Question about Ovens
STOVES 600 oven door wont shut properly
I have a Stoves Q 600 GRF fan assisted gas oben and the door wont shut properly. I think there is a problem with the hinges but can get acces to them any help welcome
  • tomismith Jun 01, 2009
    did work
    the door stayed put and i just eneded up lifting the entrie oven
    tom
  • 89 Answers
Open the door about 30 degrees, lift straight up to release the hinges, this will allow you to remove the door.
you will be able to assess the hinges from there.
most likely the hinges are just out of alignment
Posted on May 26, 2009
Stoves Q720 GRF DO main oven ignitor clicks / sparks continuously
Might be the PC board, or it might just be the switch behind the oven knob - try disconnecting the wire leading to that switch and see if the clicking stops. If it does, the switch is bad. If not, suspect the electronics.
Aug 23, 2014 | Ovens
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van...
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Oct 07, 2010 | Stoves 720EF Electric Double Oven
My stoves oven is burning my kitchen cupboards
If you could provide some more information, then I may be able to help. What part of the oven is causing the problem, i.e. top or bottom door. If the doors don't shut properly then this may cause the hot air to escape. If it is one of the doors, is it sitting square in the frame?
Feb 20, 2010 | Stoves 720EF Electric Double Oven
Reconnecting terminals onto stoves 900GTF double gas oven
\i have a stoves 900 GTF double gas oven. The clock has suddenly started to flash. It does not enable me to set the time and therefore I cannot use the main bottom oven. I am unable to overide the auto to manual. Can anyone help me with instructions or with solving this problem. I have mislaid by instruction booklet. Thanks.
Nov 27, 2009 | Stoves Premier 900GRa Gas Double Oven
Stoves new home fan assisted oven. do you reduce heating time and or temperature
It is usual to reduce temp and or time for a fan assisted oven, as opposed to a conventional convection oven.
Please rate my solution.
Thanks.
Nov 24, 2009 | Stoves Ovens
How does the q900 works
I do not know either but I would be tempted to turn off the gas, but keep the electric to the oven, and use a plastic Knitting needle to find out. It should show on a display somewhere.
Feb 11, 2009 | Stoves Premier 720GRa Gas Double Oven
I'm looking for an instruction manual for a Stoves 900 GTF built-in fan assisted main oven. Can you help?
Let me have an email address for you and I will give it access on my BT Digital Vault for you to down load a copy that I have scanned.
Dec 05, 2008 | Stoves 720EF Electric Double Oven
Main oven door does not shut properly
i removed the side panels which exposed the hinge mechanism. I have then removed the whole door and the associated hinges by simply unclipping the retaining springs.
Dismantling has revealed that the pivot pins have become dislodged from their housing, and this is why the door was not shutting properly. I am now spot welding the pins back into position.
Also noted is wear in the slots in which the pins rotate but am hoping that it is all still serviceable as I think spares for Stoves are expensive.
One other point to note is the very poor design of the whole hinge assembly. Not what I expected from Stoves.
Jul 31, 2008 | Stoves 720EF Electric Double Oven
Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Jul 07, 2008 | Stoves Premier 900GRa Gas Double Oven
Ovens Logo
461 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
