Question about Intel D845GVSR Motherboard
The machine cant start but the psu in ok
I run a 2.8 processor with an ESYS board.now the problem started with a failure in my VGA and upon opening the cpu(that is after disconnecting from mains),the cpu could not respond again even after replacing the psu....please help...anyone?
  • 79 Answers
Use a multimeter to test the output on your PSU, it sounds like your PSU is faulty..
Let me know
Thanks
Techmor
Posted on May 28, 2009
Hannstar ACER j mv-4 doesn't start up
no pc stated, maker or model #,, sounds kinda DESKTOP>?????
no oS stated
step one is test the MV4 on a known working pc,!!!
why wait, this so basic....
are you using VGA to VGA or DVI to DVI connections??????
the DESKTOP,
no sound means the fans are dead and PSU dead.
The PSU will run for 1 second and fans run now. if not PSU is dead.
if fans do run and stop that means PSU dead or mobo shorts or bad reg on MOBO. or bad ram. strip it down to test that.
ok fan runs that means 12vdc good. if stay running,
and if PSU stays up, then NEXT TEST IS Screen
is it 100 % dead, or do you get text or logos."
100% dead means to me bad VGA card(or chip GPU)
if the Hot key for BIOS fails, that means bad POWER/
or bad VIDEO card.
the fans run but are silent, I envy you.. sell me your fans....
im 1/2 deaf from Vietnam and can still hear all my fans.
my DT has 4 fans min. (it's Alien-ware box++++)
CPU, GPU and PSU, and 1 case fan,all must work.
do yours?
when you power on a PSU, the fans run and stay running
if that takes sides off so be it, ever clean the 5lbs of lent seen inside from 5 years, collected?
If you dont service any pc, this packs up and the CPU overheats
and shuts its self down by DESIGN.
why no do that service first.
see that CPU, see those fins, see that pack up there.
blow it out, outdoors, using CAN-0-AIR
mine over heats my GPU fast with lent, my Graphics car runs super hot and fast and lent is NOT ALLOWED here. ever..
old pcs with slow cpu ,, tend to packup slower, well lets say
they can run longer with huge lent here. its just slug processor so...
that is what it does.
recap.
  1. fans all run.
  2. BIOS dead?
  3. screen dead. no words no text at all.
  4. MV4 tested on other PC works. proves PC bad.
  5. LENT PACK job. as all do every year here, all.
  6. Bad VGA caRD. or using wrong port if PC has 2 VGA jacks. !
Jun 22, 2017 | Compaq Computers & Internet
Not starting properly and not starting at all most of the time
If u have the warranty valid, return the machine to the vendor. There is warranty void if you open the case, and therefore, you better return your machine for a proper investigation. The problem may be related to the failure of the PSU, power button, motherboard.
Mar 13, 2011 | iBuyPower Gamer Power WA500D3 Desktop PC...
My dell GX 1 optiplex pc is not powerring and power supply is not
Hi:
If you don't have the LED lit up on the board, the most likely failure is your power supply. You should be able to get a computer store to test it, to be sure, but a replacement is $30-40
Nov 24, 2009 | Office Equipment & Supplies
My computer is switching on and nothing displays in the monitor. After switching on, after a minute it automatically switch off. Mother board is Intel 845 GVSR processor 2.4 GHz. Service centre person is...
Try a bios reset first.
Second pull out the memories (RAM). If you hear beeps on startup the the motherboard and the processor is ok.
If not, possibly could be the processor.
Also try with other power source.
Jul 28, 2009 | Intel Desktop Board D845GLLY Motherboard
No Post No Beeps just lights and fans
If the computer just turns lights and fans thats because you have a piece of hardware that is unable to start.
My guess is that you burnt one of the three:
The CPU
The Board
A Card attached.
Disconnect the hard disks and DVD CD drives
Try removing a ram slot at a time and keep trying, keep doing that for all the pieces until you have none.
If at the end (when you get to a part where you only have Board and VGA plugged the computer still doesn't boot up, the best sollution is to try these 3 on another pc to make sure they are faulty before sending them to vendor.
Good luck
Jun 20, 2009 | ASUS K8VSE Deluxe (K8VSE-DELUXE 10PAK)...
There is no power. The green lcd light is blinking on back. Other then that I can't get the machine to do anything. HELP!
First thing to do is to verify that the pc isn't powering on.
- listen for the hard drive(s) and fans. If you don't hear them, skip these tips.
- open the cd/dvd drive bay. If it opens, you've got power.
Now, since this a vague subject, here's what the possibilities are IF the pc isn't power up:
- PSU (power supply) failure. They can be killed by power surges... frequent power outages from tripped home breakers, lightening strikes and so on. If the PSU fan isn't operating, it's a good sign that either the PSU fuse is dead or the PSU itself is.
- HDD (hard drive) failure. Although, in this case, you would get an error message on the screen informing you that no operating system was found.
- Improperly installed or loose componants. Sometimes the pc will simply shut down and refuse to start if RAM is installed incorrectly. It would also refuse to start up if the RAM were dead (not likely that all RAM would die at the same time though).
- CPU (processor) failure. Overheating caused by insufficient are flow (dead cpu fan or excessive dust) and power surges can cause a cpu to fry. This will cause the pc not to start up.
- Resource conflicts. If you've recently installed a new componant, the pc may not start if that componant conflicts with the resources that another major componant is using. In this case, uninstall the componant that you've installed and restart.
- MB (motherboard) failure. Excessive heat, shock or condensation can cause the micro curcuits of the board to melt, crack or short. In this case, there's nothing you can do but replace the board (tigerdirect.com can offer cheap, quality replacements).
Unless you'd care to elaborate further regarding the details of this malfunction, I'm afraid that you'll have to investigate each one of these possible causes to find the issue.
Apr 09, 2009 | HP Pavilion a706n PC Desktop
Only fans are starting - nothing else
Have you checked the CMOS/BIOS Battery? How about reseting the BIOS jumpers?
Test the system using Motherboard with processor and 1 RAM, just connect power and screen only, switch it on. It it fails try another memory... Whether the memory, board of processor is the problem.
Fixya me when done....
Post me back if it doesn't work...
Feb 08, 2008 | Gigabyte GA-965QM-DS2 (rev. 2.0)...
Intel D845GVSR Motherboard Logo
81 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
