Question about Gestetner Office Equipment & Supplies
Documents charger not work
The document charger doesn't work, What i can do
    President:
  • Gestetner Master
  • 990 Answers
Hello sir; I'm not quite understand what is document charger, is high voltage corona wire you are talking about?
Posted on May 31, 2009
Tip
How to change where screenshots are saved on Mac?
Step 1: Search for Terminal in Spotlight Search in the top-right menu bar.
Terminal App
Step 2: Open Terminal and type the following command: defaults write com.apple.screencapture location ~/Documents/Screenshots
Step 3: To apply the changes, enter the following command: killall SystemUIServer
That's it. If you entered the commands successfully, your screenshots will now save to a Screenshots folder within your Documents. Make sure to actually create the folder before applying the changes through Terminal though. Also, you can type any directory that you wish to save screenshots to, as it doesn't have to be ~/Documents/Screenshots if you would prefer something else.
on Jun 26, 2015 | Apple OS X 10.8 Mountain Lion
I dont know how to loudspeaker it?
The T2308 doesn't have a speakerphone capability. Sorry if that wasn't the answer you wanted to see.
If you need a manual, you can download one at
http://vt.vtp-media.com/ecp/documents/product_Product/612/UserManual/1546/t2308_manual_bkm.pdf
Aug 31, 2011 | Vtech t2308 Cordless Expansion Handset
Im trying to scan a document but its saying error code 2106. i have it hooked up through wireless
Try these things:
1. place a doc to scan in the scanner. Close the lid and hit MENU, COPY document, START.
If that doesn't work you'll need to contact kodak. If it does then try this next:
2. Check for ADMINISTRATOR rights.
  1. RIGHT CLICK on the kodak icon and select Properties > Compatibility tab > Run this program as an administrator
  2. Select RUN AS ADMINISTRATOR
  3. click APPLY
  4. click OK
Then try scanning again. If it still doesn't work then-
Reload the driver:
  1. select Start > Run.
  2. Type %windir%, then click OK.
  3. Double-click twain_32.
  4. Right-click Kodak, then select Delete.
  5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to (cd drive: > printer > scanner.
    Double-click aioscannr.msi, then follow the instructions to remove it
  6. Then go to cd drive: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
  7. Open Home Center Software
  8. Select Scan Documents and Pictures.
  9. Scan a document
If it still doesn't work then you'll need to take it in for service.
Jun 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
When printing, sentences over lap so the document is unreadable. Also it may only print the first line of a document.
I've seen word documents do this sometimes and fixing it has worked differently each time.
1) Open the document and press CTRL + A (select all) on the keyboard and then CTRL + C (copy), then start a new document and press CTRL + V (paste). Save the new document as something different and try printing again.
2) Open the document again and select all and copy again,but this time open wordpad (a different program to Microsoft Word) by going to Start > Programs > Accessories > Wordpad, and paste the text into wordpad. This may change some of the formatting. Now, select all again, and copy, and start a new word document and paste.
Copying the text out of word and back in seems to work more often. Sometimes the best program to copy out to is notepad, but you lose pretty much all of the formatting when you copy back into word.
3) If this doesn't work, you could try to update your printer drivers, and if that doesn't work, as a last resort, you can delete the printer and create it again via the Control Panel > Printers.
May 04, 2011 | Office Equipment & Supplies
How can you scan using OCR it comes in unreadable do I need some other software installed to use the OCR function ?
On OCR software we can only scan a full text documents. Document that doesn't have any line, image, graphic. Try to scan a full text document and check if that will work.
Hope this helps. Rate if it works. Thanks
May 03, 2011 | Canon Office Equipment & Supplies
My Seagate Free Agent Go 120 GB did not back up MY Documents automatically. LI formatted it. Now I have Ceedo, but it doesn?t back up My Documents.
The disk you received with the harddrive from Seagate needs to be reinstalled so it can function properly to back-up your documents. Once you reinstall the software for the Seagate harddrive, besure to check the back-up settings to insure it will back-up your documents.
Hope this is of some help. Bud
Dec 27, 2009 | Computers & Internet
Palm T/X won't hot sync on Window XP Media Center Edition
i had that problem too. sorry it is bugging you.
i know you probably want to sync your data rught now. So for now try to disable the syncing of documents to go (just for now)
on palm desktop, look for the conduits and temporarily disable the syncing of docs to go. Also ensure you plug in your pda charger as well as the usb cable (I found out this helps through experience) and sync. (Just to back it up)
as for the documents to go, there is probably a file(document) that is generating the errors. please look through documents to go on your palm desktop and remove any file you feel is not necessary. also take note that it is best if your pda has some free memory on it. you may want to save those documents on a disk (If you are not already that is..) clearing up ram made my tx more stable esp during hot sync.
please let me know it that worked for you. i still have some suggestions
good luck and enjoy
Nov 05, 2007 | Palm TX Handheld
Printing problem
This error message indicates that the printer memory is full. You might be sending too many documents to print at the same time. I would suggest dividing the number of documents/pages into smaller groups so the printer can take the load. Hope this helps!
Feb 22, 2006 | Xerox 6100/DN Laser Printer
24 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
