Question about Toshiba e-Studio163 Copier
- "No cassette with paper of size requested ...
  • 469 Answers
One of the cassettes is usually universal, if they tray has moving edge guides, the put in the paper you need and adjust the guides.
If the paper needed is in the cassette and you still get the message then the document feeder sensors are miss reading your original size, thy cleaning out the document feeder with a vacuum or compressed air, especially around the paper sensors..
Hope this is of some help
Ed
Posted on May 26, 2009
Paper size
It looks likes the unit comes with a Paper Cassette PCP-CP400 which is for Postcard Size paper. You should be able to reuse the Cassette for any postcard size paper. If you want to use L Size or Card Size paper you will likely need to purchase an additional cassette for that size.
Jan 01, 2013 | Office Equipment & Supplies
No cassette with paper of size requested is available when print from network
set up the copier derive again & set the paper size
Make sure that the tray's paper size setting is the same as the tray's
paper size setting in the printer driver. For example, if the tray's paper
size setting is A4R (LT-R), set "Setting Paper Size" to "A4-R".
Jun 29, 2011 | Toshiba e-Studio163 Copier
I wantto print from tray 2. but it always print on tray 1
When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an "autoselect" process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
Press the "Check" button, scroll down to "Paper Handling", press the Check button again, scroll down to Tray 2 Type and press the check button again. Select the type of paper you have in that cassette and confirm by pressing the check button.
Nov 16, 2010 | HP LaserJet 4700N Printer
I cant find my manual how to i place the paper underneath so it feeds through the bottom
You can use the paper cassette located at the bottom of the printer, on the front when the output paper tray is closed concealing the paper feed switch, the usb port and the cassette lamp.
1 Gently pull out the cassette from the printer.
2. Remove the cover from the cassette.
3. Place your paper in the cassette tray.
a. when using A5 or larger sized paper (non standard sized paper, pinch the tab and extend the cassette if needed.
b. legal sized paper is not loadable in the cassette
4. Do not load paper above the load limit mar4k.
5. Make sure the print side of the paper is facing down.
6. Align the paper stack against the right side of the cassette
7. Slide the paper guides so they fit the loaded paper stack.
8. The paper cassette will hold up to 150 sheets of plain paper, however you do not eant to stack any more than 50 sheets in the Paper Output Tray.
9. Reinsert the cassette into the printer. Then set the cover on the cassette. Now make sure the cassette is pushed al the way into the printer. (If long paper was used and the cassette was extended iy will now extend beyond the front of the printer
10. Prepare the paper output tray by opening the front cover and pulling out the tray extension until extended completely.
11. Press the paper feed switch so the cassette lamp lights.
You can slo select the paper source with the printer driver if you prefer .
Mar 07, 2010 | Canon Office Equipment & Supplies
Toshiba eSTUDIO 166 ''No cassette with paper of size requested is available''
Naeem Shoukat
Feb 16, 2010 | Toshiba e-Studio163 Copier
WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
Jan 18, 2010 | Canon Office Equipment & Supplies
Default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Dec 09, 2009 | HP LaserJet 4200 Printer
E Studio163 - Printing - "No cassette with paper of size requested is available"
after changed one of the sensors ,the same problem-"no cassette with paper of the sieze requested is available" has happened,alway paper jam.
any ideas why?
machine:e studio0259
Aug 27, 2007 | Toshiba e-Studio163 Copier
Toshiba e-Studio163 Copier Logo
578 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
