to program than RISC processors, but are slower and more expensive. Developed during the 1970s, the microprocessor became most visible as the central processor of the personal computer personal computer (PC), small but powerful computer primarily used in an office or home without the need to be connected to a larger computer. PCs evolved after the development of the microprocessor made possible the hobby-computer movement of the late 1970s, when
. Microprocessors also play supporting roles within larger computers as smart controllers for graphics displays, storage devices, and high-speed printers. However, the vast majority of microprocessors are used to control everything from consumer appliances to smart weapons. The microprocessor has made possible the inexpensive hand-held electronic calculator calculator or calculating machine, device for performing numerical computations; it may be mechanical, electromechanical, or electronic. The electronic computer is also a calculator but performs other functions as well.
, the digital wristwatch, and the electronic game electronic game, device or computer program that provides entertainment by challenging a person's eye-hand coordination or mental abilities. Made possible by the development of the microprocessor , electronic games are marketed in various formats, such as hand-held
. Microprocessors are used to control consumer electronic devices, such as the programmable microwave oven and videocassette recorder camcorder combines a video camera and VCR in a single handheld machine.
The first commercially successful VCR, which used a Betamax format, was introduced in 1975. A competitive format, VHS (Video Home System), was introduced in the same year and became the dominant system.
; to regulate gasoline consumption and antilock brakes in automobiles; to monitor alarm systems; and to operate automatic tracking and targeting systems in aircraft, tanks, and missiles and to control radar arrays that track and identify aircraft, among other defense
Mar 30, 2009 | Computers & Internet
Denon 1508
This should resolve your propblem... taken from the Denon USA FAQ...
You’ll rarely need to "initialize the microprocessor" under normal operating conditions. In a few cases, the microprocessor will temporarily freeze or "lock up" just as your home computer does. When this happens, just follow the guidelines in the back of your owner’s manual to "unlock" the microprocessor and restore normal operation. (This is directly comparable to rebooting your computer. It’s an electronic wake up call to your unit’s temporarily paralyzed microprocessor "brain.")
If you experience some unusual behavior -- a channel that’s suddenly silent, "forgotten" level adjustments, some eccentricities in your unit etc. -- you may need to reset the microprocessor. Of course, you should check all connections carefully first. But if you’ve eliminated these items as a source of potential problems, you may need to go through the initialization process.)
Initialization is easy. Please refer to your owners manual for instruction on reseting the microprocessor as each unit may have its own individual protocal for reset.
What causes these problems? Several things can -- a jolt of static electricity, a current surge through an antenna input, etc. But don’t worry, the microprocessor is well shielded from any permanent effects.
When you do initialize the microprocessor, remember that this erases any setup instructions you may have previously programmed into the unit. However, the on-screen menu will quickly get you through a new setup. And, if you write down your preferred settings BEFORE you reset your unit’s microprocessor, you’ll have an even easier job!
If in the event you do intialize microprocessor reset please refer to your owners manual for instructions on setup..
Sep 20, 2008 | Denon AVR-1508 Receiver
Loses programing
It has a microprocessor that is supposed to keep the settings. What is happening is that the microprocessor is not holding the configuration, or the configuration is not being saved as it should be. This could indicate a bad microprocessor or a failed state maintainer circuit. In both cases I would suggest that you take you unit to a qualified electronics repair shop.
I hope this helps,
Shuttle83
Apr 01, 2008 | Sansui VRDVD4005 DVD Player/VCR
I want to upgrade my Compaq Presario 1200 AMD laptop Hard Drive - any limitations?
Several companies such as AMD and Cyrix are also developing processors which are completely compatible with Intel processors. This means that they are capable of emulating every processor instruction in the the Intel chips.
INTEL SOCKET INFORMATION
Intel designed a set of sockets. Each of these sockets supported a certain range of processors. Below we have listed the complete specifications and layouts of each of these sockets.
socket1.gif SOCKET 1 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
SUPPORTED PROCESSORS
169 Pins 17 x 17 PGA 5v SX / SX2, DX/DX2, DX4 OverDrive
socket2.gif SOCKET 2 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
238 19 x 19 PGA 5v SX/SX2, DX/DX2, DX4 OverDrive, 486 Pentium OverDrive socket3.gif SOCKET 3 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
237 19 x 19 PGA 5v/3.3v SX/SX2, DX/DX2, DX4 OverDrive, 486 Pentium OverDrive socket4.gif SOCKET 4 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
273 21 x 21 PGA 5v Pentium 60/66MHz, Pentium 60/66 OverDrive socket5.gif SOCKET 5 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
320 37 x 37 PGA 3.3v Pentium 75-133, Pentium 75+ OverDrive socket6.gif SOCKET 6 SPECIFICATIONS Slot 6 was thought and planed of, however was never actually ever implemented in any system.
