Question about Buffalo Technology AirStation G54 WHR-HP-G54 Wireless Router (DHWHRHPG54)
Can't get it configured
Connected cables b/t buffalo wireless router and pc and cable modem per instructs, configured pc's IP adress for windows xp,went to http://192.168.11.1 and entered user name 'root' and left password blank,clicked ok per instructs, and got looped right back to the same username/password box---stuck there; what can i do?
  • 135 Answers
Try to reset the router using a paper clip, then try to re-log in to the router with the IP address, If you are still unable to log in , try log as admin as the username and password as admin or admin on the username and password is password.
Posted on May 26, 2009
Cable modem internet works when directly plugged into desktop, but when run through the router, no connectivity
Most cable Internet Service Providers (ISP) use a Media Access Control (MAC) Authentication to establish Internet connections for end-users. A MAC address is a unique 48-bit (6-byte) integer that is attached to an Ethernet NIC for each computer. To set-up your Linksys router to a Cable ISP, you have to do MAC Cloning. MAC Cloning is a procedure which enables a router to copy the MAC address of the PC that's registered with the ISP.
To setup a Linksys router with Cable connection you need to perform five steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the Router's LEDs
  4. Configuring a Linksys Router for a Cable Connection
  5. Power Cycling
NOTE: Before proceeding, use the computer that can go online when connected to the modem and follow the steps below.
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your ISP. If it can go online, the PC connected to the modem is the one that's registered with the ISP.
kb4682-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
Once an active Internet connection is established through the modem, connect the modem and the computer to the router by following the instructions below.
After ensuring that you have an active Internet connection, connect the modem to the router's Internet port and the computer to any of the four Ethernet ports. For instructions, click here.
After connecting the devices, check the LEDs by following the instructions below.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router. For instructions, click here.
After checking the router's LEDs, configure the router for cable Internet. For instructions, follow the steps below.
kb4682-002_en.png For Telstra Cable internet users, please contact Telstra to confirm if your internet connection is using DHCP or HB (Heart Beat) signal. There should be no other machine running HB client upon doing this procedure.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE
: If you are using Mac to access the router's web-based setup page, click here. If you forgot your IP address, click here. If you forgot your router's password, click here.
Step 2:
When the router's web-based setup page appears, click the drop-down arrow under the Internet Connection Type field and select Automatic Configuration - DHCP.
(a) If you are NOT using Telstra HB, proceed with DHCP setup.
NOTE: If you are a Telstra Cable internet user and you're using WRT120N, WRT160N v1, WRT320N or WRT610N, please select Telstra Cable.
(b) If you are using Telstra Cable, proceed with the following setup. Obtain your user name and password from Telstra. Please disable any HB client that might have been previously running on the PC after the router is configured.
Step 3:
Click kb4682-005_en.png.
Step 4:
Click MAC Address Clone.
Step 5:
Select Enabled and click Clone My PC's MAC.
Step 6:
Click kb4682-012_en.png.
Step 7:
Click Status. Check the value of the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're not online, perform a power cycle to synchronize the router with the modem. For instructions, click here.
NOTE:
If the Internet IP Address is all zeroes (0.0.0.0) click kb4682-008_en.png first then click kb4682-009_en.png. If the Internet IP Address is still all zeroes (0.0.0.0) perform a power cycle. For instructions, click here.
If the IP Address starts with 192.168.1.xxx or if it has the same first three numbers (octets) as the router's IP address, change the router's LAN IP address to a different LAN segment. For instructions, click here.
Once the router is configured, perform a power cycle. For instructions, follow the steps below.
Power Cycling
Step 1:
Shutdown the computer.
Step 2:
Unplug the router's power cable.
Step 3:
Unplug the Broadband modem's power cable and wait for 30 seconds.
Step 4:
Plug in the Broadband modem's power cable and wait for its lights to appear stable.
Step 5:
Plug in the router's power cable once the modem's lights appear stable.
Step 6:
Power on the computer on and test the Internet connection.
NOTE: If you're not online after performing this procedure, you may need to upgrade the firmware of the router.
