Question about Gateway Essential 400 PC Desktop
Do i have to purchase a Wire-less Network Card in order to use a wire-less connection?
Im currently on broadband but I am going to change over to Wire-less. I have been told i have to purchase a Wire-less Network Card in order for a connection with wire-less. Can you please tell lme if this correct?
  • 73 Answers
Yes You will need what is called a "Wireless Modem Dongle"
Type that into Google Search.
Thet range from Free to 30.00 Depending on Who you usa as your Provider.
Verizon has some good deals.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
Posted on May 26, 2009
  • Gateway Master
  • 6,487 Answers
If you really want to create your own wireless network, first of all you need to make sure that you have a wireless Broad band router and for your computer to wirelessly you need a wireless adapter that will be the receiver of the wireless signal from your router....
Can you introduce the version types of broadband network and its realization way?
First is the bearing network and broadband network to points clear, PTN and OTN are bearing network, both them are carrying broadband metropolitan area network (backbone) business. Itself is not broadband network. Broadband access technology at present mainly include: (1) the PON passive optical network, the current is given priority to with GPON, adopts the OLT + optical splitter, ONU + user solution, in the current mainstream broadband technology. (2) the DSLAM before FTTH as the main broadband access technology, is to use the original copper (lines) to realize broadband dial-up access. Is actually using MODEM digital signal modulation into high frequency simulation on copper wire transmission, with MODEM finally demodulation into digital signals.At present, the light into the basic finished copper retreated. (3) using LAN + light cat. (5) abroad and power carrier solution, is to use the high voltage wires at the same time the broadband service. (6) HFC radio and television use before, is the cable upload 50 ohm coaxial cable broadband business. Basic don't now.
Nov 23, 2015 | Computers & Internet
How do I change from wired hookup to wireless? Bob
Instructions
Things You'll Need
Broadband modem
Router compatible with modem
Internal or external wireless network adapter
Phillips screwdriver
Suggest Edits
  1. Prepare the Network
  • Purchase and setup a wireless broadband router by interfacing it with your wired computer. Choose a router that is compatible with your broadband modem and that supports the wireless network type you desire.
  • Enable WPA or WPA-2 security, and change your router's default password. Give your SSID or wireless network a memorable name.
  • Connect your modem to the WAN (wide area network) port on your router.
  1. Install an Internal Card
  • Purchase a wireless network card that is compatible with the router you purchased and with your computer. For example, if you bought a 802.11 b/g router, do not purchase an 802.11 n adapter.
  • Shut down your computer. Remove all cables and peripheral devices.
  • Remove the left side panel while facing the front of the case. You may need to remove screws or to manipulate latches and notches. Consult your case or computer manufacturer's documentation if you are unsure of how to remove the panel.
  • Clip the metal part of the anti-static wrist bracelet to a metal object, and ******** the bracelet.
  • Locate an available PCI or PCI-Express slot. Unscrew the screw that secures the slot cover that corresponds with the slot, then remove the slot cover.
  • Line up the wireless adapter's pins with the slot. Insert the card until it clicks into place. Do not force the card into the slot, or you may damage the card's connectors. If you feel resistance, remove the card, line up the card with the slot again, and reinsert.
  • Secure the card with the slot cover screw. Reattach the side panel, and replace any screws you removed earlier.
  • Reinsert all cables, and plug in all peripherals. Boot the computer.
  • Allow Windows the opportunity to detect the card. It should automatically install the drivers for the card. If you have updated drivers, insert the disk and install according to on-screen instructions.
  1. Install an External Card
  • Boot up your computer.
  • Insert your external wireless adapter into the appropriate slot. For example, if you purchased a USB slot, insert it into a USB port.
  • Complete Setup
  • Double-click the network icon in the task bar.
  • Highlight your wireless network. Windows will display the name you entered when setting up your router
  • Click the "Connect" button.
  • Enter and verify the security key you created when setting up the router. Click on "Connect."
If you have further query then try to let me know. Thanks for using FixYa.
Aug 27, 2011 | Cisco Linksys Wirelessn Router Black...