PINS
PIN LAYOUT
VOLTAGE
235 19 x 19 PGA 3.3v DX4, 486 Pentium OverDrive socket7.gif SOCKET 7 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
321 37 x 37 PGA Voltage Regulator Module Pentium 75-300, Pentium 75+ OverDrive slot1.gif SLOT 1 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
242 Slot Voltage Regulator Module Pentium II / Pentium III Processors
PROCESSOR HISTORY AND INFORMATION
Below is a listing of all known processor manufacturers made to date. In the below list is information about major processors listed by the date manufactured as well as a brief description of the technology and advances of each of the processors.
INTEL 4004 - Microprocessor introduced in 1970 with the speed of 108KHz was the worlds first microprocessor.
INTEL 8080 - Microprocessor introduced in 1974 running at the speed of 2 MHz was used in the world's first PC, the Altair.
INTEL 8086 (Code Name: P1)- Microprocessor first introduced in 1976. The 80086 had a 16-bit architecture that allowed it to work with 16-bit binary numbers and pass them through a 16-bit data bus. The 8086 was available in clock speeds of 5MHz, 8MHz, and 10MHz.
MOTOROLA 68000 - Microprocessor released in 1979 was later chosen by Apple for the Macintosh computer.
INTEL 8087 - Floating-point math compressor compliant with the 8086 / 8080 microprocessor family.
INTEL 8088 - Microprocessor released in 1979. The 8088 was the first Processor used in the original IBM PC and XT personal computers because it was less expensive than the 8086 microprocessor because of the availability of less expensive eight-bit data bus supporting chips made it the microprocessor for the IBM PC. The 8088 was available in speeds from 4.77 MHz and 8MHz.and used the 16-bit architecture allowing it to work internally with 16-digit numbers. The 8088 had the ability of addressing up to 1MB of RAM.
INTEL 80286 (Code Name: P2) - Microprocessor introduced by Intel in 1982 which commonly is referred to as the 286 processor. The 286 processor supported 16-bit architecture, supported virtual memory, and was available in clock speeds of 8MHz, 10MHz, and 12MHz. The 286 was around 20 times faster than the predecessor 8088.
INTEL 80287 - A compliant processor to the 286, a floating-point math coprocessor. Specially designed 286 chips have the capability of placing the optional 80287 processor on top of it, giving the computer a math coprocessor.
INTEL 80386DX (Code Name: P3) - Microprocessor manufactured in 1985 was the next generation of Intel processors. The 80386DX included the math compressor, unlike the 80386SX, and still featured the 32-bit architecture and built-in multitasking. The chip was available in clock speeds of 16MHz, 20MHz, 25MHz, and 33MHz.
SPARC - Released in 1987 is short for Scaleable Processor ARChiture by Sun - used RISC (Reduced Instruction Set) to speed up processing.
INTEL 80486DX (Code Name: P4) - Microprocessor released April 10th 1989. The 486DX featured a built-in memory cache and 32-bit architecture. It had more than three times the computing power of the 386DX and was available in clock speeds of 25MHz, 33MHz, and 50MHz.
INTEL 80386SX - Microprocessor introduced in 1989 was the next generation of Intel processors. The 80386SX lacked a math coprocessor but still featured the 32-bit architecture and built-in multitasking. The chip was available in clock speeds of 16MHz, 20MHz, 25MHz, and 33MHz.
Good Luck, Please dont forget to Rate/Thank You.
Jan 17, 2008 | Compaq Presario 1200 Notebook
Alarm 1 won't go off when set to AM
Sorry it took so long to answer your question about the Clock/Radio. This look like a problem with the Clock/Radio's Microprocessor. You will need to reset the microprocessor by removing all power sources to the microprocessor. This means removing the Clock/Radio from the A/C power source and removing the internal battery (CR2430). After removing all the power sources from the Clock/Radio, let the Clock/Radio set for a period of about 3 hours. This will let the power completely drain from the microprocessor and reset it to the factory settings. You can then reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio should have reset and the functions returned to normal operations. If The Clock/Radio functions have not returned to normal. You will need to let the Clock/Radio's microprocessor drain off the power again and put a new internal battery (CR2430). Then test the Clock/Radio's functions again. The Clock/Radio functions should have returned to normal operation. If you are still having problems getting the Clock/Radio to return to normal operation. You can call the Emerson customer support at this telephone number 1-800-909-1240- Call them between the hours of 8am to 4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for their assistance. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Nov 19, 2007 | Emerson Smartset Clock Radio
Panasonic tc-15lt1 lcd
This does sound like a uP (Microprocessor) problem... If you don't know what a microprocessor is or how to troubleshoot the problem, your best bet is to cut your losses and take the set to a repair shop. In addition to the possibility of a microprocessor the easiest thing to check for would be to actually check the wiring... Sorry i cant help you more...
Dec 18, 2005 | Panasonic TC-15LT1 15 in. EDTV LCD...
Computers & Internet Logo
1,347 people viewed this question
David Payne
David Payne