Sep 28, 2010 | Linksys Wireless-G WRT54G Router
How do you get connection in a sb4200 motorola
1. If you have a modem, connect the modem to the router(make sure modem should be connected to the port on which LAN, Internet, WAN is mentioned. It would be a separate one port on the router) and router to the computer.
2. Insert the disk that came with the router, inside the computer.
3. Follow the on screen instructions.
4.No, connect to the wireless. OR
u can get connect by IP adress has well
go to explorer after contecting the cable in lan port to modem
type your IP adress which come from company by difold
(http://192.168.1.1)
after that your open your modem setup from there you can setup according to your locale sevice provider setup
Apr 18, 2010 | Arris SURFboard SB4200 Modem
When I connect my wireless router to my computer the speedtouch cannot be detected by my computer therefore I have no internet on my computer but I have wireless on both laptops which are directed through...
you probably have the router set to static ip so first you have to assign your pc with an ip range of the router , then log in the router set to dynamic ip and make sure you connect cables as per router manual. if it does not work then disable firewall , enable upnp devices . After configuration of wireless router you can enable firewall again. If you are using vpn with speedtouch then you should configure speedtouch to store username and password to connect to isp
Sep 11, 2009 | Computers & Internet
TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Mar 19, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I set up my linksys wireless router this morning on my desk top which has high speed or DSL and I like to have it on my laptop also. I need instructions on how to ave it on both computers,
If your laptop has a wireless card built in - or external, you will be able to get the wireless signal.  You need to open your wireless dialog - Start > My Network Places > View Network Places
Jan 02, 2009 | Computers & Internet
Cannot connect wireless 802.11b/g router to the internet on my vista home basic using the cd or following instructions in book provided
Rather than using the cd, it may be best to browse to the router's built in web page to configure. Your documentation should give you the default IP address, username, and password.
If connecting your router to a cable modem, turn off the router, turn off the cable modem for 30 secs. (unplug if necessary). turn the cable modem back on, turn the router back on, verify your pc is connected to the router. After 5-30 secs, depending on your devices, DHCP should assign IP addresses to each device and connect to the internet.
Nov 06, 2008 | Computers & Internet
I'm not sure about setting up Linksys WRT54G2 Broadband Router in conjuction with desktop Sony Windows XP. I have a HP Pavillion dv6700 notebookWindows Vista) to configure the router so I can use it...
the cable should go to any of the pc's u wish to configure the router with,then all you have to do is configure the router via internet explorer,just type 192.168.1.1 in your adress bar and use admistrator for both password and username(these are the defaults) the pc that u wish to set the router up must be set to dhcp(this is done by going to network connection settings selecting properties then where it says internet protocol(tcp/ip)
select properties and select obtain an IP address automatically(this will make router give you an ip adress)
Jul 30, 2008 | Computers & Internet
Netgear MR314
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at
the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network.
Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other
end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a
standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical
outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result
in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each
other across a network, such as the Internet.
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router.
The next few pages tell you, step by step, how to configure your network settings based on the type of Windows
operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network
adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/IP line for the applicable Ethernet adapter.
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
itself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart
your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area
Connection listed). Double-click the Local Area Connection. Click the Properties button.
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the
OK button again to complete the PC configuration.
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the
Classic interface (where the icons and menus look like previous Windows versions), please follow the
instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon.
Then click the Network Connections icon.
click the Properties button.
button. Click the OK button again to complete the PC configuration.
Jul 05, 2008 | NetGear MR314 802.11b
Unable to open internet page
let you router allocate the ip addresses manually by enabling DHCP and restart the router,and remove the usb adapter from the usb port and reconnect it, but when you right click on the taskbar on the little pc icons for your connection click enable WZC windows wireless Zero configuration as this will dissable the software you got with the usb adapter and hopefully make the connection more stable, but ensure you have a strong signal.
Jun 01, 2007 | U.S. Robotics MAXg USR5421 802.11g/b...
Buffalo Technology AirStation G54 WHR-HP-G54 Wireless Router (DHWHRHPG54) Logo
363 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
