Question about D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point
Access points I was asked to look for Access points to cover a 10 acre Greenhouse (wide open) How many do I need that would do the job? I have read of using four APs in repeater mode back to one AP ( manager ) Thoughts??? Paul..
Aplly any access point that its anttena is diatachble
an 18 db omni anttena .install it on the roof with a water resistant plastic box
u need only one
Posted on Mar 22, 2008
    Brigadier General:
  • 6,966 Answers
Am using for the past 5 months a LinkSys WRT300N as master with 2 WRT54G as slaves (repeaters). Both the 54Gs are using 1 of the original antenna + a rooftop mounted directonal antenna. 1 of the 54Gs is installed at a computer shop inside a school campus, the master 300N is at an office (outside the campus, a block away) and the other 54G is installed at a student dorm (3 blocks away from the office).
One favorable aspect of the 54G is that it will accept a firmware replacement; Alchemy and Talisman bySveasoft and DD-WRT by Brain Slayer, ipv6 by EarthLink, and another by Sputnik. I found the first 2 with the most features,  ease of installation and configure.
Hope this be of some help/idea. Post back how things turns up or should you need additional information.
Good luck and kind regards.
Posted on Oct 21, 2007
How to create a guest internet access in hp msm430 access point?
you asked 2 times?
that question is wifi only guess accounts
not all routers or AP wifi access points have that feature
and is deemed today as dangerous. to use.
hint expect to see less.
why not open the book that came with the AP .
here ill do that for you, spoon fed.
its only 5 years old or less.
page 15 + covers what it can do and can not do
better is have all PCs at home with sharing turned off
the GUEST mode is useless. and is unsafe.
http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c03738365-1.pdf
read why here.
guess
pw 1234.
super unsafe ways
and the guest most uses open wifi, always bad that.
this is why most new AP wifi routers or boxes have no such thing now. protecting owners from themselves... wise.
https://www.howtogeek.com/219808/warning-%E2%80%9Cguest-mode%E2%80%9D-on-many-wi-fi-routers-isn%E2%80%99t-secure/
Nov 25, 2015 | HP E-MSM430 Dual Radio 802.11n AP AM -...
My nokia N70 phone ask default access point when i play you tube videoeo
It's a normal thing, if its annoying you go to settings, and than access points and set a default access point. Turn off and turn. It should do the job.
Jan 09, 2013 | Cell Phones
Nokia 6300,plz can you open my gprs?
call you service provider and ask them to send you the internet settings then install the settings which they sent. then ask thme what is the access point name. when they say the access point name write in the following place settings -> connectivity-> packet data-> access point ->edit active access point . after writing in to it restart your phone then start using gprs. Have a nice day
Jun 19, 2011 | Nokia Cell Phones
I can not access My Linksys WAP2000 Business series. I can not reset it either.
With the access point UNPLUGGED from power
hold down the reset button, PLUG IN POWER, keep holding reset
after 10 seconds, release. Access Point will then be configured with
a default static IP address of 192.168.1.245
Then open a browser like IE or Firefox and type in that IP and the
config screen will show up.
Mar 28, 2011 | Linksys WAP2000 802.11b/g Wireless Access...
My phone ask for pin dialog if i ask for GPRS setting...what is pin dialog and how 2 install my GPRS??
Manual setting GPRS on Nokia E71:
1. Seeks Nokia Menu > Tools > Settings > Connection
2. Select Access Points > Options > New access point > default settings
3. Name the connection
4. Set Data bearer to Packet data
5. Fill in access point name (APN)
6. Set Username (None)
7. Set Prompt password to No
8. Set Password (blank)
9. Set Authentication to
Normal
10. Set Homepage to whatever site you like
11. Back #2
12. Select Packet data
13. Set Packet data connection when available
14. Leave Access point blank or
Depending on your service provider settings, You may need to get their default setting on some items listed above.
Dec 03, 2010 | Nokia E71 Smartphone
How can i activate internet on nokia E63?
Your device can detect and connect to wireless local area networks (WLAN). Using a WLAN, you can connect your device to the internet. To use a WLAN connection, you must create an internet access point (IAP) for the WLAN. Use the access point for applications that need to connect to the internet.
Use the WLAN wizard to create an access point
1. You can access the WLAN wizard directly from your home screen's information area. Another way to get to the WLAN wizard is to select Menu > Connectivity > WLAN wizard.
2. If the search finds WLANs, you can create an internet access point - scroll to the connection, select Options > Start web browsing. If you select a secured WLAN, you will be asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
3. To end the active connection, select the connection > Options and Exit. If you want to define whether you want to use the WLAN or packet data connection when starting to browse the web, you can set it so that the device always asks which access point is to be used.
Set up an access point inquiry when you open the browser
1. Select Options > Settings.
2. Select General > Access point, and from Always ask - You always get to select which access point you use.
Nov 02, 2010 | Nokia E63 Cell Phone
I am not able to connect my laptop with ACR-201 802.11b wireless ethernet adpotor. Do i need any driver
Yes, the adapter should come with a disc, if not, search online for that product then download and install the driver for it.
Jun 13, 2010 | OTC ACR-201 802.11b Wireless Ethernet...
Access point configuration
Access is easy to configure, you just need to understand basic setup you need to do and just have to find the same options on the configuration page of any wireless access point.
Things to setup.
1. Local IP Address ( You will get default 192.168.1.1 according to your device guide, still you can set different (not recommended, if not expert) )
2. Setup WAN IP-This could be dial up connection (PPPOE) or Internet IP Address provided by your internet provider.
3. Setup Wireless access point SSID, this is what you will find when you scan for wireless connection available
4. Setup security settings. You can setup WPA or WAP to protect security. Just need to select and assign key/password which you will be asked while connecting SSID
Follow the link for exact information on how to setup your Access Point
http://www.tomsguide.com/us/asus-wl-wl330,review-233-3.html
http://support.asus.com/faq/asus-faq.aspx?no=E8D3A5FD-995C-D299-0AE3-FBF28AA04DA6&SLanguage=en-us
http://www.ddp.ru/upload/images/PDF/WL_HDD25.pdf
Hope this helps
Jun 02, 2010 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
How i can reconfigure my dwl 2100 access point
reset your access point by pressing the small button on the front with a pen hold and count till 10
the default ip now is 192.168.0.50
open your browser and type 192.168,0,50
type admin as a user name leave the password empty press enter
you can now configure your access point password username give a new ip
Oct 14, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point Logo
160 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
