Question about Brother LS-2125 Mechanical Sewing Machine
Changing bulb on machine
Where can i get the same bulb for ls2125 from that the machine came with ? using other bulbs from local shops dont last more than a day or two.
  • 128 Answers
Try Joann Fabrics
Posted on May 28, 2009
My light just burnt iut onmy kenmore sewing machine and now it wont work
You need to replace the lightbulb. You may need to remove the cover over the lightbulb off in order to remove the bulb. Take the bulb to the local sewing machine repair shop or order a replacement online.
FWIW, you may want to consider an LED bulb. They are much brighter and do not get hot like the standard bulbs.
Mar 15, 2017 | Kenmore Sewing Machines
I have a Montgomery Signature Sewing Machine. I need a new bulb. How do I get one since Montgomery went out of business and where can I purchase one.
will be a 10 watt or a bit more and is available from most sewing machine shops ( don't get a bulb with too high wattage as it heats the end cover of the machine and burns the socket
bulbs are not manufacturer specific but are generic so take the old bulb along to get the same wattage and glass size as some globes are bigger in dimensions than others and will not fit in the end of the machine
Jan 02, 2017 | Sewing Machines
How do I change the bobbin winder on the Brother ls2125 sewing machine please
In the meantime, you can pick up a stand-alone bobbin threader at the local fabric store or online. They cost ~$25. A lot of sewists prefer using the stand-alone because it saves wear & tear on their sewing machine and they can also wind bobbins without interfering with the machine's setup.
May 03, 2015 | Brother Sewing Machines
Light bulb keeps blowing
The light from a light bulb is caused by the metal filament being white hot, over 1000 degrees Centigrade, so touching hot isn't too much in those circumstances! However there may be a ventilation problem in the bulb area but our machines are just the same in the bulb area. A bulb that has gone black has had an air leak into the glass envelope and this it may well be a just poor quality bulb.
Are you getting the correct bulb? Some shops will supply one for a normal light which has a weaker construction and is not suited to vibration and working in an enclosed area. If you (or the shop) use a bulb with a higher wattage than specified with the good intention of supplying a better light it could also be supplying more heat....
A genuine Janome bulb - if you can get one - may cost more but should last a lot longer. I don't want to say your sewing supply shop is not providing the right bulb but ....
The other possibility is that you have just had a run of bad luck to counteract someone else's good luck of not having a bulb blow. Sorry (but thanks!).
Finally, try to avoid touching the bulb with your bare hands when you fit the new one. All peoples, everybody's, hands have a natural layer of oils on the surface that can cause hot spots on a bulb surface and make it blow. If you have any acetone type thinners (nail varnish remover) give the bulb a wipe over with that before fitting to make sure it is thoroughly clean and use a piece of new clean cloth to hold it when you are fitting the bulb.
Good luck
Jan 16, 2014 | Janome Sewing Machines
How do I change the light bulb on the Bernina 1000 sewing machine?
The machine should have came with a light bulb tool, to help you get it out.
Very very hard to do that with out the tool.
You can get it at your local bernina dealer, or they should change it for free.
Does that machine have a power switch on the back top of the machine, there is a good chance that if it does it is bad. They go bad all the time. Some dont have the switch.
Apr 09, 2011 | Bernina 1008
How do you change the light bulb?
on the brother website they have a free operation manual that shows how to change the light bulb
on the home page to the left look for manuals under support
click on it & then under select product group choose home sewing & embroidery
& select model LS2125
at the back behind the face plate on the top left there is a screw take it out & turn the machine back around to face you & the face plate will come off & the bulb is accessable
Dec 12, 2010 | Brother LS-2125 Mechanical Sewing Machine
How to open the right front cover on a brother Ls2125? The manual only talks about how to change the light bulb.
I look at my manual & at the back of the of the thread take up lever ,where the thread guide is behind the machine on the top left hand side is a screw, just unscrew it take off the face plate & change the bulb & put the screw back in
Dec 10, 2010 | Brother LS-2125 Mechanical Sewing Machine
Cannot get the light bulb in the right position abve the needle any suggestions? We can get the light bulb up there with the grey bulb thing, but it will not stay up there. cannot see how to position...
Agree, this is a very tricky operation! Lie the machine down on its side - you still can't see properly, but it is easier that way. Be sure you are using the correct end of the grey plastic thing. One end is marked In and the other Out (or words something like that - I;m away from my machine right now and can't check). If the bulb is not staying in, then it is not in correctly and you just have to keep trying. As a last resort, take the machine to a repair shop and ask them to teach you how to do it. Believe me, I share your frustration. I don't think Husqvarna could have made changing the light bulb any more difficult if they had tried!
Nov 06, 2010 | Husqvarna Designer I
Replacement bulb for a Necchi 537FA
it's the same size as a night light bulb. That's how I replaced mine. You can pick one up at any hardware or dept store.
Oct 31, 2009 | Necchi 3537 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
82 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
