Question about Nikon D200 Digital Camera with 18-200mm Lens
Pictures are noisy
I have a D200 & lately the pictures have been turning out with a lot of noise.  I used the camera last week & the pictures turned out perfect.  Could anyone tell me why this could be happening?  I have a cheap Sigma lens on it, so I'm wondering if that would be causing these problems.
  • joebrown19 Nov 18, 2007
    I have recently bought a nikon D200 and have moved from a D50.
    My D200 picture quality seems to be so poor compared to the D50. A lot of noise, the images are dark and dont seem to be as sharply focused.
    Ive set the D200 to the same settings as the D50 and tried a few different lenses but still cant get the same quality. Can anyone help.
  • 37 Answers
What ISO setting are you using?  If you go above 400 ISO with your D200 you'll likely need to do some noise reduction when you process.  Check to see if you accidentally activated AUTO-ISO.
Posted on Oct 23, 2007
SOURCE:
My Nikon D2oo is not working with Extreme 111 Compact flash cards that I just had the camera Format. There is an burn oder coming from either the camera or card.Wanting to put card not formatted with...
Hello, and thanks for using FixYa.
Please if the card contains any important pictures, connect it to a computer and copy them to the computer if they are not backed up. Then put the card in the camera and format the card in the camera, then you can connect it back to the computer, put those pictures in there and then the card back into the camera if that is what you wanted to do.
Note that the camera might not show your pictures, unless they are named the same way as original pictures taken with the camera.
Oct 22, 2010 | Nikon D200 Body Only Digital Camera
How do I use the LCD screen to take pictures
Unfortunately it is new cameras feature and not available for D200.
Jun 02, 2010 | Nikon D200 Digital Camera With 18-135MM
Bushnell Trail Sentry Model 119320C Problem
maybe the deer are turning the the camera off.they are pretty smart .just kidding ,im a minnesota deer hunter,and i have downloaded the manual for this camera,and am currently looking for solutions,as far as formating the card ,you need to know what format first,then using your computer,right click on the card reader in my computer and you should see format,click on that and you should see options for fat 32,ntsc,if it uses other format,may need software,or possibly the camera has the capeability to do it ,still reading the manual,try a test with it in your yard after dark,and monotor it for a couple hours,maybe you will notice something
Oct 14, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Reinsert memory stick
Are the contacts on the card clean? Is the slide switch on unlocked?
Sep 13, 2009 | Nikon Coolpix 990 Digital Camera
My Nikon d40 is all of a sudden taking dark pictures
Silvanus is correct - I have a D200 and often by accident adjust the exposure bias dial when taking the camera out of my backpack resulting in dark shots. I bet this is your problem.
Dec 28, 2008 | Nikon D200 Digital Camera with 18-200mm...
Kodak Z740 digital camera
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 08, 2008 | Kodak EasyShare Z740 Digital Camera
Nikon D200 / photos coming out magenta somtimes blue
Set it to a manual white balance colour temperature, 5200K being an average one to start testing at. Does this make a difference? If not, then the sensor, RGB lightmetering sensor or exposure board may be at fault. The peripheral area of most sensors is used for white balance metering, which denotes a sensor issue, although if the exposure board isn't reading this information correctly, then it will give varying results. However, Nikon's 420 pixel RGB sensor on the D200 may also be taking WB readings. I'll be talking to Nikon soon, but try manual settings first.
Jun 30, 2008 | Nikon D200 Body Only Digital Camera
Nikon D200 incomplete RAW pictures
If youre using exposure bracketing, especially when raw+jpeg is used, this is saving out massive amounts of data to the memory card. Have you tried using a faster (80x) memory card and/or just using raw alone? You can always make the jpeg at the computer later.
Mar 11, 2008 | Nikon D200 Digital Camera with 18-70mm...
Nikon D200 Digital Camera with 18-200mm Lens Logo
48 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
