Question about ASUS Eee PC 900 PC Notebook
My asus eee 900 pc with 512mb of ram, i upgraded to 2gb of ram, and it restarted fine, now with either ram chip in it it will start to boot up, but the screen stays blank and it attempts to start up with a black screen then aborts and powers down. please help
  • rickjamz19 May 26, 2009
    the 2gig is one strip, i was told on ebay it was made specifically for this model of eee pc, even with the 512, it will not boot up anymore,
    any guesses?
    Problem Solver:
  • 10 Answers
Request you to check speed of 2 gb ram with old 512 gb, if u r using 2 strrips of 1-1 gb then first remove both and resinstall old 512 again, and checked, again install both 2 gb ram and check. if after installation of 2 gb ram laptop is not restarting the problem is only with speed of ram. u may need to install ram with proper matching speed
Posted on May 26, 2009
ASUS k8v mx RAM upgrade
go here http://support.asus.com/download.aspx?SLanguage=en&p=1&s=20&m=K8V-MX&os=&hashedid=dJ2XP7zr8tzeYbLp
Dec 05, 2013 | Computers & Internet
My computer is assus Eee pc 900, after I turn off hard disk in cmos , it always ask to for boot disk. now I can't log to cmos even I press F2 but it doesn't work. how to log to cmos ?
check with asus website for any bios upgradations or insert any boot cd and check..........i think it may be the problem with bios only................
Sep 24, 2010 | ASUS Eee PC 900 PC Notebook
Is it possible to up grade a asus eee fizz book
Yes it is possible to upgrade the ram and the harddrive, there will be little blanking plates on the back of the laptop, they are held in by small screws, undo the screws and you will have access to the memory and the harddrive. If you are unsure take it to a pc store and ask if they could find out what type of memory and harddrive is needed to upgrade. hope this helps.
Mar 24, 2010 | ASUS Eee PC 900 Notebook
When i start my asus eee pc 900 laptop i get an error it says
BIOS / system is not able to read ur boot files and boot sector on HD...press F8 when system starts and get into Safe Mode or Last known good comand that worked etc etc...and then do a system scan
Jan 11, 2010 | ASUS Eee PC 900 PC Notebook
Eee pc 900ha upgrade problems..
be sure that it is the same kinda ram ... I mean the frequency ...anyway ..go to bios..by pressing del on boot ...and look for some that says optimal factory defaults ... click ... ..after that press F10 to confirm and restart ... if after that will not read the 2 G ...you have to reinstall the operation system to make it see i t...
do not worry cause everithing is fine ..if the ram unit you add was damaged ..you should been having problems booting ....the solution for your problems was to remove tha Bios batery for a few seconds ..but Im not sure how easy is to get to it on this model ...
anyway if you want to see if they are readed ..just right click on My computer ..and properties and it should show all that is on it ...cpu...ram memory ...operation system..
the final solution is to reinstall .but it is a recommended one in all upgrading of this kind..cause the real changes in speed and promptness are like rockets fire...
anyway ..to be honest on all models the speed depends on the cpu size also...
Dec 10, 2009 | ASUS Eee PC 900HA Notebook
Asus Eee pc 900 can't boot (blank screen)
Just had the same thing happen, and I thought it was the motherboard. Then a tech friend removed the battery and held the power button down. Then he replaced the battery, and it booted up fine! Good luck...
Aug 14, 2009 | ASUS Eee PC 900 PC Notebook
Asus Eee PC 900 which has a weird problem
hello
The problem you are facing is a very common problem.
The memory dumping statement show that you RAM is dying and soon it will be dead.
Replacing the RAM would solve the problem.
Thank you
Aug 07, 2009 | ASUS Eee PC 900 Notebook
Bought 3 Eee PC 900/XPs. Bought recommended Crucial 2GB SODIMMS to upgrade memory for all three machines. After upgrade and just after Windows XP loads the screen goes crazy. Crucial suggested...
pop battery out ...... re-start with cord power , then shut down completely. pop battery back in after 5 minutes .....and try that ......you may also want to check your power settings .
Jul 13, 2009 | ASUS Eee PC 900 PC Notebook
I changed my1G ram in my asus 900ah to a 2g CrucialDDR2
As reported on the EeeUser forum, the EeePC 900 is somewhat picky with RAM upgrades. If the RAM chip is not exactly spec’d like the stock RAM module, then the computer would be prone to freezing, especially when switching between battery and mains power.
Also, note that the RAM module that came with the EeePC 900 is an AData PC2-3200 (running at 400 MHz) with part number DOGC1A08342. I find it strange that the chip is a 400 MHz one. Even the original 512MB chip that came with my EeePC 701 was a 667 MHz one!
This means if you plan to upgrade your 900’s RAM, better make sure the module is compatible!
P.S.: If this information was helpful, please rate this solution.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 20, 2009 | ASUS Eee PC 900HA Notebook
I put 2gb of DD2 ram in 800 mhz it wont show a screen? To fast of
Eee PC models use 533/667 MHz DDR2 RAM via a standard SO-DIMM module.
The hardware supports up to 4GB (2GB for the 1000 series, and some of the 900 series).
Feb 25, 2009 | ASUS Eee 900 Notebook
ASUS Eee PC 900  PC Notebook Logo
501 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
