SOURCE: Sony KDF-55WF655 55" LCD Projection TV
I have the same TV and the same problem, I take out the block of colours red, green and blue (the blue colour is broken) and I went to the electronic supplies for ask the price and they don't sell just the little blue mirror (blue pixel), they sell all block for $2,050.00 dollars. It's the price for a new one
SOURCE: Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
I fixed my problem by removing the lamp and vacuuming the hell out of the hole where the lamp lives and also getting all of the dust out of the rear ventilation grids with my vacuum. I put the old lamp back in and what do you know the TV has worked perfectly ever since. My lamp was over a year old and did not show any signs of hazing on the lens that you might see on a lamp that has a ton of hours on it. I just thought I would try to put it back in before I spent a couple of hundred bucks on a new lamp.
TA DA problem fixed.
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
SOURCE: My Sony LCD projection TV - not turning on easily
The flashing is a diagnostic code that should be listed in the owner's manual. It may indicate a lamp failure or fan failure. Check there. If you can not find the manual, please post here what light(s) is/are flashing and I'll look it up.
Thanks,
Dan