Got the router without instructions. How do I set it up to work with my lab top and desk top?
first thing you need to know is the default ip/password is 192.168.1.1 with the password being "admin" that will get you into the router im assuming your going wired to the desktop and wireless for the laptop, so first you'll need to hook the router up to the desktop using a cat5 wire from your network card to one of the numbered ports on the back of the router, ok now that you have a connection to the router open up a web browser and in the address bar type in 192.168.1.1, no user name and a password = admin, once your in there click under the wireless settings and enable the wireless network, change the ssid to something you like and can remember, then under the wireless security tab enable the wpa2 security encryption personal works fine then enter a nice password that you can remeber but isnt too easy to guesse, once you have that set up use the laptop to see if you can now see your new network and once you can try and connect to it using the password you just made up, now then if your going wireless all the way your still going to have to wire your desktop to the router for these initial steps once the changes are made then if you have a wireless card for your desktop then you can disconnect the wire and use your wireless card to find the new network and connect to it :) hope this is helpfull
Oct 13, 2009 | Linksys Wireless-G Broadband Router
CAN NOT CONNECT WIRELESS ADAPTER SO AS TO USE MY LAPTOP WITH SKY BROADBAND
i connect to the wireless adapter its very easy go to the wireless adapter & refresh to the network list if your notification area will have a wire less network when the wireess adapter search any connection then you see a option connect then click connect
Sep 17, 2009 | Adapters.com Computers & Internet
I have been using this product for the last 2
have you tried going into the properties of the network card and check the tcp/ip settings and see if it is set to dhcp. also try going to the Toshiba site and down load the current drives for it and reinstall them.
Jul 15, 2009 | Toshiba Satellite L25-S119 Notebook
I have a toshiba satellite a350d-ba3 how to setup wireless connection.i got different networks but all need a keyword.I tried to set up my own network and it was successful.I had saved it on a usb,but...
You have two questions thrown. And I will try to answer one after the other. You said you have wireless card. If you have no WIFI in your location, your wireless card could not be used so you need a router from the Broadband connection which your satellite computer will have a wire connection from the router. If you have WIFI booster connected from the router, your wireless card will be used without wire connection direct from the router.
Jun 21, 2009 | Toshiba Computers & Internet
NETGEAR Wireless G USB Adaptor Problems
I contacted Bigpond after my whole internet collapsed due to my amature abilities in fixing the internet. >_<" yet they fixed my internet connection by disconnecting my current (DLINK DIR-300) router from the network. hmmmm... the technician also confirmed that my current broadband modem (2WIRE 2071-A) isnt capable of supplying a shared connection to more than one computer!! she also directed me towards a modem with an inbuilt wifi router that "supposedly" is the best option right now. (2701HGV-W) I'm a bit shaky and the stupid NETGEAR adaptor problem still exists - im willing to buy the new modem if its guaranteed to abolish this problem and give me a better internet wise outlook - please any suggestions will be appreiciated =)
Apr 23, 2009 | NetGear Wireless-G USB Adapter...
How do I connect a laptop to my hp 2575
Without getting too complicated, the problem is the difference in how the work grups are named. The easiest way to fix this is download network magic. I believe its only 14 0r 15 bucks for the full version and in does a great job. I have several mixed operating systems running on my network and it fixed it all up in minutes. Good Kuck
Dec 29, 2008 | HP Photosmart 2575 All-In-One InkJet...
Using a Mobile broadband service for online use.
Im very possitive you cant do that the ones you can do it with normal wireless broadband boxes (wi fi) you can use this wireless by going to your network settings and put wireless (also wired you choice) and then it will tell you to fill some things out with the internet cable with a wireless broadband you can wire it but the connection is better but that depends on how or were u use it wireless is still very very good for more questions (DGKME@yahoo.com) also myspace.
Mar 30, 2008 | Sony Playstation 3 (PS3) Console
Cant go online wireless (working before)
Hi jamesone..
This router will not support vista laptops..and the warranty period for this router is only a single year..better you can go for advanced g or gs routers .. model no's like..wrt54g or wrt54gs..with a warranty perion of 3 years..
HI baby..
this is for u..
It seems that you are not connected to the wireless connection ..i think the operating system in your laptop would be xp..to fix this problem
right click > wireless n/w connection > click view wirelss network connection > click change the order of the preffered network connections > select your wireless network name > from preffered wireless network and remove it..and then right click wireless network connection icon again and try connect to the network.. you will get connect.. and will get an ipaddress..
Nov 29, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Computers & Internet Logo
56 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
