Question about Dell Dimension 4600 PC Desktop
Black vertical lines & looks like safe mode when XP is loading
When I power up, Windows XP appears to be starting just fine. After about 2 minutes as various programs launch, my screen turns into a psychedelic-looking screen with large pixels in primary colors (similar to safe mode) with wide black vertical lines across the entire screen. An alert box pops up, but I cannot read what it says because of the picture being so bad.
I don't think it's the video card because it looks fine when the computer initially boots. Could it be a driver gone bad?
Any ideas?
Thanks!
  • Anonymous Mar 15, 2014
    everytime I turn on computer there are lines across the screen and when update video card it works for a little bit then messes up again
    Problem Solver:
  • 13 Answers
Ur video card heats to much, so check if the fan in ur video card is working, if ur video card didn't have a fan try to install one
Posted on May 26, 2009
HP pavilion ze4600 XP operating system safe mode etc. will not load CD restore does not work either? help
Firstly hdd's shouldn't click. Purchase a new hdd set your BIOS to boot from CD drive, install XP from your disc.
Dec 05, 2014 | HP Computers & Internet
Emachines t5274 vertical blue lines during startup/XP.
It looks like you've got two issues. If you tried a different monitor and it too have vertical blue lines your video card might be bad, but hold that thought. I'm thinking you need to reload the operating system because you can't boot all the way up which is the second issue.
Have you tried to boot up in Safe Mode and do a System Restore? Turn the computer off, then turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option. When it boots, if it boots successfully things will look different in Safe Mode. The screen will be darker and icons bigger, but that's normal. If you get into the desktop successfully, click Start/Programs/Accessories/System Tools/System Restore. Select a restore point (date and time) that is before you started having problems. If the system tells you that you have no restore points, then you will have to either Reload the Operating System or do a System Recovery. By the way, System Restore does not lose your data, documents, music, pictures, videos, or programs unless the program was installed after the restore date. System Recovery LOSES EVERYTHING, it sets your system back to when you first purchased it.
Mar 26, 2012 | eMachines T5274 Desktop PC
When I turn on my Dell Latitude D600 PC, the windows xp loading page appears. After it has loaded the screen turns black and does not make any further progress.
It appears that your display works fine until Windows XP loads. Try tapping the key when powering on the laptop. Select boot in safe mode and see if the laptop works.Here's a description of safe mode by Microsoft.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
If your display works in safe mode then you have a video driver issue or virus or software issue.
Jun 20, 2011 | Dell Latitude D600 Notebook
Hello! I've got a LG LW40 Express Laptop. Whenever I turn it on, a black screen apologizing for inconvenience is what I see. It says that Windows didn't start successfully because of a software or hardware...
Take the hard driver out & put it back in, push it in nice & *** so that the pins go all the way in.
start it up & go into the BIOS witch should either F2,F8,Esc or Del.if you can't see the bios option
at the start it will appear as F8 or something like that in the list you keep getting.
Or just keep tapping F2 when you first switch it on.
In the BIOS go to exit then select LOAD SYSTEM DEFAULTS hit enter then go to the BOOT list & put them in this order if their not all ready done.......
1. FLOPPY
2. CD/DVD DRIVE
3. HARD DRIVE
4. USB or ANY OTHER DEVICE
it tells you how to change the values @ the bottom of the screen.
Go back to EXIT & make sure you SAVE CHANGES & EXIT.
It will reboot then select start windows normally.......JOBS A GOOD ONE!
if not bell me on my land line it's free land line to land line with BT & we'll try something else........GOOD LUCK.
Sep 04, 2009 | Computers & Internet
MS Vista patches broke my Desktop on my HP PC
after switching on the computer press F8 & Choose safe mode to boot the system & Restore the system in previose state & Before doing this make sure u backup the C Drive.
Don't Forget to Vote
Max
Jun 29, 2009 | Computers & Internet
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
2.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.
Do not choose the option to press R to use the Recovery Console.
4.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.
Follow the instructions on the screen to complete Setup.
Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
Booting problems with my Toshiba Satellite P105
Try to reinstall the video driver from Safe mode.
It appears your hard disk is OK but the operating system and or registry is corrupted.
1. Try installing the video driver first.
2. If it still does not work, back up your data files in Safe Mode then re-install XP again, make sure you delete the partition and create a new partition and do a full NTFS format, not a quick format.
Nov 12, 2008 | Toshiba Satellite A25-S207 Notebook
Hi, I wonder someone could help me. My computer is IMEDIA 1901, S/N 038958820300 with Windows XP. It was working all right until 3 days ago. Now after power is on, I have Packardbell logo screen, then...
Hi.
Even i once had this problem.
There are two solution.
First remove the ram and wipe it then fit it again.
If this doesn't help then get the system formatted.
Hope this will help you (By the way it did helped me)
Regards
Faraz
Oct 13, 2008 | Packard Bell Computers & Internet
Red vertical lines appear, can only run computer in Safe Mode
check the video cable and see if it;s properly seated. run the laptop with something that uses memory. if the video chip it going to show signs of problems, it will be more prominent when the laptop gets hot. most cases laptop motherboards have integrated video cards and cannot be replaced.
Aug 27, 2007 | Dell Latitude C640 Notebook
Dell Dimension 4600 PC Desktop Logo
220 people viewed this question
Alun Cox
